Skylight Ruined?
Old 11-17-2008, 09:40 PM   #1
go do it's Avatar
Trade: general contracting
Skylight Ruined?
my stucco contractor got a bunch of stucco and color coat on a custom
built skylight, on the aluminum frame.
so while i was gone he trys to clean it off with macuric acid!!!
the aluminum frame finish now looks like general motors balance sheet
in other works it looks like sheet!!
this skylight cost $1,575.00
how can i fix the frame?
polish? paint?
thanks
go do it is offline
Old 11-17-2008, 09:57 PM   #2
SCFoxman's Avatar
Trade: Trim
Re: Skylight Ruined?
Eek!
If it's not a fixed frame, you could get it buffed and anodized. Only thing I can think of after the muri was used.
What kind of finish was on the aluminum? What exactly was the result of the muri on it. Did it just leave black streaks on it? How bout hitting it with a buffing/polishing wheel to get a plain brushed finish?
SCFoxman is offline
Old 11-17-2008, 10:19 PM   #3
j_builder's Avatar
Trade: Specializing in residential remodeling
I had my painters completely paint my skylight frames to match my pella windows...you'd never know the deference. Don't forget to back charge for your time.
http://www.myperfectcolor.com/Popula...r-com-s/13.htm
j_builder is offline
Old 11-18-2008, 02:24 AM   #4
genecarp's Avatar
Nice home J, that is a good link, MYPERFECTCOLOR, do you use it often ? how, exactly is it usefull ?. thanx, G
genecarp is offline
Old 11-18-2008, 07:38 PM   #5
go do it's Avatar
well the finish looks all streaked and matted.
no pits or gouges but it looks like someone poured milk on it and it flash dryed
i haven't done anything to it yet but polishing may be the thing to do.
go do it is offline
Old 11-18-2008, 10:09 PM   #6
Bleed's Avatar
Trade: Residential remodeling
Just buff the crap outta it. Something similar has happened to me few years back (also with Pella windows) when my "experienced" painter sprayed the stain on the aluminum frame. You just have to buff it out. The only problem is....it takes some time to get it done. This article can help out a bit as well, http://www.pfonline.com/articles/069801.html. Good luck
Bleed is offline
Old 11-18-2008, 11:01 PM   #7
j_builder's Avatar
Originally Posted by genecarp View Post
Nice home J, that is a good link, MYPERFECTCOLOR, do you use it often ? Just used them once to date for the project you see above how, exactly is it usefull ? They shipped out my order the next day. thanx, G
Thanks G for the comment, that rebuild project was a true challenge in so many ways
go do it
Why buff? Just hit the skylight frame with some 000 fine steelwool,acetone,mask off,prime,paint...done deal
Putting in a skylight Easy_rhyno Remodeling 9 06-21-2008 02:44 PM
Skylight in corrugated metal roof bob_cntrctr Roofing 5 04-30-2008 12:47 AM
What is the lowest pitch roof everyone is comfortable with putting in a skylight? mikeybobo Roofing 10 03-03-2007 11:34 AM
old skylight on flat roof wayne3434 Construction 1 02-12-2007 07:00 PM
Skylight leaking jason97z28 Roofing 6 01-02-2007 09:03 PM
