Should You Be Licensed?
Old 03-11-2007, 08:42 PM   #1
General Contractor
NickofTime's Avatar
My question is, should you be licensed to install gas pipe?
I've heard both sides, some yes and some no.
The reason I ask, I have a customer who wants me to install a gas fireplace but I'm not a licensed gas fitter. I have worked with licensed gas fitters and now what I'm doing. Is it okay to do the work as long as it's inspected by a licensed gas fitter?
Thanks
p.s. I accidentally stumbled onto this website and I find the website very entertaining on the fact that everyone has a different opinion on things and I think that's great. Some debates are pretty intense and some are funny. I enjoy them all. It's a great place to pick up little tips and tricks.
NickofTime is offline
Old 03-11-2007, 08:47 PM   #2
mdshunk's Avatar
Re: Should You Be Licensed?
I guess that would depend on the laws in the jurisdiction where you propose to do the work. There's no possible way to answer that with a blanket YES or NO.
mdshunk is offline
Old 03-11-2007, 10:14 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
You may be able to "get away with it" If you were working for a licensed gas fitter... But that may depend upon your state and local laws. As far as how I feel... NO. Anyone doing anything (EXCEPT as an employee (and once again unless required by local law)) should be licensed for the work they are doing.
RobertCDF is offline
Old 03-11-2007, 10:26 PM   #4
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Send a message via AIM to Mud Master
No..nothing should be done on anything but your own home without a license...Nick, search the forums and you will find countless threads about being hacked and lowballed by unlicensed guys. I am in no way stating or even assuming that you are a lowballer, just stating that we here have many many discussions on unlicensed guys. It is a risk to both yourself and the homeowner or builder to preform work without a license and proper insurance coverage.
Now, if you are working under a licensed gas fitter, with something written stating that you are, than you are by all means covered and can preform the work. But if you are not licensed and insured yourself for that kind of work, than I would most definetly call one of your licensed friends in the business that has seen you install gas related fixtures and ask if he will sign a form stating that you are working under his license. Covering your azz is the BEST thing any contractor can do.
IMO
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 03-11-2007, 10:51 PM   #5
pro picnic table builder
vwovw's Avatar
Trade: gc
ugh yes they should be licensed and also drug tested
vwovw is offline
Old 03-13-2007, 09:57 PM   #6
LC Australia
Boogga's Avatar
Trade: Building
In this part of the world, absolutely YES.
"It's better to die on your feet than to live on your knees"
Boogga is offline
Old 03-13-2007, 11:06 PM   #7
Home Builders/Contractors
Metrojoebarbs's Avatar
Trade: Residential Home Builder/Contractor
yes
Metrojoebarbs is offline
Old 03-13-2007, 11:56 PM   #8
GC/ Master Electrician
Ken@K&R's Avatar
Trade: General Contractor/ Master Electrician
Send a message via AIM to Ken@K&R Send a message via Yahoo to Ken@K&R
Why not just install the fireplace and sub the gas out?
Ken
Ken@K&R is offline
Old 03-14-2007, 09:57 PM   #9
General Contractor
NickofTime's Avatar
Thank you for your input. I can definitely say that I'm not one of the 'lowballers' mentioned above. I take great pride in my work and work ethic. Always wanting to learn new things just don't want to get in trouble doing it.
Thanks again.
Old 03-14-2007, 10:04 PM   #10
Mud Master's Avatar
Thanks again.
I hope you don't think that I was saying you were a lowballer, I even said in my post that I wasn't refering or assuming you were, but just that other threads about licensing had it brought up. Hang around here for a while, be suprised how many new things you can learn...I know I have!!
Old 03-14-2007, 10:24 PM   #11
General Contractor
NickofTime's Avatar
No offence taken whatsoever. I'm pretty easy-going.
Old 03-17-2007, 05:23 PM   #12
my own boss
supercrew's Avatar
Trade: carpenter
Send a message via Yahoo to supercrew
i think a license should be required of all building trades, including framing carpenters and foundation work. even to the extent of GC having a "working knowledge" type of license in all fields when developing their own properties.
case in point: i just built a house for a GC who did everything with inexprienced laborers. the foundation was out of square by 3" in one 20x40' section and another 2+" in another 15x20' section. he backfilled 2 days after stripping the walls with no ?outside tile drain?...might be a lake of the ozarks thing....but he was pissed cause the basement walls had bows in the middle and water was always around the inside of the footings after a rain.
he then proceeded to snap the plate lines off the outside of the walls and slap the plate to it without EVER measuring side to side or the corners.
he then proceeded to do the 1st floor layout starting with the front from the right, then the center beam he started on the left, starting the back wall from the right.
i get hired to finish framing the house at this point. talk about some head scratchin and abusive language figuring out why this stair hole is 1/2" smaller on one side and looks crooked.
he also put a header in a 4' exterior wall that was 1" too long.
now were setting the second floor. one of "boyz" laborer cries about a brace on that mentioned 4' wall of being in the "way". the GC comes in and knocks it off.
i say: hey i kinda need that, its holding the corner of my building up.
he says: it'll be alrite, besides its in juniors way.
i say: noooooo as he whacks the brace off
now were puttin the roof on....6/12 and its an all hip roof with 6 hips and 4 valleys including the 2 for the gabled front porch roof. the GC ordered the truss system so it ends 10' from each corner leaving the rest to be stick built.
1 1/2 days into the roof i call him to say were running outta lumber....furious!! he shows up on site and demands why it isnt framed on 24" centers. ....i calmly explain that the print didnt dictate either and as far as i knew you couldnt stick build a roof with 2x6x12's on 24's.
now before anyone starts to blast me for "knowingly working for an unethical person", i already know that. but i learned a thing or two on how to hide and compasate for ground up mistakes. a plus in my book.
besides i wont be trimming out this house ....its suppose to have hardwood and ceramic tile floors everywhere..,,,and i dont think my name will ever be connected to it, so i dont care.
would i ever participate with another GC with the same practices???
an astounding NO, even tho he paid me great money to cover his mistakes.
also did a project for the same guy involving a rehab of a basement in a commercial bldg that im not to proud of myself.
we tore out a section of concrete to find the drain, and built a bathroom w/comode, urnal and sink,.....
also added 12+ can lites and 24+ pen lites..36 lites with 20+ switches...on the same circut..
added a gas furnace including the ductwork..
when i was asked to "hook the gas up" i refused and no longer work for him
as an UNLICENSED worker in the field,i did electrical,plumbing and hvac work that i was NOT qualified to do. in a commercial building that 4+ workers sit at computers and do an ad agency thing without so much of a fire system in a basement with ONLY ONE escape route...and....NO WINDOWS.
this weighs heavily on me every mornin when i wake up...should i report or should i just distance myself????.......
im still in a moral fight with my concious to report the work on the basement with the cities code enforcement establishment just to clear my liability and "to do the right thing".
sorry to vent guys but this has been hanging over me for weeks, going on months. i dont want to read/hear a fire killed/injured someone that was started by something i wired.
i only work off drawings
supercrew is offline
Old 03-17-2007, 11:57 PM   #13
Where are the inspectors Supercrew? This guys days are numbered.
Old 03-19-2007, 01:20 PM   #14
Custom Fence Builder
Susan Betz's Avatar
Trade: Fence Manufacture and Installation
Not really related to the actual thread, just the title of the thread.
Our county, in 2007, stopped all occupational licensing. We *were* licensed, until they did away with the licenses.
Now for those of you who say "HUH?" - I can't make s*** like this up. The county decided not to issue any more occupational licenses.
Try explaining to a client why you're not licensed.
Fences of Distinction, Ocala, FL
http://www.fencesofdistinction.com
Susan Betz is offline
Old 03-19-2007, 05:37 PM   #15
How do they get away with that? No State or Federal violations on the County's part, not to mention conflicts of interests.
Old 03-20-2007, 06:22 PM   #16
Susan Betz's Avatar
There are state licenses (FL) for many trades. But we do fences - no state license. Licenses are issued county by county. Now, to further confuse the issue, the county seat, Ocala, issues licenses for fence companies, but only if you're technically in the city limits. Our location is just outside the city limits. We can't get a city license. BUT if we want to install a fence within the city limits, Ocala is ok with that. <groan>
It gets more complicated. There is at least one county in FL that requires we have a county license in our home county and a county license in their county before we can pull a permit. (I know because we have a job coming up there and it's my job to clear this stuff, which for the record is a job I despise).
I want to curl up in a fetal ball when I bang into this sort of stuff. It shouldn't be this difficult to put up a fence. We don't mind following rules and laws, but consistency would be a blessing.
Old 03-22-2007, 11:14 PM   #17
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
DO NOT DO IT >>>>>>> My friend just got back from Reno NV and he went to school for that to install stoves pellets and gas by lunch time he changed to wood stoves the liability was to great you could spend the rest of your life in JAIl,, if some thing went wrong by the way they came from all over the states to take this test one guy has been sued 17 times
hrscammisa is offline
Old 03-22-2007, 11:38 PM   #18
Jack's Building's Avatar
Trade: General
Supercrew, I would, as you did, distance my self from that hack. A foundation 3" off... I feel sorry for the guys attempting to run the trim.
Jack
Jack's Building is offline
Old 03-23-2007, 08:10 PM   #19
J87513's Avatar
Trade: plumbing/pools
licensed or not, just DON't SMOKE ON THE JOB!
J87513 is offline
Licensed VS. Unlicensed jgjrei Painting & Finish Work 59 10-13-2009 04:56 PM
Licensed & Insured bjg5240 Business 34 06-09-2009 07:56 PM
licensed vs not Jengle Introductions 5 01-13-2007 10:39 PM
New Licensed GC In South Florida mikegee Introductions 2 10-30-2006 01:29 AM
Starting a licensed business ? asaner85 Construction 5 06-17-2006 02:00 PM
