Tricks Of The Trade
Old 03-02-2007, 08:59 PM   #1
JourneymanCarpenterT
Journeyman T's Avatar
Lightbulb
Tricks Of The Trade
Tricks of the Trade
I’m posting this in general discussion, because I want to include tricks from several trades:
  • Carpentry
  • Including Decks & Fencing, Finish Carpentry, and Framing.
  • Flooring
  • Not only Ceramic & Stone Tile, but Wood & Vinyl Tile as well.
  • Drywall
  • Roofing
  • Windows, Siding & Doors
  • Excavation & Site Work
  • Residential & Commercial Construction
  • Remodeling
Please restrict your posts to actual building tricks only. This excludes tips on business, as well as tips on “were to get the best deal on whatever.”
Here’s an example of what I mean:
Framing:
To speed the removal of door plates, wait until framing is complete before installing the jack studs. Then cut the plates off with a circular saw set a 1 - ½” depth, using the king studs as a guide.
Journeyman T is offline
Old 03-03-2007, 12:19 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Tricks Of The Trade
I cut the door plates about 1/2 way through from underneath during layout, come back later and it takes two strokes with a saw and no chance of hitting the concrete or sub.
reveivl is offline
Old 03-03-2007, 01:03 PM   #3
Thom
thom's Avatar
I blunt the metal tips on my "Cat-of-nine-tails" so as not to so seriously injure my guys that they are unable to work.
thom is offline
Old 03-03-2007, 02:33 PM   #4
Speaking of blunting tips, blunting nail tips can prevent splitting. Simply blunt the point of the nail with a hammer before driving it into the wood.
Old 03-03-2007, 02:42 PM   #5
wackman's Avatar
Trade: Builder, Additions, large remodels...Lately also small remodels.......
Heard that years ago when I was an apprentice, along with running it through your hair to "grease it", and neither seemed to work any better than normal for me. I'd watch all these apprentices blunting the point or rubbing 16d on their head like fools and decided we were being hazed.
wackman is offline
Old 03-03-2007, 02:42 PM   #6
dirt diggler's Avatar
Trade: contractor
no kidding!?
makes sense more i think about it
good tip - i will try that
dirt diggler is offline
Old 03-03-2007, 03:18 PM   #7
Palisade Point Const.
TempestV's Avatar
most of the time when your hands are sweaty, the sweat on your hands will do the same thing. and Blunting/lubricating does work to keep nails from spliting the wood.
TempestV is offline
Old 03-03-2007, 03:36 PM   #8
TempestV's Avatar
pushing a nail into the female end of an air hose to push on the air valve makes a great easy to carry blow nozzle for blowing sawdust off a floor or whatever.
(rather old, but I thought the blunted nails were too) the back of your tape is a great place to write your cut list- the pencil rubs off with a smuge of your finger
tacking the top and bottom plates of a wall together with 8's when cutting them to length and doing layout keeps them identical
TempestV is offline
Old 03-03-2007, 03:47 PM   #9
The best way to lubricate fasteners is with either bee’s wax, or Akempucky.
Jamestown Distributors / McFeely's
Old 03-03-2007, 04:00 PM   #10
TempestV's Avatar
I've heard of carpenters hollowing out a cavity in the base of their hammer handle to press some bee's wax into for that purpose
TempestV is offline
Old 03-03-2007, 04:59 PM   #11
wannabe
WNYcarpenter's Avatar
Trade: carpentry
I doubt it's new to anyone, but when trying to set deck joists alone I'll tack a 16 to the top of the board at the opposite end and bend it over. It allows me to nail off my end while the opposite hangs from the rim joist. The easiest is to use joist hangers of course, but a neat trick to keep up your sleeve anyway.
I'll use your tips tempestv...thanks!
WNYcarpenter is online now
Old 03-03-2007, 06:06 PM   #12
Tscarborough's Avatar
Blunting nail points causes them to crush the wood instead of split it. My Grandfather taught me that when I was 5, and I still do it on trim and thin wood.
My tip:
On new construction, brick or rock, immediately after washdown (once it dries, of course), use a penetrating sealer on the bottom 2'. This will prevent splash-back stains from the dirt.
Tscarborough is online now
Old 03-04-2007, 07:14 AM   #13
my own boss
supercrew's Avatar
Trade: carpenter
Send a message via Yahoo to supercrew
or just cut the plate at the king and run the jack to the subfloor, makes for a stronger opening.
slap staple the sill seal to the bottom to the green plate, keeps it in place.
when using TGI,s run the furthest walls rim board first, lay your joist on layout, then snap a line across the front wall to length and then cut all TGI's at once..(major time saver)
before sheathing the wall, mark the bottom n top of the inside jacks on the plates, mark the plywood top n bottom when you get there, snap a square, cut, nail, perfect opening..
when filling a new chalk line, pull out a "normal" amount of line...then fill.
when siding a gable....run a piece level with the siding and another up the rake to create your angle(pattern)
when siding a gable...Always snap the soffit line from the peak to the birdbox so the pattern works....
when sidin ANY wall, ALWAY measure the total length 1st and do the math so you dont end with a 1' piece.
Never work for anyone that you have heard say "im the person who pays you".
oh yeah...when finding a center, use 2 tapes and just find the corresponding marks, faster than a caculator and no double checking.
when plumbing...the stuff runs downhill.
ok im done.
i only work off drawings
supercrew is offline
Old 03-04-2007, 07:48 AM   #14
dreamwvr's Avatar
Trade: Industrial, comm. general contractor
TO ATTACH WOOD TO CONCRETE DRILL THROUGH BOARD AND INTO CONCRETE WITH A 3/I6 BIT, INSERT A PIECE OF TIE WIRE, THEN HAMMER IN A 16D DOUBLE HEAD NAIL. VERY STRONG AND PULLS OUT WITH HAMMER OR BAR. I USE THIS ALL THE TIME IN FORMWORK. SPACE ABOUT 12 TO 18 INCHES. 2 8D NAILS WORK WELL 2.
dreamwvr is offline
Old 03-04-2007, 09:26 AM   #15
Chris G's Avatar
Trade: Porch and Deck Builder
Never adjust your seat whiie braking or accelerating.
Chris G is offline
Old 03-04-2007, 09:33 AM   #16
Owner
ajbackhoe's Avatar
Trade: Excavation, Site work, Septic, Demolition
When setting pipes in your drainfield, set grade stacks dead center in the trench and use plumbing strap to fasten the pipe to the top of the stake every 10 feet. Then put your stone in, pipes stay on grade and on center. Works great for us guys that do it alone.
Alan
aoconstruction.net
A O Construction Inc.
Attleboro, MA 02703
Email: alan@aoconstruction.net
www.aoconstruction.net
ajbackhoe is offline
Old 03-04-2007, 02:51 PM   #17
wackman's Avatar
I'll have to give this trick another try then, I't been a long time and I've never seen anyone do it except that first time I was told about it.
Heres a good one: When removing trim that is attached with casing nails and you need to put it back on, to keep from having pry marks or cats paw crushes use a punch (about 1/8" wide and 2" long) to just push the nail all the way through. Works great on cedar and other soft woods.
wackman is offline
Old 03-04-2007, 04:12 PM   #18
Rich Turley's Avatar
Trade: Residential Remodel
Just pull the nail from the backside. No larger opening from the punch and if the holes have been filled it leaves them filled, then you can nail in a different spot, which is ideal anyway.
Rich
Rich Turley is offline
Old 03-04-2007, 05:16 PM   #19
TempestV's Avatar
To expand on Rich's comment- a pair of channel locks works wonderfully for this task
TempestV is offline
Old 03-04-2007, 05:52 PM   #20
boman47k's Avatar
Since we are posting tips that some of us think of as well known but not necessarily so in differnt areas, I'll post one. Maybe two. Got a nail not wanting to come out the normal way with a claw hammer? Put the claw on it near the substrate and pull it sideways down toward the substrate. Repeat until nail release.
Prying sideways with a flat bar seems to make base and trim less likely to split if you intend to reuse it. Of course don't try to loosen too much at a pry, work down or up the length in increments.
Anyone who has driven a 16 p nail in some of this old wood just far enough that bends and does not want to come out will appreciate the claw turned sideways ( if they did not already know about it).
boman47k is offline
Post Tricks of the Plumbing Trade Here. Ron The Plumber Plumbing 216 02-09-2012 09:50 PM
Tricks of the Trade Nathan Painting & Finish Work 24 10-15-2010 01:32 PM
NEW FEATURE: Your trade is now listed next to your posts Nathan General Discussion 10 09-15-2006 10:45 PM
FEEDBACK: ContractorTalk.com Posts in a Free Trade Magazine Nathan General Discussion 71 04-21-2006 07:39 AM
