Trade: Windows, Siding, Doors
Siding Affected By Heat Reflections From Windows
This was pretty interesting, and I'm wondering if anyone has a solution to this problem? Luckily the home owner is ok with it.
A piece of siding developed a concave bend in it out of nowhere, the siding was replaced, then the same thing happened again right away. We noticed that the neighbors upstairs window which had LowE coating, was reflecting the suns heat and directing it directly to this particular piece of siding, causing this issue. The siding used is mastic carvedwood, however I'm wondering that should siding have been put with form fitted insulation behind it, would it be able to resist the warping do you think? |
#2 | |
Capra aegagrus
Re: Siding Affected By Heat Reflections From WindowsQuote:
To respond to your question though, I can't imagine that any kind of backing would keep that from happening--though it might mitigate it slightly. |
Trade: framing/remodeling
I was at a seminar once where they talked about this happening. The houses in the pics were really close together. I think the only solution may be to change the glass in the other owners window. Sounds crazy but.................
It's definitely the window, the sun just hits it right and we could see the reflection right on that spot, it's like a laser.
as far as the siding, it's .044 so it's not terribly thin. |
KemoSabe
Along the Barrier islands, many of the homes are 8-10 feet apart. The reflection off of today's high performance windows is incredibly bright on the neighbors sidewall. I haven't seen this problem personally, but I've heard tell of it before.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Capra aegagrus
Excluding a very cooperative neighbor, it may be time to try your hand at design/build of decorative planters.
Capra aegagrus
Re: Siding Affected By Heat Reflections From Windows |
good idea with the planters, but the customer is pretty much ok with how it looks and understands it being a freak occurrence, thank god.
lone framer, coincidentally the neighbor is roughly ten feet away. |
Let me guess silver gray or village green carvedwood?
I would put a remote temperature sensor in that area, see how hot it gets..... contact the manufacturer and see what they recommend.
I know that the warranty conveniently excludes reflections of windows or doors, but not a bad idea to ask the mfr for a suggestion.
Patrick - it was pebblestone clay. |
If the other homeowner wont comply with a solution, convince your homeowner to install a window at that location and reflect the light right back at the other guys siding!
haha, Or a big mirror and magnifying glass!
Good fences make good neighbors.
Even a bush would work to cut back on the glare. or; Go soap up the neighbors windows ![]() I've never seen that happen,but I guess it happens since it warranty conviently excludes it!
https://www.facebook.com/pages/John-...94183374011504 |
Trade: Roofing, Siding, Windows, Remodeling
Hey everyone.
I've run into same problem last year. It was Mill Creek siding we've installed five years ago. Unfortunately ALCOA (manufacturer) don't cover this type of damages under their warranty. We replaced few pieces and home owner planted a small tree in front. Hope it helps |
Trade: Remodeling 30+ yrs
Try planting a tree or a bush.
Same deal here but with Royal Woodlands. The rep replaced 4square of siding on a wall, we split the labor all from the neighbors window. Not sure if it was a tinted glass or exterior Low E coating.
#18 | |
#19 |
Trade: siding
ive seen it on a wolverine restoration panel ,it was caused by a defective skylite,the glass sagged causing it to reflect onto and distort a wall some 20' away
looked like someone took a lazer and ran it up the wall,siding was melted so if you ever see a panel like that look for something shiny,it could happen in a driveway by a car mirror or chrome trim
Tom |
| stucco over the existing asbestos siding | DLF Builder | Business | 2 | 09-21-2009 02:08 PM |
| windows siding doors | Patrick | Contractor Swap | 6 | 02-06-2009 01:19 AM |
| siding an old house | gtmstang | Windows, Siding and Doors | 14 | 12-20-2008 06:21 PM |
| Uh-oh, the Big Drop is stalling out. | Mike Finley | Marketing & Sales | 7 | 12-12-2008 06:05 PM |
| Siding job, windows | sady | Specialty Trades Picture Post | 11 | 08-01-2005 10:20 PM |
