Tearing Up Tile For My Folks (TILE GUYS PLEASE HELP!)- Opinions Please
Old 11-19-2009, 06:21 AM   #1
tuffplay's Avatar
Trade: Playground Design and Construction
Alright guys quick Q and A:
1. The folks are super cheapos; although they have money.
2. I did a HUGE paving job for them around thier pool; quote from local contractor was 30K. I did it for less than 7k, made 0 dollars - just to be nice, it was NOT appreciated.
3. They are remodeling their kitchen and have about 1100sq feet of new tile to go down.
Currently they are debating the following:
1. should they tear out the old tile, or put new tile on top?
Quote for removal is about 2600.00. I told them I would do it for them for 1000.00. I am wondering this:
There is a lot of thin set underneath the tile, I tested a small area and its not coming up with the tile. IF i rip the tile out, I am going to have to use a floor grinder to smooth everything out:
1. HAS ANYONE USED THESE - HOW WELL/FAST DO THEY WORK?
2. DO YOU THINK I SHOULD EVEN BOTHER TRYING TO HELP THEM?
3. CAN I GET THE THIN SET PRETTY SMOOTH AND LOWER IT SO THEY CAN JUST FLOAT THICKER THIN SET ON TOP?
TIME IS OF THE ESSENCE - NEED TO START OR TELL THEM NO ASAP.
ONE GUY SAID HE COULD DRILL HOLES IN THE TILE AND THEN THIN SET ON TOP, ANOTHER GUY SAID HE COULD USE EPOXY BASE AND GO RIGHT OVER THE TOP, ANOTHER GUY SAID THEY ARE IDIOTS, TEAR OUT THE TILE.
A SIDE NOT: THE NEW TILE IS ACTUALLY STONE; TRAVER-TINE.
PaulAndSon
tuffplay is offline
Old 11-19-2009, 06:33 AM   #2
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Re: Tearing Up Tile For My Folks (TILE GUYS PLEASE HELP!)- Opinions Please
Just run away
chris n is offline
Old 11-19-2009, 07:31 AM   #3
tuffplay's Avatar
Unfortunately that is not really an option - how hard would this be seriously? I can post pics if needed.
PaulAndSon
tuffplay is offline
Old 11-19-2009, 07:31 AM   #4
mattp's Avatar
Trade: roofing
TEAR OUT THE TILE. Make sure who ever does the job to tear it out.
mattp is offline
Old 11-19-2009, 07:34 AM   #5
tuffplay's Avatar
I wanted to take the tile out myself to save them some cash and make a little money for myself as business has been slow. I just want to know if the floor grinder will work "quickly" on lowering the thin set......
PaulAndSon
tuffplay is offline
Old 11-19-2009, 08:09 AM   #6
Sean
SLSTech's Avatar
Tear out the tile is the correct answer - the sub floor is???
SLSTech is offline
Old 11-19-2009, 08:12 AM   #7
Remodeling GC
kevjob's Avatar
look into a small chiiping hammer with a wide chisel bit for thinset removal, you have to check for deflection, sub-fllor material, joist size, span spacing etc...
kevjob is offline
Old 11-19-2009, 08:12 AM   #8
bathroom guru
jarvis design's Avatar
Definately rip up the tile - do not go over existing tile.
A floor grinder will definately help
I might have missed it, but, what is under the tile- framed/subfloor or concrete??
If your folks are putting down stone do they realize (and this is if it is framed) that they need double the "strength" for their stone floor?
Working for family sucks!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 11-19-2009, 08:44 AM   #9
ARI001's Avatar
Don't work for family. If I do work for family or friends I always make it clear that I am just lending a hand and expect no compensation other than food and drink while I am there. Working for family and friends usually causes hard feelings if you do so in a business like manner as they expect you to do twice as much for a fraction of what you should be charging. If you want to help your parents save money then do so, but don't try to have a business relationship with them. When helping my parents with projects I look at it like this: They put way more into raising me emotionally and monetarily then anyone could ever put a price tag on. I owe it to them to help them now that they are older and not as able to do things.
That said, I make sure my parents understand that I have a business to run and that paying work must come first at all times in order to provide for my family. They also understand I will only be there on down time (week ends, holidays, time between projects) and that it is going to be just me or possibly a friend and myself, not employees and/or subcontractors.
As far as the tile removal goes tear it all out. Make sure the existing floor joists meet the required deflection rate and beef them up if they don't. Good luck.
ARI001 is offline
The Following 3 Users Say Thank You to ARI001 For This Useful Post:
abacab (11-19-2009), fairfaxgc (11-20-2009), Willie T (11-19-2009)
Old 11-19-2009, 08:50 AM   #10
BCConstruction's Avatar
Trade: Construction
Couldn't have been more spot on. I done some work for my bro in law which took over 3 months and he wanted me to do it for 1/4th what i would normally charge. Then a big family argument erupted and kicked of big time.
BCConstruction is online now
Old 11-19-2009, 09:41 AM   #11
tuffplay's Avatar
Okay sorry I left this out:
Existing Tile is coated ceramic about 25 yr old and in decent shape.
Sub surface is concrete ( foundation)
1. Do they need to tear out the tile to install the stone or can they install on top of the tile? Why?
2. Whats the going rate for tile removal and thin set removal? (what would you charge to tear it up and haul it off - 1100 sq/ft
3. Anything special to keep in mind when installing stone instead of regular tile - aside from sealing? -
Thanks
Paul
PaulAndSon
tuffplay is offline
Old 11-19-2009, 09:53 AM   #12
Pompass Ass
bwalley's Avatar
I think you mean the subfloor is concrete.
The Tile needs to come out and all loose thinset up, the floor does not need to be completely free of all thinset, do not grind the floor as it is not needed and a big mess.
$3.50 a ft2
Hire someone who knows what they are doing
Thanks
Paul
Based on your previous post about doing work for them, i would avoid it like the plague.
bwalley is offline
The Following User Says Thank You to bwalley For This Useful Post:
tuffplay (11-19-2009)
Old 11-19-2009, 09:59 AM   #13
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Charging labor to the people who raised you, and paid for everything from the day you were born?
I see your company is "Paul & Son". Learn how to spell Karma now, because in a few decades you just may be meeting it, face-to-face.
If you cannot afford to buy the material for them, that's one thing. But to charge for a little time and sweat?
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is online now
The Following 2 Users Say Thank You to Willie T For This Useful Post:
bwalley (11-19-2009), dkillianjr (11-20-2009)
Old 11-19-2009, 10:04 AM   #14
Inner10's Avatar
Trade: Control Systems
From what I found:
Friends expect you to work for cheap.....
Family expects you to work for free.
If I help my family or they help me a dollar never comes out of pocket except for buying the beer, coffee and pizza.
Inner10 is online now
Old 11-19-2009, 10:08 AM   #15
Linear Shower Drains
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
The best way to remove those tiles is with a little demo hammer. I like to start by vibrating the tops of the tile in as small section maybe 4' x 4'. Just try and vibrate and crack the tops don't dig into the tile. Then go back and hit the edge at about 30 degree angle and the tiles should start popping off. The vibrating first helps with the removal and helps bring up more thin set with the tile.
Travertine is softer than the ceramic you have now and some kind of anti fracture material should be used in the new install.
Lots of on John Bridges web site for this same question.
Good Luck
John Whipple (By Any Design Ltd.) - Member of Terrazzo Tile and Marble Association of Canada, the National Kitchen & Bath Association and the National Tile Contractors Association. Specializing in Vancouver bathroom renovations, linear shower drain installations and shower waterproofing procedures.
JohnFRWhipple is online now
Old 11-19-2009, 10:12 AM   #16
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Can afford the work but expect you to do it for free? Can anyone say HACK?!? Thank you. Disown your family.
Cdat is offline
The Following User Says Thank You to Cdat For This Useful Post:
Old 11-19-2009, 11:11 AM   #17
Chris G's Avatar
Trade: Porch and Deck Builder
They had the balls to get quotes?
Disown them.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
The Following User Says Thank You to Chris G For This Useful Post:
Old 11-19-2009, 12:09 PM   #18
Its all ball bearings
angus242's Avatar
Trade: Tile
tuffplay,
Aside from the obvious family issues here are a few things to watch for.
You said original installation of 25+ years old. Are you sure that's thinset under the tiles and not a mastic? If it's mastic, it must be removed.
For removal pricing () I'd guess around 12-14 man hours to remove just the tile without being able to see what needs to be done. Multiply that number by what you feel is a fair hourly wage. In my area $300 for debris haul.
As already stated, if the old thinset is removed, it will be a very dirty job. That would also more than double the hours for demo.
What I'd do is remove everything and start clean. Install Ditra (or equivalent membrane). Install stone.
If old adhesive is, in fact, thinset and it's not fully removed, I'd consider using a SLC to smooth out the surface. If not, with installing the stone you're looking at coverage issues and good luck getting someone to be able to keep lippage to a minimum!
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
MAD Renovations (11-22-2009)
Old 11-19-2009, 11:04 PM   #19
Dan V.'s Avatar
Trade: Home Improvement/Remodeling
Yep, what he said, especially about the lippage.
You may want to consider using an air chisel to get that old tile out. I sure as hell wouldn't want to tear out 1100 sq. ft. by hand. After it's up, check subfloor condition (cracks, level, moisture, etc.) and remediate. An SLC is a definite consideration, especially if you're going with large format tile (12" x 12" and larger).
Unless you have a good wet saw and have set tile in the past, I'd hire a pro. That whole situation sounds like a nightmare about to happen.
I spent most of my money on booze and women. The rest I just wasted.
www.forwardsolutions.net
Dan V. is offline
Old 11-19-2009, 11:10 PM   #20
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Send a message via AIM to WilsonRMDL
get a nice chipping hammer and have at it. Wide chisels work great, I think bosch makes a wide blade chisel specifically for removing tile, works good on old thinset too.
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Bathroom Tile Application jkcustmcarpntry Flooring 15 05-30-2009 09:44 AM
Tile over Tile fireguy Flooring 3 02-26-2009 11:36 PM
Time for a new tile guy? orson Ceramic & Stone Tile 20 12-11-2008 08:38 PM
Laying new ceramic tile on wall faromic80 Ceramic & Stone Tile 4 09-17-2008 08:01 AM
How to tile a Deck with Patio under it? JBowman Carpentry 9 09-15-2008 08:23 PM
