Mod / ArchiBuilder
SIP Panels
Guys, can you build your own SIP panels?
I know I can order them but I want to build them. What kind of equipment would I need? I am thinking it wont be worth the trouble but hey I probably would learn something new.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Bah Humbug!
Re: SIP Panels
You can build them. SIP is a structuraly insulated panel. It's basically plywood sandwiched between some kind of insulation.
Buy 2 sheets of plywood, 1 sheet of polyiso rigid insulation board and some insulation adhesive. Another option would to actually build a frame and buy an insulation spray rig. There are tons of types of insulations. Many roofers spray on SPF which has a good isulation value, however I would see what types of insulation most SIP manufacturers use and look into that spray equipment. Note: A portable SPF rig costs about $100,000. Plus maintenance which requires immediate clean up after use. |
Mod / ArchiBuilder
Re: SIP Panels
Grumpy, good info.
From what I have seen most SIP manufacturers use a thick piece of insulation board. I wonder where I can find some at.
Custom Builder
Re: SIP Panels
Cole they press the skins on with an industrial vacuum system. I'm not sure what type adhesives they use.
Also something to think about: Some SIP manufactures can't sell in certain areas of the country. Engineering requirements and such. Bob
Bob |
Mod / ArchiBuilder
Re: SIP Panels
Good info, Bob.
I can already tell this might not be a smart idea, after all. I would love to experiment with building my own, but its not looking good.
#6 | |
DGFVT
Trade: Electrical
Re: SIP PanelsQuote:
The general idea is to make a panel and then fill it with foam. Interesting idea. http://www.chemicalonline.com/conten...&VNETCOOKIE=NO http://www.instapak.com/products/pro.../instapak.html |
jack of all, master of 1
Trade: carpenter/roofer
Re: SIP Panels
And be sure to get the right spray adhesive. Your regular 3m deteriorates the foam panel. Just something I learned when building a speaker box back in the day.
Re: SIP Panels
I don't know, but here's my input anyhow...
When you come to wiring a SIP house, choose an electrician who's never wired one before. If you pick one that has ever delt with them before, the bid will be high. I've wired two in my career. I promised myself that my next bid for one will be about 1 million dollars. I hate them. A close second on the frustration scale is log homes.
#9 | |
Trade: carpentry/ self employed master craftsman
this is a topic that has a lot of varied answers...yes you can build and use sips if you are using them as a curtain wall (non structural aplication)hanging them on a timber frame, other wise as in a structural application the panels need to have an engineers stamp on them to meet code requirements. check out this link look for the search button and type in homemade sips www.sipweb.com .. I also have some links for manufacturers of panel presses and so on if your interested. stay curious, Dan
"what ever it takes" |
| Share your techniques for access panels in finished ceilings and walls | Dustball | Carpentry | 9 | 07-14-2007 08:27 PM |
| I goofed- how do I remove solder from wall panels? | Dustball | Plumbing | 12 | 05-04-2007 10:40 AM |
| stone panels | rservices | Masonry | 10 | 03-31-2007 05:28 PM |
| Solar Panels | clueless in CT | Electrical | 1 | 11-23-2006 09:41 AM |
| How many Breaker Panels can I have | robertc65 | Electrical | 6 | 02-10-2006 05:13 PM |
