Tyvek Roof Wrap
Has anyone used the Dupont Tyvek Attic Wrap? The Tyvek wrap is placed on top of the roof trusses/joists before the house is sheathed. It is suppose to make a house up to 30% more efficient. Of course the wrap is expensive at about 200 bucks a roll. I think a roll is 4 x 100.
There is an installation video on the Tyvek site. Let me know what you guys think. |
Trade: Builder/Framing Co.
Re: Tyvek Roof Wrap
How would tyvek on top of the rafters make it more energy efficient? The line of insulation is usually at the ceiling joists and the attic is vented. ????
Trade: Residential General
Re: Tyvek Roof Wrap
Looks like a great idea.
http://www2.dupont.com/Tyvek_Constru...atticwrap.html I'll probably try it. |
Trade: Renovations
Re: Tyvek Roof Wrap
Great! Interior gutter system. Now you can cheap out on the roofer.
Commercial construction
Trade: Commercial construction
Re: Tyvek Roof Wrap
30%? Sounds like horsesh*t.
Bah Humbug!
Re: Tyvek Roof Wrap
I really don't see the point, nor can I figure out how it's supposed to work.
Super B
Re: Tyvek Roof Wrap
The breathable metalized surface reflects away the heat during the warmer months and holds in the radiant heat during the colder months, also insures a tighter envelope.
Bah Humbug!
Re: Tyvek Roof Wrap
Are we not supposed to be venting the heat from the attic including in the tiner time when hot air holds moisture and migrates into the attic space? If the wrap, sitting loosly on the bottom of the roof deck creating pockets in each rafter, then reflects the heat into the attic space will it not be also causing the insulation and exposed framing to become saturated with humidity? Will this metalized vapor barrier be blocking air from the attic area from exhausting through the vnetilation?
#9 | |
Super B
Re: Tyvek Roof WrapQuote:
#10 | |
Bah Humbug!
Perhaps I am wrong, but as I think about it, that's where I keep ended up. This design will trap moisture. I have the same hangup on those attic envelopes where the rafters are sprayed with closed cell foam insulation. Where does the mositure go? |
Re: Tyvek Roof Wrap
I saw Tyvec placed on a roof deck before a standing seam panel roof was installed, but it looked just like standard house wrap. Commercial building...I would have liked to have stopped and asked why, but I never had the time.
Re: Tyvek Roof Wrap
A builder friend of mine is using the product and he thinks it is helping sell his homes. They even have a monitoring system to show the decrease in heat up in the attic. I see the benefits in heating and cooling, I didn't know if moisture would be a problem or not.
Trade: House Wapping
Re: Tyvek Roof Wrap
Properly installed, DuPonts attic wrap does not creat air "pockets."
I suggest you all watch the video of its installation at DP's site. Contrary to the notion of air "pockets," the use of rafter caps go on top of the wrap, on top of the rafter, pushing it down between the rafters to create a channel for the ventilation. It allows vapor (water molecules) to escape. The actual method of weather resistance is that water itself has a tighter molecule composition, it can't penetrate the paper. When it turns to vapor, the molecules separate, thus each alone is able to pass through the paper. Physics. |
Trade: carpenter, builder
Re: Tyvek Roof Wrap
Make yourselves aware of it. Because of its cost to install, it may be rare for a while. But if your customer with money and some knowledge of it asks for it, you won't feel like a dumb dumb if you at least know a little about it.
I don't mean to sound like I'm preaching. Just glad I learned of it from a salesman a while back |
I prefer carpenter
Re: Tyvek Roof Wrap
i hope i never have to use that, sounds like a pain in the a##, watch it will probably be spec`d in the next job hahah
Trade: GBC & Roofing ReM Comm & Res & Insured loss restoration
Re: Tyvek Roof Wrap
Interesting?
For this system to work on a Hip roof ALL ridges need to get ridge vent. Anybody ever put ridge vent from eave to peak on a hip roof? Should be good for re-roofing biz. Lets cook some shingles? |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
