Siding Nailer Worthwhile? Or Framing Nailer.
Old 09-24-2013, 04:57 PM   #1
bob_cntrctr's Avatar
Trade: property manager & renovator
Gentlemen,
I have a large vinyl siding job coming up. In the past, I've just hammered. But the old bones got me thinking about a siding nailer. I've never had or used one. They look an awful lot like my coil roofing nailer - Bostitch even makes an adapter for one of theirs that converts it into a siding nailer!
Anyway - not suggesting any crazy like using my roofing nailer - but I have seen references to using a framing nailer. I might use a dedicated siding nailer three more times in my life - whereas a framing nailer I'd use a fair bit in the coming years.
Can you really do vinyl siding with a framing nailer? If so, any special tricks? Or best models for the job?
Thanks.
bob_cntrctr is offline
Old 09-24-2013, 05:06 PM   #2
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
Re: Siding Nailer Worthwhile? Or Framing Nailer.
Originally Posted by bob_cntrctr
Gentlemen, I have a large vinyl siding job coming up. In the past, I've just hammered. But the old bones got me thinking about a siding nailer. I've never had or used one. They look an awful lot like my coil roofing nailer - Bostitch even makes an adapter for one of theirs that converts it into a siding nailer! Anyway - not suggesting any crazy like using my roofing nailer - but I have seen references to using a framing nailer. I might use a dedicated siding nailer three more times in my life - whereas a framing nailer I'd use a fair bit in the coming years. Can you really do vinyl siding with a framing nailer? If so, any special tricks? Or best models for the job? Thanks.
I maybe be missing something bit I've never seen, heard, or used a any of the options on vinyl siding. Only pneumatic I've heard of for vinyl is a stapler, I've only done it by hand. But I had the same problem deciding so I bought both.
Tylerwalker32 is offline
Old 09-24-2013, 05:18 PM   #3
Creter's Avatar
Rewards Points: 1,966
I thought about it when my latest siding project came to light. It had been a couple years since I had a siding project and since then the 'siding nailers' came to my attention.
I may be way off base but I am glad I chose to go old school and hammer down.
Reason being is that having the ability to fine tune a section of nails to eliminate the wave effect of covering up shotgun work.
**Now I'm not saying nailing tight etc, but you know what I mean by being able to feather out a run to make it look great to our eyes, let alone the homeowners.
So, with that being said, that was main reason I didn't and the second one would be to have one less thing to drag around the house, let alone the noise of the compressor.
Creter is offline
Old 09-24-2013, 07:19 PM   #4
steex's Avatar
Trade: repair and remodeling
Rewards Points: 510
Vinyl has to hang from nails that are a little loose, how would you get a framing nailer to do that?
steex is offline
The Following User Says Thank You to steex For This Useful Post:
woodworkbykirk (09-27-2013)
Old 09-24-2013, 08:12 PM   #5
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,226
Siding nailers are for wood, fiber cement, smart side, etc. not vinyl. That said, my Bostich has enough depth adjustment that it won't seat the nails tight. Every once and a while it would though, from missing a stud or whatever, and that might be enough to mess up a siding job.
Golden view is online now
Old 09-24-2013, 08:19 PM   #6
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Don't buy the tip for the bostitch, they don't work, but I made my own siding nailer, I just used a ridgid ( I know I know) roofing nailer (because they have the option of the sequential trigger, took a grinder and cut the bottom of the tip so it sits on the siding and run at about 70 psi and it works amazing
jlsconstruction is offline
Old 09-24-2013, 08:19 PM   #7
stacker of sticks
Rewards Points: 590
I'll post some pictures tomorrow
Old 09-24-2013, 08:32 PM   #8
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I can't under any circumstance see where that would be a good idea. Try hiring a young guy...
ohiohomedoctor is offline
Old 09-24-2013, 09:08 PM   #9
dutchroots's Avatar
Trade: Residential Builder
Rewards Points: 123
I've never seen a professional siding guy use a nailer. I've seen the nailers and the attachment for shooting right into the nail slot, and in fact I remember using one 25 years ago. It was winter time. Didn't work so well.
Edit: For vinyl, that is
dutchroots is offline
Old 09-24-2013, 09:47 PM   #10
VinylHanger's Avatar
Rewards Points: 7,422
The bostich works ok, but really doesn't save time. I addition to that, it makes it very hard to control the depth of the nails which can vary as you go across the wall, even in as short a distance as one panel. Hand banging is the best way.
If you are getting wore out nailing, try a smaller hammer. I use a 16 oz. Estwing finish hammer for vinyl. I choke up on it and it is very easy on the shoulder which is where my main discomfort comes from.
VinylHanger is online now
Old 09-25-2013, 07:22 AM   #11
I dunno. But, like I said, I see references to doing so online. For example:
http://www.homedepot.com/p/Hitachi-3...75AG/203397591
Hitachi 3 in. Coil Siding and Framing Nailer
"...Its depth adjustment allows you to change your driving depth without tools. Simply adjust the driving depth and use this nailer on a variety of materials...."
So I wondered - a depth adjustment that leave's them 1/32" proud?
But it appears when they say "siding" they mean concrete board, not vinyl.
Old 09-25-2013, 07:23 AM   #12
Sigh - I know it's true - was just hoping.....
Old 09-25-2013, 07:25 AM   #13
So what's apparent is that someone needs to invent a vinyl siding nailer with a positive, mechanical, reproducable, depth, or rather proudness, adjustment. Something not based on pressure, but a reproducable mechanical stop.
Old 09-25-2013, 02:06 PM   #14
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,068
flush nailer attatchment
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 09-25-2013, 02:19 PM   #15
SouthonBeach's Avatar
Rewards Points: 987
I have one of the senco roof nailers with their vinyl siding head. Once you get the feel of holding it the right way so the nail placement is correct each time it works great. Once in awhile I'll hit a soft spot and need to pry the nail loose a bit.
SouthonBeach is offline
The Following User Says Thank You to SouthonBeach For This Useful Post:
jlsconstruction (09-25-2013)
Old 09-27-2013, 07:04 AM   #16
Originally Posted by SouthonBeach View Post
...senco roof nailers with their vinyl siding head. ...
I think I found that online:
http://www.ebay.com/itm/Senco-Vinyl-...-/290847114030
Really? The magic "vinyl siding head" is a 10-cent piece of stamped steel?
This is what I've been thinking in the back of my head - I suspect the modification to make a roofing nailer into a siding nailer is something nearly trivial like this - so why the heck don't all the top brands offer it? And just how crazy is it really to think of making something up yourself? I've got a DeWalt coil nailer - must be some way to make it work. OR - a DeWalt rep reads this and gets the message.
Old 09-27-2013, 07:16 AM   #17
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,558
Constantly raising a gun and holding to the appropriate position to nail properly might be more uncomfortable as hammer and nail.
Above all, a good roof
Mr Latone is offline
The Following User Says Thank You to Mr Latone For This Useful Post:
Tom Struble (09-27-2013)
Old 09-27-2013, 08:04 AM   #18
Rewards Points: 987
It's a cast piece of steel. Basically take the tip of a roofing nailer add two legs to it to fit into the slot of the siding so it centers itself. And also serves as a stand off so you have better adjustment of leaving it loose.
Old 09-27-2013, 02:29 PM   #19
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
how will a siding nailer work for vinyl.. siding nailers use nails with very small heads.. the vinyl will slip right off the nail. if your gonna gun nail vinyl it has to be a roofing gun
woodworkbykirk is offline
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
Golden view (09-27-2013), Tom Struble (09-27-2013)
Old 09-27-2013, 10:26 PM   #20
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
properly driven staple [16 ga 1/2'' crown]is the best fastener for regular vinyl,with practice you can set them on almost any wall condition
they are not permitted on some shake panels
Tom Struble is offline
Gatorgrizz27 (04-29-2016)
Best coil siding nailer Gwinterburn Tools & Equipment 37 03-06-2016 10:14 AM
Short nails in a framing nailer onmywayup Tools & Equipment 39 10-21-2012 06:57 PM
Good Framing Nailer? onmywayup Tools & Equipment 17 09-24-2012 11:58 PM
need some wood siding advice Spike7 Windows, Siding and Doors 47 06-28-2012 10:27 PM
Bosch framing nailer sounds like a .22 CrpntrFrk Tools & Equipment 9 05-13-2010 01:09 PM
