Silicone Caulking Won't Cure?!?
Old 01-15-2010, 09:52 PM   #1
bob_cntrctr's Avatar
Trade: property manager & renovator
Gentlemen,
Never seen this before. Finished a bathroom about a week ago - left the original (porcelain on steel) bath tub in and tiled the bath and floor. Three days after grouting, applied GE Silicone II around the tub. I was in there today and happened to touch the caulking along the floor at the foot of the bathtub - it's still soft! No, I dont mean flexible - I mean my finger smuched into it - it's like the day I put it down. Oh, maybe it's a bit set up underneath, but I was able to run my finger over it to smooth out where I had smushed it. The caulking everywere else, all around where the tiles meet the tub, is perfectly cured. Just along the base at the floor is un-cured.
The house is empty, the rest of the house undergoing more renos, so the bath has not been used - it's not been wet.
Now, it took a few tubes of caulkig to do the whole room, so maybe this was a funky tube of caulking?
Anyone ever seen silicone that won't cure?
Thanks.
bob_cntrctr is offline
Old 01-15-2010, 09:57 PM   #2
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Silicone Caulking Won't Cure?!?
There was a post about this very problem about a month ago. Poster said the caulk was way past the expiration date.
I've always been afraid to use silicone that has been frozen. I hope that this helped.--MIKE--
mikeswoods is offline
Old 01-16-2010, 07:30 PM   #3
Ya, that prompted me to search this:
http://fixithouse.blogspot.com/2009/...k-warning.html
A warning about silicone caulking beyond its expiry date, and even some people complaining of the problem before expiry. Never had it happen before, personally> Of course the tubes went out in the dumpster a week ago, so no way of knowing, but... live 'n learn.
Old 01-16-2010, 07:39 PM   #4
Lack Of All Trades
Darwin's Avatar
Trade: Construction & Home Improvement Services
It's not 100% silicone. I've made the mistake -- too -- of buying the stuff that says silicone and find out that it is not 100% silicone. I did a whole house with this stuff (12 windows + ) and after 3 hours, it still wasn't dry. Plus, it rained shortly thereafter.
Darwin is offline
Old 01-16-2010, 09:19 PM   #5
MarcD's Avatar
Trade: Making Everyone Happy
Rewards Points: 75
I had a box of Dap Alex black that was bad would never cure. We went through three or four tubes and on the next one it started to come out in the consistency of tomato soup. Then the next day and couple there after we realized the whole box had a problem as the caulk we had applied stayed squishy and never cured. Was horrible we ended up having to touchup paint four bathrooms and Dap said we should have sample tested the caulk before we used it ?????????????????
MarcD is offline
Old 01-17-2010, 09:14 AM   #6
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 228
Freezing, and excessive heat will destroy silicone. I have to throw out a dozen tubes every year that cook in my trailer during the summer. I always forget to take them out at the end of the day.
Just an observation- Silicone that has been frozen tends to look normal when you're laying a bead of it... Silicone that has seen excessive heat has a curdled appearance, a bit like cottage cheese. That's a telltale sign to throw it out and buy a new tube.
Splinter is online now
Old 04-16-2011, 12:51 PM   #7
StPete727's Avatar
Rewards Points: 18
I know this is an old post but just for learning purposes I agree here. Had this problem with GE I silicone (FYI GE II is still "real" silicone only has a fungicide agent in it) Anyway I spoke with Chemist at GE and she notified me of that same thing as above quote and some tips. Bottom line with Silicone I or II is to use fresh tubes. If you must store it, try and air-conditioned space and when you cut the tube, if you don't smell the acetic acid (vinegar smell) then it's no good.
StPete727 is offline
Old 04-16-2011, 01:03 PM   #8
3bar's Avatar
Trade: carpenter
Rewards Points: 460
i had the same issue before. bought some silicone at lowes, and later realized it was expired.
3bar is offline
Why does concrete cure white and portland cement cure grey? jgray152 Masonry 44 01-27-2011 02:34 PM
Cordless caulking gun help? EPD Tools & Equipment 5 11-24-2009 02:55 AM
20 Year Old Concrete Cure BSCi Health & Safety 0 09-23-2009 01:42 PM
removing silicone rescraft Tiling 3 07-07-2009 05:43 PM
Bathtub Caulking Type Jodi M Construction 21 12-12-2008 07:34 AM
