Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 08-14-2007, 02:37 PM   #1
Trade: Fontains
Special tool for lifting needed
Hello, Our company needs a tool to lift boulders that have had a hole bored thru them vertically to make water fountains. Some boulders might weigh as much as 3 tons. We need a tool that will go down the bore hole and then be used to lift. The bore hole would be one inch in diameter. Please educate me as the best way to do this. thanks in advance.
Versatile is offline   Reply With Quote
Old 08-14-2007, 02:48 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Construction
I can see several ways of getting this done, but they all will be custom solutions, which will cost $$$.
What is your budget?
Midtown Tulsa Remodeling
Cole is offline   Reply With Quote
Old 08-14-2007, 02:57 PM   #3
Trade: Fontains
You scare me when you mention budget. Will be glad to pay a fair price.
I was assuming that a tool like this shouldn't cost over a couple hundred. Please give me the education.
Old 08-14-2007, 02:58 PM   #4
Trade: General Contractor, Remodeler
What about an old school bike handle bar nut? You put it in the hole, tighten the nut and it locks in firm... I wouldn't stand under the boulder, but it might work.
Forry is offline   Reply With Quote
Old 08-14-2007, 02:58 PM   #5
RYANINMICHIGAN's Avatar
Trade: builder of stuff, real nice stuff
buy alot of 4 inch snachems and lots of chains
RYANINMICHIGAN is offline   Reply With Quote
Old 08-14-2007, 03:02 PM   #6
Trade: Fontains
That is kinda like what i am thinking. A cable goes down the hole and then lifts up two tapered pieces and then binds in the hole. Does something like this exist?
Old 08-14-2007, 03:04 PM   #7
Trade: Decks
The cheapest easiest way I can think of doing it is getting a 3ton engine hoist. They cost around $500 and don't take much to move. The only issue might be rolling around those type of wheels on grass.
zukkoor is offline   Reply With Quote
Old 08-14-2007, 03:13 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Trade: Popcorn Vendor
Why not get a box of Hilti 3/4" drop in anchors, a 3/4" eyebolt, and set up an electric hoist on a tripod over the hole?
KillerToiletSpider is offline   Reply With Quote
Old 08-14-2007, 03:16 PM   #9
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Seems to me you could use a rubber plug to lift these.
The plug would be almost the size of the hole in diameter and probably 3-4 inches tall, the bottom of the plug would be bored out in a cylinder shape with the thinner part of the cylinder shape at the top, probably the bottom 1 1/2 inches of the plug.
Through the plug you would pass a thick braided metal wire and it would connect to a piece of metal in the shape to fit in that bored out shape at the bottom of the plug, but a bit bigger.
When you pull up on this braided wire it would pull the metal plug up into the bottom of the rubber plug and make the rubber plug bigger and hold in place. As long as there was gravity and pressuer pulling down on the stone it would keep the rubber plug in place.
The is basically the same idea as using gravity as the clamping force used on the grippers they use to move granite slabs around a granite yard.
Seems like if this isn't available a machine shop could make them for you.
bathroom remodeling - Denver, Lakewood, Littleton, Arvada, Westminster, Centennial, Highlands Ranch, Lone Tree, Englewood Colorado.
Originally Posted by Ahren View Post
Citibank BK Jan 2010, Dow 3000 Q1 2010,FAZ is about to go through the roof, stagflation, hyper-inflation, Jan 2010 $2.00 C puts
Mike Finley is offline   Reply With Quote
Old 08-14-2007, 03:19 PM   #10
Trade: Residential GC
do you have heavy equipment? is this a one time project?
http://www.rockjaw.com/
I don't know the key to success, but the key to failure is trying to please everybody.
Bill Cosby (1937 - )
GreenW00D is offline   Reply With Quote
Old 08-14-2007, 04:06 PM   #11
Trade: Fontains
Taleked to Hilti and they have a product that should work.
I like Mike Finleys idea real well. We will be moving constantly and need to reuse the lifter.
Yes we have acess to heavy equipment.
Can anyone recommened a supplier for the graite industry?
Thanks for all the quick replies.
Old 08-14-2007, 04:24 PM   #12
tgeb's Avatar
there are skid loader attachments that will do what you are wanting to do.
http://buyattachmentsdirect.com/atta...grab/index.cfm
That is only one option.
http://www.skid-steer-attachments.ne...ting_forks.htm
Here is another.
http://bobcat.com/attachments/tree_fork
Or this.
There are dozens of different things you can get that would be safer than experimenting with something homemade.
Not that I am opposed to home made solutions, but playing trail and error with boulders could be painful.
www.gebcon.com
tgeb is offline   Reply With Quote
Old 08-14-2007, 04:51 PM   #13
Trade: contractor
if access allows ... a backhoe??
anytime i gotta do waterfeatures with immovable objects (i.e. boulders) ... take two straps and two guys.
haven't done anything heavy as 3 tons though
dirt diggler is offline   Reply With Quote
Old 08-14-2007, 04:59 PM   #14
jmic's Avatar
Here is another.
Or this.
3 tons lifted by a skid steer ?
Joe
jmic is offline   Reply With Quote
Old 08-14-2007, 05:03 PM   #15
Trade: HVAC Contractor/ General Contractor
You say you have access to heavy equipment, how about this.
Diesel65 is offline   Reply With Quote
Old 08-14-2007, 06:36 PM   #16
Palisade Point Const.
TempestV's Avatar
once you set the bolder down, do you have access to the bottom of the bolder? if so, a rod could be bolted through, with some kind of eyelet on the top to hook to.
What kind of heavy equipment do you have access too?
if it's a crane, I am with diesel on this one.
Most telihandler type forklifts could lift three tons, and it is possible to get a grabber similar to what Tgeb was recommending, but for a forklift. such attachments are also available for front end loaders and I believe excavators. other than that, I can't think of any heavy equipment capable of lifting 3 tons.
TempestV is offline   Reply With Quote
Old 08-14-2007, 06:47 PM   #17
tgeb's Avatar
Oops, I missed that part in the original post.
Even the biggest skidsteers are only good to about 1/2 that.
The fork lift option sounds good.
www.gebcon.com
Old 08-14-2007, 10:21 PM   #18
What I had in mind when you said 1" hole bored vertically was an expanding mandrel/air shaft. See this link for examples- http://www.doubleeusa.com/core_shafts.htm
I don't know if 1" dia versions are available- the ones I've used in the past were 4" dia shafts.
Dustball is offline   Reply With Quote
Old 08-14-2007, 11:03 PM   #19
DRIFTWOOD
Trade: GEN CONTR.
Thumbs up E Z Beans
A wire choker with loop. Run it through hole , place a 5/8" short re bar through eye on the underside of boulder. Please send $100.00 within 10 days
Driftwood is offline   Reply With Quote
Old 08-15-2007, 09:36 AM   #20
Trade: Fontains
Thanks for all the ideas. A good education real quick.
Driftwood! Your check is in the mail.
TBA Meeting (Tool Buyers Anonymous) DecksEtc Tools & Equipment 123 03-02-2010 01:04 AM
Trailer: Customizing ideas needed. Long Robie Vehicles 130 02-22-2010 09:30 PM
The tool repair called me after 2 years nywoodwizard Tools & Equipment 3 05-21-2007 02:37 AM
FEEDBACK: Online Survey Tool Nathan Off Topic (Non Trade) 9 08-29-2006 05:20 PM
PVC Pipe Tool Box denick Excavation & Site Work 35 04-25-2006 05:35 AM
