Tape All Drywall Seams Before Ceramic Tile Install?
Old 08-22-2007, 08:39 PM   #1
zmusashi's Avatar
Trade: carpentry, remodeling
I just hung my sheetrock in this bathroom remodel (dry areas) and am about to start laying ceramic tile on it-- is is necessary or recommended to tape all the joints? I have used mesh tape in the past with one or two quick coats of compound to fill in the voids created by the cove edges. I imagine taping the corners might make the room stronger, but is it necessary? Is any taping really necessary before tiling?
Thanks a lot
zmusashi is offline
Old 08-22-2007, 11:40 PM   #2
Veteran Boss
fiore22's Avatar
Re: Tape All Drywall Seams Before Ceramic Tile Install?
Always tape. For many reasons, one being moisture will find its way through those cracks over time and get behind your tile. Yes, it makes it stronger. It will also make your wall smoother for the tile and lessen the chance of a unsightly valley in your tile pattern, especially with a mosaic tile. You also want to prime the plaster, better surface adhesion for the mastic/adhesive.
I could've leased a new Ferrari, but I thought the chicks would dig my workers comp and GL insurance more
fiore22 is offline
Old 08-24-2007, 07:18 AM   #3
bonny scotland's Avatar
Trade: CARPENTER/JOINER
Location: SCOTLAND(UK) halfway between Glasgow and Edinburgh in a place called Bathgate
Thanks a lot
yes you should always tape in tiled areas , to many tapers get of with doing it but it needs to be done
bonny scotland is offline
Old 08-24-2007, 09:04 PM   #4
zmusashi's Avatar
Thanks guys
zmusashi is offline
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
tape all drywall seams before ceramic tile install? zmusashi Drywall 4 08-23-2007 12:23 PM
ceramic tile pre-reno Flooring 10 02-04-2007 04:15 PM
outdoor tile install southcoastbuild Flooring 3 01-09-2006 11:03 AM
