Today's Estimate Pics (not For The Weak Stomachs)
Old 02-26-2008, 05:10 PM   #1
General Contractor
JPV123's Avatar
Trade: Class "A" Contractor with "BLD" Classification
Comments anyone?
JPV123 is offline
Old 02-26-2008, 05:13 PM   #2
Brock's Avatar
Trade: Residential Remodeler
Re: Today's Estimate Pics (not For The Weak Stomachs)
Can you still reach the doorbell?
Brock is offline
Old 02-26-2008, 05:17 PM   #3
General Contractor
JPV123's Avatar
lol, yeah, with a 4ft pole. My question is (in a Mike Holmes Voice and attitude) Where the hell is the fill? How much would of it cost to fill it before they poured the concrete. Were not Heros, but we make it right.
JPV123 is offline
Old 02-26-2008, 05:34 PM   #4
Patrick's Avatar
How does that work?
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 02-26-2008, 05:34 PM   #5
Knowledge Factory
Floordude's Avatar
Who got hurt!!!
http://www.AustinFloorguy.com
Floordude is offline
Old 02-26-2008, 05:37 PM   #6
Carpenter/fencing
nywoodwizard's Avatar
I see what appears to be furing strips and some concrete nails for initial support ? could they have been pre fabbed slabs ? Its apparent it must of leaked real well.
Hope no one was sitting on that park bench thats now below.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 02-26-2008, 05:41 PM   #7
Moderator
Double-A's Avatar
A porch accident in some parts of Arkansas is seen as more of a tragedy than in others.
You know how many good dogs you can lose with one porch collapse?
New York Times, July 20, 2006
Double-A is offline
Old 02-26-2008, 05:46 PM   #8
General Contractor
JPV123's Avatar
It collapsed around 3am so no one was hurt. Good thing kids weren't playing ring and run that night. I think it was orinally held up at the fron by the bricks that are on an angle sticking out. then the furring strips must of been holding up the side against the house. Maybe another board went across the front wall. The front band of the house is completely rotted. The slabs look kinda thin to me.
JPV123 is offline
Old 02-26-2008, 05:59 PM   #9
user15686's Avatar
Start knocking on neighbors doors.
user15686 is offline
Old 02-26-2008, 06:00 PM   #10
Brock's Avatar
you price another concrete porch or are they going with a nice composite for the new floor?
Brock is offline
Old 02-26-2008, 06:03 PM   #11
Mod / ArchiBuilder
Cole's Avatar
LMAO! Thanks my keyboard is covered with water!
Cole is online now
Old 02-26-2008, 06:11 PM   #12
Patrick's Avatar
I dont understand, Can someone explain, Every porch I have seen was back filled with sand an gravel first.
Could it erode that much?
Patrick is offline
Old 02-26-2008, 06:13 PM   #13
Grumpyplumber's Avatar
Trade: Plumber
I see potential there for a retro-medieval moat.
Could be the latest home improvement trend....
Grumpyplumber is offline
Old 02-26-2008, 06:38 PM   #14
Al Smith
A W Smith's Avatar
Thats a fairly common method of construction. But usually theres four inch bearing on each wall. Looks like the brick edging on three sides compromised that. Filling that hole with dirt would have caused more problems than it would solve. Look at the existing grade outside. You would need to compact it every couple inches, If it got wet and froze it could possibly push out on all the surrounding concrete block walls. Something that happens commonly around my area with small porches resulting in bulging block. They make a steel deck pan just for that kind of pour but it looks like they just used plywood. I have seen homes with doorways into that area as basement storage.
(Edit to add) Wow I saved that pic and zoomed in. It looks like absolutely no ledge at all on the building side. That should have been a 12 inch block wall to carry four inches of that slab. Looks like zero inches.
Al Smith
http://www.awsmith.com
Last edited by A W Smith; 02-26-2008 at 06:48 PM. Reason: zoomed in to reveal... no ledge
A W Smith is offline
Old 02-26-2008, 06:50 PM   #15
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Geez! Did your estimate exceed $15,000?
"If you start the grout process over, you too could use sparkly grout!"
There is no such thing as an illegal immigrant, they are either illegal or immigrants.
I'm Retired, or a student, don't really know anymore.
wizendwizard is offline
Old 02-26-2008, 07:11 PM   #16
SchwartzRES's Avatar
Trade: Carpenter / Contractor
wow..be carefull with that one man...I wouldn't touch it unless i could replace that band board, and reflash the whole thing first..looks like a callback nightmare waiting to happen....I would also get a moisture/mold reading in that basement, before you start.
SchwartzRES is offline
Old 02-26-2008, 07:14 PM   #17
send_it_all's Avatar
I say hot mop it and call it a koi pond. You could build a cute little arched bridge to the front door.
send_it_all is offline
Old 02-26-2008, 07:15 PM   #18
General Contractor
JPV123's Avatar
AW - I thought gravel should of been used for fill. I see your point with dirt being used.
They want me to price out decking instead of cement. I was thinking of replacing the front band, attaching a ledger to the new pressure treated band, and chipping away the angled brick, drilling through the block and attaching a ledger with Hilti threaded rods set in epoxy. We've used this system before and it seems to work well. I'm thinking 2x10's for the ledger this way I have more surface area for attaching. I'll make the decking flush with the brick so it will have a brick border. I'll include composite as a nice upgrade.
JPV123 is offline
Old 02-26-2008, 07:17 PM   #19
General Contractor
JPV123's Avatar
No basement, There's a crawlspace about 3ft high.
JPV123 is offline
Old 02-26-2008, 09:06 PM   #20
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Let's use wood to support concrete
Tail light warranty from the original low bidder, right?
Chris
Chris Johnson is online now
How do YOU Estimate? Nathan Painting & Finish Work 54 12-09-2008 10:41 PM
Honoring your original estimate A.W.Davis General Discussion 8 10-11-2007 11:28 AM
Quote and Estimate Breakdowns....what's wrong with honesty? Flikka Painting & Finish Work 39 08-21-2007 10:27 AM
Estimate lead time fireguy General Discussion 5 03-19-2007 03:13 PM
Indented hardwood fixed w/ pics dkillianjr Flooring 3 09-24-2006 06:41 PM
