Steel Roofing
Old 01-10-2017, 04:35 PM   #1
freemanroofer's Avatar
Trade: roofing
Rewards Points: 4
Steel Roofing
We mainly do architectural shingles, epdm, tpo and some stone coated steel. I have been getting quite a bit of pole barn steel request but don't know how to price it for a smaller city in the midwest. Can someone push me in the right direction to as pricing it for quotes? thanks!
freemanroofer is offline
Old 01-10-2017, 05:09 PM   #2
FrankSmith's Avatar
Rewards Points: 4,490
Re: Steel Roofing
As you don't know what your time is worth or you don't know how to install the product?
FrankSmith is online now
Old 01-10-2017, 05:19 PM   #3
Trade: roofing
Rewards Points: 4
Re: Steel Roofing
I have guys that can do it but we use a xactimate software that has pricing on material but it seems very on the expensive side. So more a material pricing. Thanks
Old 01-10-2017, 05:41 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 864
Re: Steel Roofing
Out right asking pricing here is not looked on very highly. Cost of material - you need to talk to your supplier and add your markup, only way you will know your cost. . Cost where you live and I live can be different.
Randy Bush is offline
Old 01-10-2017, 06:24 PM   #5
FrankSmith's Avatar
Re: Steel Roofing
I would send your material list with a note that says "Request for Pricing" to a few of your suppliers.
$130 a square for steel with exposed fastens and accessories should get you close on a normal house. Less on an easy gable roof. More on a cut up roof.
Old 01-10-2017, 06:32 PM   #6
Randy Bush's Avatar
Rewards Points: 864
Re: Steel Roofing
I normally like to allow a little more then that. But it is still right in the ball park.
The Following User Says Thank You to Randy Bush For This Useful Post:
FrankSmith (01-10-2017)
Old 01-10-2017, 06:34 PM   #7
FrankSmith's Avatar
Re: Steel Roofing
I order steel through Menards. I think they are considerably less than from a lumber yard.
The Following User Says Thank You to FrankSmith For This Useful Post:
Randy Bush (01-10-2017)
Old 01-11-2017, 12:08 AM   #8
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 270
Re: Steel Roofing
We do quite a bit of metal roofs and try to stay away from asphalt. It's pretty common here on houses. When I bid em it usually isn't that much more than shingles because I drop the labor since they go so quick, with the exception of chopped up roofs. I'm usually around 150 square for material, covers titanium wrap, metal, trim, screws, em seal, and ridge closure. That's also based on tuf rib (local store) / delta rib, the standard stuff, corrugated and standing seam cost a lot more.
Professional wood welder
51carpenter is offline
The Following User Says Thank You to 51carpenter For This Useful Post:
Randy Bush (01-11-2017)
Old 01-11-2017, 08:07 AM   #9
Trade: roofing
Rewards Points: 4
Re: Steel Roofing
Thank you guys I really appreciate it!
Steel roofing low slope jeradlittle Roofing 15 01-22-2013 09:03 AM
Roofing new construction LeeFowler Roofing 20 12-20-2012 06:50 PM
Steel Tubing Lintel Strength 6stringmason Masonry 16 10-04-2012 09:12 PM
Painted steel roofing PA woodbutcher Roofing 8 08-06-2009 05:25 PM
