Trade: Handyman
Sheet Goods Best Way To Move....
I have a pick up with a home made slide out bed. When I have it loaded with tools I have left a bit of room to stand up sheet goods up against the tool boxes of the cap. It is a real pain to get them in and out past the barn style doors on the back of the truck.
What is the best way that you have found to move sheet goods. This is my first post and thanks for any ideas...... |
Its all ball bearings
Trade: Tile
Re: Sheet Goods Best Way To Move....
Bring a helper!
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
KemoSabe
Delivery
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Years ago when I worked out of a pickup and canopy. I also had a slideout, and I raised it up so I could slide sheets under it.
After that I went to a 1 ton van, and had slide out drawers under the floor. So when I built the shelves on the sides, I put in slots so I could put in some cross braces about 2 feet off of the floor and carried the sheets on top of the braces. |
Capra aegagrus
Ditto Lone's "delivery", if it's more than a couple/few pieces. One of the nicer truck setups I've seen was a homemade slide-out bed with room underneath it for a few 4x8 sheets. But depending on where you typically work, and how often you need to haul such stuff, a trailer might be your best bet.
| WTB Sheet Metal Brake | Waggz | Contractor Swap | 0 | 05-24-2009 01:43 PM |
| European Sheet Goods Sizes | ScenicArtist | General Discussion | 9 | 02-17-2009 07:56 PM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Sub-flooring For Sheet Goods | TRISTAN | Flooring | 3 | 05-19-2007 12:08 AM |
| Apparently $7 a sheet is Good??????????? | 1KingOfDrywall | Drywall | 39 | 04-10-2007 11:08 AM |
