Stucco Underlayment
Old 02-10-2008, 03:14 PM   #1
dannywild's Avatar
Trade: Project Manager
Stucco Underlayment
I have a stucco crew in on a project and they are placing stucco on the outside of a finished walk-out basement. They have placed an underlayment of #30 felt paper on top of the existing Tyvek that hangs down from the above floor. I think this is wrong but they say it will be fine and that is how they do things. If any wind driven rain gets behind the siding it will flow behind their felt and then have no-where to go except up against the house. Am I missing something or shouldnt the felt be tucked under and overlapped by the Tyvek?
dannywild is offline
Old 02-10-2008, 08:34 PM   #2
Custom Builder
Custom Builder's Avatar
Trade: Custom home builder
Rewards Points: 79
Re: Stucco Underlayment
With a proper caulk job along with the pieces of tape between butt joints of the siding (provided you are using Hardi) you should not have any penetration. If you do it sould flow between the existing Tyvek and felt. Why are you not using Tyvek Stucco Wrap under the felt?
Custom Builder is offline
Old 02-10-2008, 08:39 PM   #3
Tscarborough's Avatar
Rewards Points: 1,392
Any time that there is a change of material or plane, the upper should lap the lower, no exceptions.
Tscarborough is offline
Old 02-10-2008, 09:48 PM   #4
philner's Avatar
Trade: remodeling contractor, SE Mass.
Rewards Points: 160
If the upper siding is vinyl the tyvek should lap onto a dripcap flashing above the stucco to keep water from getting between the 30# felt and stucco(or behind the felt the way it is now). Phil
philner is offline
Old 02-12-2008, 07:42 PM   #5
troubleseeker's Avatar
Not quite sure if your concern is about the proper layering of the materials or the use of the felt over the Tyvek.
As stated by others, ALL layers of any underlayerment or flashing should always be lapped from top to bottom, so that water is always shedded over the next piece in the direction of flow.
If you are worried about using the felt over the Tyvek, it is fine. You actually have a stucco crew that understands that the stucco is suppossed to have a bond breaker (in this case, the felt) to prevent the scratch coat from being in direct contact with and adhereing to the building wrap.
troubleseeker is offline
Old 03-31-2014, 05:10 PM   #6
CarpenterSFO's Avatar
Rewards Points: 2,044
Quote from Dupont installation instructions for all of its Tyvek products:
"When DuPontTM TyvekŪ water-resistive barriers are used behind stucco they should be separated from the stucco by a second layer of DuPontTM TyvekŪ WRB, a layer of Grade D building paper, felt, rigid foam board or the paper backing of paper-backed lath."
Yes, I know that it's an old thread, and other original post was on the shingling of layers. Here in early 2014 it's still a top search result for tyvek stucco wrap, so I thought I'd add the note.
- Bob
CarpenterSFO is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 08:09 AM
Rubber membrane behind ledger on stucco? Woodcrafter74 Decks & Fencing 6 01-31-2006 08:27 PM
repairing stucco ceilings and cracks Zeebo Painting & Finish Work 10 12-21-2005 06:43 PM
