Things Only Professionals See
Old 09-21-2006, 11:49 AM   #1
Scott Young's Avatar
Trade: carpenter/remodeler
i am like most of you and cursed with too much knowledge when i go places i am constantly looking at things that most common people don't see. here are a few:
1/4 round used instead of shoe mold.
shoe mold installed incorrectly.
crown installed upside down.
casing used for chair rail and or base.
doors installed backward.
shingles installed without a starter strip on tabbed shingles leaving keyways open on the first run. (i got to fix that one for a friend when i noticed it and pointed it out.)
oh there are others, but what have you seen
Scott Young is offline
Old 09-21-2006, 11:56 AM   #2
Get the board stretcher!
TonyD's Avatar
Trade: Residential Building and Remodeling
Re: Things Only Professionals See
How about outside corners on drywall, without cornerbead, just a painted raw end.
"...You cannot strengthen the weak by weakening the strong..."
Abraham Lincoln
TonyD is offline
Old 09-21-2006, 12:04 PM   #3
4319hendrie's Avatar
Trade: Handyman/ Maintanance/ Student
Unfilled nail holes on trim work drives me nuts.
4319hendrie is offline
Old 09-21-2006, 12:33 PM   #4
Drywall finisher
dumplin1078's Avatar
Trade: Drywall
You have got to be kidding.
"I hate to tell you this, but you're a man. You're going to spend your life gettin' up one more time than you get knocked down." John Wayne
dumplin1078 is offline
Old 09-21-2006, 12:37 PM   #5
TonyD's Avatar
Nope not at all. An 1 bedroom apartment upper i rented for about 2 years. 10-11 years ago $400 a month. Every day was an adventure.
Abraham Lincoln
TonyD is offline
Old 09-21-2006, 12:50 PM   #6
My custom title
Brushslingers's Avatar
Paint on doorknobs, crooked cut lines and crooked tile lines, electric plates with the cover screw not up and down, ya... i'm anal. My wife gets mad when I walk into someones home and start scracthing paint from the knobs. I mentioned once to a good friend of hers, not a bad job but all these cut lines are croooked as hell... turns out, SHE did it.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 09-21-2006, 01:58 PM   #7
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Flashing and thin paint has to be the biggest one I notice. I swear everywhere I go I see one coat paint jobs that don't cover right and have no primer. Was at a Zaxby's the other day and noticed the poor job on the acid stained floor. There were saw cut squares, and each square you could see where they applied too much around the edges cutting them in, and never quite blended them right.
As far as everything else, I could probably make a list a mile long. Nail heads showing on trim, or nail that stick out an inch. Carpenters building things with stain quality wood and not sanding the fuzzies off the ends of the boards before nailing it together leaving ugly splinters sticking out at every joint.
Saw a shingled roof that buts directly up to the siding on one customer's townhome with no flashing or anything and has rotted out the whole wall. It's the neighbor's porch roof that was just re-done.
This list could be miles long if I sat and thought for a minute.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 09-21-2006, 02:56 PM   #8
carpenter and builder
Nick H's Avatar
Trade: carpenter and builder
One thing I always notuce is when a HO has hung his own doors, sometimes a pretty good job, but they always put the hinges in the wrong place, usually equidistant from top and bottom. I have a real job not to piont it out .
Dont give me problems, give me solutions.
Nick H is offline
Old 09-21-2006, 03:51 PM   #9
Central Florida Painter
YourWayPainting's Avatar
Trade: Painter
I know what you mean. I am constantly seeing crooked cut-ins, non-covering rolling, and paint in places that it shouldn’t be. Not to mention the piss poor excuse for a prep job. I don’t mention it to the home owners though. You just never know ...
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline
Old 09-21-2006, 05:06 PM   #10
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Radiator hose from a small block chevy rad custom bent to form a P-trap under a bathroom vanity. Yes the HO was a mechanic
Don't worry, the baseboard will hide it!
ron schenker is offline
The Following User Says Thank You to ron schenker For This Useful Post:
Metro M & L (09-18-2009)
Old 09-21-2006, 05:51 PM   #11
Pro Painter
AAPaint's Avatar
The one I hate the most........carpenters with caulk guns! No offense wood guys, you can build some beautiful stuff with wood, but leave the caulking to us!! Caulk is the number one thing I would have to say that I see poorly done, and it's one of the easiest. Usually looks like someone used a bucket of caulk and slathered it on with all four fingers!
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 09-21-2006, 05:58 PM   #12
mdshunk's Avatar
A little paint and a little caulk, makes a carpenter what he's not.
mdshunk is offline
Old 09-21-2006, 06:03 PM   #13
Moderator
Double-A's Avatar
I try to limit my caulk application to two fingers. I need the other two for nose maintenance.
Having a home owner say, "I plumbed the bathroom myself" and entering the crawlspace to see that pressure fittings were used and sani-tees are laying on their backs... Argh.
New York Times, July 20, 2006
Double-A is offline
Old 09-21-2006, 06:30 PM   #14
Teetorbilt's Avatar
Painters that remove the cover plates and then hit the receptacles/switches anyway. Tile setters who assume that the slab is flat. Framing carpenters that save a few bucks by re-using the concrete forming lumber from the dumpster. Framers who can't get a wall plumb, straight or flat even when using metal studs. Painters who dust the walls with primer so that nothing will ever truly adhere to it (anybody know how to strip drywall?)
Albert Einstein
Teetorbilt is offline
Old 09-21-2006, 06:47 PM   #15
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Awesome!
Looks like some pros were here.
Gordo is offline
Old 09-21-2006, 07:35 PM   #16
Bigbricklayer's Avatar
Trade: Masonry
I'm not a carpenter by any mean but there was a guy putting up trim in the house we are working on, so I went inside just to check the house out. In my looking arround i noticed his trim work.He put 34 nails in one piece of trim along the side of an interior door. I'm glad i'm not a painter.
Bigbricklayer is offline
Old 09-21-2006, 07:51 PM   #17
i hate when i walk up to a house that someone has spent a bunch of money on to restore and the hack jackleg painted over peeling paint, and used caulk for window glazing.
Old 09-21-2006, 08:20 PM   #18
theworx's Avatar
Walking into a new $300,000.00 home (high end up here) and having the bad taping just jump out at you. Also makes for a bad paint job without nice sharp clean and straight corners (especially at the ceiling). Pisses me off because those shotty tapers make way more money than I do and I do a better job...
theworx is offline
Old 09-21-2006, 09:00 PM   #19
contractor
cmwacasey's Avatar
Trade: carpentry plumbing electric
poor attic ventilation in southern homes.do not know much about northen homes with the snow and all.
cmwacasey is offline
Old 09-21-2006, 09:17 PM   #20
Dave-Raleigh's Avatar
Trade: Residential remodelling
Drywall taping that telegraphs through popcorn ceilings
OSB/Plywood 4' edges telegraphing through roofing shingles
Roofing shingles layed in brick pattern rather than stair stepped
Wavy vinyl exterior walls because of sloppy framing amd/or vinyl installation
Crooked/loose electrical switches/receptacles
Dirt imbedded in spray painted baseboards
Wavy chair rail because walls are wavy
Door latch plates that don't match factory routed recesses
Wall paint touchup where you can see exactly where the touchup was done
Dave-Raleigh is offline
Self employed guy needs some advice from the Pros to keep things straight... Luny Landscaping 14 05-27-2007 12:38 PM
Things You Never Knew Your Cell Phone Could Do Tried Them Out Ron The Plumber Off Topic (Non Trade) 19 03-14-2007 04:39 PM
Are Things Changing denick Excavation & Site Work 2 08-21-2006 06:04 AM
April 15th How Are Things denick Excavation & Site Work 12 04-16-2006 04:13 PM
List of reasons that people buy things Paul Burns Painting & Finish Work 9 01-20-2006 12:40 AM
