Tool Survey For Professionals [please Help Fill Out]
Old 10-14-2008, 10:17 AM   #1
jkersh's Avatar
Trade: Tool Design
Hello,
My name is James Kershaw and I am currently working on designing a tool to help with cabinet installation.
Below is a questionnaire that if anyone has time I would love to get your feed back to further my research and development.
Research Survey
On average how long does it usually take to install a cabinet?
What do you normally use for cabinet installation?
What do you feel works?
What are you likes and dislikes about your system?
Do you feel a tool to help cabinet installation is necessary?
  • Yes
  • No
Would you purchase a tool to help aid cabinet installation?
  • Yes
  • No
Would you prefer a free standing installation tool or a wall mounted?
  • Free standing
  • Wall mounted
What do you feel would be a necessary feature for a cabinet installation tool?
Do you feel a leveling system would be necessary?
  • Yes
  • No
What price range do you think would be reasonable for this tool?
  • $10-$20
  • $25-$50
  • $50-75
  • $100+
jkersh is offline
Old 10-14-2008, 10:47 AM   #2
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Re: Tool Survey For Professionals [please Help Fill Out]
They already have these on the market. Your choices are a little vague.
Cdat is offline
Old 10-14-2008, 11:01 AM   #3
jkersh's Avatar
Trade: Tool Design
Yes, I know. This is a project for a tool company that wants to explore into this category.
Any suggestions on how to improve the survey?
jkersh is offline
Old 10-14-2008, 11:41 AM   #4
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Ask more specific questions.
Cdat is offline
Old 10-14-2008, 01:37 PM   #5
jkersh's Avatar
Trade: Tool Design
do you mind filling out the survey? The whole purpose is to get end user feedback this is just the first survey
jkersh is offline
Old 10-14-2008, 01:55 PM   #6
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Originally Posted by jkersh View Post
Hello,
1. On average how long does it usually take to install a cabinet?
2.What do you normally use for cabinet installation?
3. What do you feel works?
4. What are you likes and dislikes about your system?
5. Do you feel a tool to help cabinet installation is necessary?
6. Would you purchase a tool to help aid cabinet installation?
7. Would you prefer a free standing installation tool or a wall mounted?
8. What do you feel would be a necessary feature for a cabinet installation tool?
9. Do you feel a leveling system would be necessary?
10.What price range do you think would be reasonable for this tool?
Be careful what you ask for...
1. Depends on the size of the job.
2. See following list:
POWER TOOLS
Belt sander
Jigsaw
Miter saw
Small router
portable tablesaw
A 1/2" vsr dual speed/hammerdrill (Milwaukee) with a box of assorted tapcon screws, lead anchors
power planer
hot-melt glue gun
circular saw
angle grinder
Makita 12v impact driver
Dremel tool with assortment of bits and cutoff wheels
DRILLS AND ACCESSORIES
18 volt or bigger cordless drills
battery angle drills
drill bits
countersinks
screw bits
pilot bits
holster for the screw gun
Hole saws and spade bits
Cordless saw that uses same batteries as your drill
magnetic extension
Masonry bits
Screw tip holders
Quick change hex shank bits and holder
AIR TOOLS
Small portable air compressor
18 gauge brad gun that shoots at least up to 2" brads
23 gauge pin nailer
air hose repair kit
extra air nails
monster hook for the nail gun
25' air hose
compressed air bottle
HAND TOOLS
Fold out allen wrenches
Fold out Torx bits
Drill bit case
Pencils
Pencil sharpener
1 1/2" stiff putty knife
channel locks
needle nosed pliers
linesman nippers
Metal shears (or tin snips)
hammer
Stanley angle divider
rubber mallet
dead blow hammer
Files (include a rat tail)
Hand plane or block plane
Chisels
STUD FINDER!
Hammer
hacksaw
key-hole saw
japsaw
awl
screwdrivers
pliers
utility knife
files
pliers
wire cutters
crescent wrench
vise grips
sharpening stone
pry bar
scribes
Coping saw
Steel framing square
25' Stanley tape
Nail set
Laminate file
Chalk line
Goggles
bucket boss
Stanley mini flat bar
Drywall saw
electrical pliers
sanding block
4 lb sledgehammer
sharp hand saw
CLAMPS
4" C clamps
18" to 24" bar clamps
spring clamps
Small 9-ply pieces to use for clamp blocks
8) 8" clamps
Jorgenson cabinet clamps
Wetzler F-clamps
FASTENERS
screws - 1", 1.1/4", 1.5/8", 2", 2.1/2" and 3"
Anchors, mollies, etc.
Asst. nails - finish - common
5 gallon buckets with the stacking trays
Tapcon screws and ez-anchors
HARDWARE
"weird" hardware items (little L brackets for fastening frig end panels)
miscellaneous spare hinges/slides
Extra 8-32 and 4mm screws for drawer pulls
Clear nylon door bumpers
shelf supports
shelf pins
angle brackets
washers
FINISH / TOUCH-UP
Shop Vac
cordless vac
color nail filler putty or sticks
Screw caps, different colors
toothpicks
masking tape
double sided tape
blue low tack tape
Some sort of cleaner
sandpaper
electric iron
touch up kit - solvent, stain, rags, sandpaper, 3m pads, various fillers, can spray lacquer
mineral spirits and lacquer thinner
409 or Fantastik
paper towels and/or rags
Drop cloths
CAULKING / ADHESIVES / GLUE
caulking gun
wood glue (white - yellow)
silicone
5 minute epoxy
Colorflex caulking
dap 30 white caulking
Homax caulking tools
3m contact adhesive
Construction adhesive
ELECTRICAL
Extension cords
Electrical boxes
remodel boxes
wire nuts
10-3 wire, 12-3 wire
Basic electrical kit - wire nuts, wire stripper, electrical tape, circuit tester, voltmeter.
three-way plug adaptor
Good 6-way with power surge
SUPPORTS / LADDERS / MATERIAL HANDLING
Chop saw table with end supports
2 wheel dolly with stretch tie downs and bungee cords
folding horses
folding table
cabinet hoist
2' and 6' ladders
Folding saw horses
LAYOUT
small layout jigs
laser jamb level
7' straight edge and string line
2' 4' and 8 ' levels
Shop-made blank jigs for locating door pulls
9-ply pieces 10 x 10 to make hardware jigs for locating holes on doors and drawers
MISCELLANEOUS
shims
radio
Flashlight
Razor blades
WD40
floodlights
Ramset for nailing to concrete
8' boards to use for blocking
PAPERWORK / ADMINISTRATION
Cabinet plans (plan and elevation views)
List of appliances with cut in sheets
Pad of paper
Cell phone
roll of TP
3. I don't understand your question. BE MORE SPECIFIC!
4. I love my system. It works.
5. If you mean a jig or hoist for wall installation, then yes, it'd be great. I have my own, home made jig.
6. Buy one? Why? I made one.
7. Free standing.
8. The more bells and whistles, the better.
9. Yes.
10. Over a hundred bucks since mine cost that much to make.
Cdat is offline
Old 10-14-2008, 02:08 PM   #7
jkersh's Avatar
Trade: Tool Design
Thank you, that is what I needed ot see I will make the survey more specific now that i understand where you were coming from
jkersh is offline
Old 10-14-2008, 02:20 PM   #8
jkersh's Avatar
Trade: Tool Design
Thanks again, is this more specific?
_______________________________
What do you normally use for leveling and lifting a cabinet for install?
Do you use a home made jig?
  • Yes
  • No
If so what are you likes and dislikes about your jig?
What do you feel would improve your jig?
Do you feel a lifting and leveling system for cabinet installation is necessary?
  • Yes
  • No
Would you purchase a lifting and leveling system to help aid cabinet installation?
  • Yes
  • No
Would you prefer a free standing installation system or a wall mounted?
  • Free standing
  • Wall mounted
  • Yes
  • No
  • $50<
  • $50-75
  • $100-$150
  • $200+
jkersh is offline
Old 10-14-2008, 02:33 PM   #9
Palisade Point Const.
TempestV's Avatar
Hello,
Research Survey
Depends on the cabinet
Depends on the cabinet- in general, look at Cdat's list, although I would add a Fien saw and, since I've been doing a lot of log work recently, a chainsaw. also, I have removed cabinets hung with a ramset, so apparently that's on someone's list.
It all Depends on the cabinets, the type of construction of the wall, the quality of construction of the wall, ect.
My system changes with the type of construction, with log, the worst part is cutting the channels for the trim to slip into.
You certainly aren't getting very far without tools. If you mean a new tool, what are you offering?
I don't hang a lot of cabinets, but if I knew that I had a bunch to hang, I probably would buy something to make it eaiser.
Depends how the tool works. Free standing is potentially better because you don't have to attach temp stuff to the wall.
for me, the most usefull tool would be something to channel out the logs, so the ablity to cut a perfectly vertical line up to 1 1/2" wide would be the best feature.
In the above mentioned tool, absoultly. In a jig for positioning the cabinets on the wall, it would certinally be a useful addition.
  • $10-$20
  • $25-$50
  • $50-75
  • $100+
It depends on what the tool can do- if it does more, then it's worth more.
TempestV is offline
Old 10-14-2008, 02:35 PM   #10
Mod / ArchiBuilder
Cole's Avatar
Please read our advertising rules:
http://www.contractortalk.com/faq.ph...aq_advertising
Participants may not solicit the membership for feedback or suggestions on their product or services.
Cole is offline
Old 10-15-2008, 11:28 PM   #11
seifconst's Avatar
Trade: Frame to Finish and Concrete
cdat, thanks for cracking my a$$ up, cripes, i'm still giggling. How bout this survey- So, how do you build a house? Would a house tool be something you would use? What does your current house tool weigh? Sorry, but had to have fun @ someone's expense.
seifconst is offline
Tags
cabinet, tools
tool storage SES Constructio General Discussion 55 08-18-2010 09:53 PM
old survey equipment TaitINC General Discussion 1 09-11-2008 03:02 PM
Do you use an impact driver? Quick survey help would be very much appreciated. cohaver General Discussion 4 04-02-2008 07:20 PM
Patio & spa pad over fill questions deckman22 Concrete & Paving 4 01-27-2008 06:14 PM
FEEDBACK: Online Survey Tool Nathan Off Topic (Non Trade) 9 08-29-2006 06:20 PM
