Steel Sheets For Garage
Old 09-07-2007, 10:25 PM   #1
plazaman's Avatar
I have an old 2 car garage at my city home that needs update. The entire building is frames with Angle irons with steel sheathing. Its time to update and i want to replace the sheets alone. Can i do that? The framing is in ecellent condition, not even rust. Is it possible to purchase steel sheets alone?
Sorry if this seems like a dumb questions, but my steel knowledge is very limited.
plazaman is offline
Old 09-07-2007, 11:37 PM   #2
Dustball's Avatar
Re: Steel Sheets For Garage
Are you talking about corrugated metal panels?
Dustball is offline
Old 09-08-2007, 12:17 AM   #3
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
I have a one car garage that sounds like what your talking about. If its the same as mine then the sheeting is rotted in some spots. Menards has corrugated steel paneling on sale this week, around $1.75 a linft.
Michaeljp86 is offline
Old 09-08-2007, 07:41 AM   #4
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
you can replace the sheets, but make sure you use the same gauge, or thicker. I would try to find the original manufacturer if possible, to maintain wind/snow load ratings, and to get all the matching trim and gutter parts.
Install with tappers that have an "O"-ring, and be very careful on the roof, it is very slippery when wet. Pay extra to have the sheets pre-cut to length by the manufacturer, and dont forget new insulation. Wear gloves, and dont work on windy days.
Pearce Services is offline
Old 12-09-2008, 06:30 AM   #5
steelfabric's Avatar
Trade: 265
Hi,
AceCad Software is unique in the steel industry for its range of advanced software systems. You can know more information from deleted advertising.
Last edited by joasis; 12-09-2008 at 08:25 AM. Reason: Please read the rules of the site
steelfabric is offline
Old 12-09-2008, 08:27 AM   #6
joasis's Avatar
Do a search for "steel buildings" and your area, and you should find a manufacturer close. The industry standard is 3 feet wide by infinite length, meaning they roll this at their plant. 26 gauge is pretty standard as well, and due to the tensile strength, will work in nearly every application....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 11:33 AM
AISC Steel Pipe Column on Conc. Curb Wall Atlantex Welding & Steel Trades 0 08-20-2007 04:59 PM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
steel door problem wmerrell Commercial Construction 12 03-24-2007 04:04 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
