Setting Tapcons, SDS Or Impact? - Page 2 - General Discussion - Contractor Talk
Old 08-20-2016, 07:52 AM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,368
Re: Setting Tapcons, SDS Or Impact?
Originally Posted by heavy_d View Post
I use sds to drill then impact to set. I have never sheared the head off a tapcon in my life. I didn't know you could do that. Even when the hole isn't quite cleared out enough and the impact is just struggling... Never sheared a head. I do use 1/4" always though. Maybe you guys are using real thin ones?
1/4" are hard to snap, 3/16" snap pretty easy.
Inner10 is offline
Old 08-20-2016, 08:10 AM   #22
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,052
Sds and impact for me also. Drilling the hole deep enough and clearing as much dust out as you can by running the bit in & out several times helps a lot. I always felt those combination setups weren't beefy enough and would strip or snap to soon.
overanalyze is offline
Old 08-21-2016, 07:43 AM   #23
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
Originally Posted by aptpupil View Post
Impact driver will snap the head off half the time.
and the other half will set short.
Krok is offline
Old 10-29-2016, 08:22 PM   #24
PacificCanvas's Avatar
Trade: Awnings
Rewards Points: 146
Why not just use plastic expansion anchors? We use the blues and they work great......Never have I used a tapcon. We go from using 1/4" Hex head lags with blues( plastic expansion anchors) to 3/8" Redhead Expansion anchors and then if the material is brick or a non-dense masonry/concrete we have to use 3/8" lag shields with lags.
It's interesting to see what everyone uses though.
PacificCanvas is offline
Old 10-29-2016, 08:27 PM   #25
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 422
I don't like the combo bit thing either.
SDS plus to drill (cordless)
impact to drive
Watch the tapcon. If you are running the impact and it doesn't zip in like a screw, stop...
Back it out.. Re-drill if needed.
Then drive back in.
BTW, I use a ton of tapcons.
Lunicy is offline
Old 10-29-2016, 09:58 PM   #26
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,440
Call me crazy, but I've all but stopped buying Tapcons since I discovered the GRK Caliburns...haven't snapped one yet and they just seem to cut the threads in easier and cleaner...anyone else try them? A few extra bucks, but I'll take less frustration for a few dollars!
mstrat is offline
The Following User Says Thank You to mstrat For This Useful Post:
Kowboy (02-04-2017)
Old 10-29-2016, 11:09 PM   #27
rustyjames's Avatar
Rewards Points: 1,576
Originally Posted by META View Post
Most holes I make sure are cleared out well. A big part of this discussion should be tapcon depth, though. Tapcons going in beyond 2" or so are naturally going to have issues with too much friction.
Agreed, I believe that they are spec'd not to be embedded more than 1.75".
rustyjames is offline
Old 10-30-2016, 07:48 AM   #28
maxwage's Avatar
Rewards Points: 791
I don't use any less then 1/4" tapcons, even for metal track. Anything less then that snaps way too easily and doesn't seem to have chit for sheer strength.
I'm a beast at everything I do.
I buy tools. Not brands.
maxwage is offline
Old 10-30-2016, 08:08 AM   #29
tjbnwi's Avatar
Rewards Points: 3,902
I find the Spax multi material screws work much better than Tapcons.
tjbnwi is offline
Old 10-30-2016, 09:10 AM   #30
Inner10's Avatar
Because you can't drill through the item you are fastening, then drive the anchor directly into it. For instance fastening a sheet of plywood to the wall, you would have to take the sheet off, insert your rawlplugs then hang it back up. Plus they fatigue overtime. Once you try a one piece anchor you will never go back.
impact to drive
Then drive back in.
Yup, if they slow down, back em out.
Often times the item I'm mounting won't accommodate a fastener that big.
Inner10 is offline
Old 11-01-2016, 06:42 AM   #31
builditguy's Avatar
Rewards Points: 414
SDS for the hole. 3/16". Impact for putting the tapcon in. 1/4" tapcons. Rarely break one. Smaller tapcons, I can break almost all of them.
One thing that happens is when you use the drill bit that comes with them, the hole is a little smaller. Technically correct, I'm sure, but easier if you use a 3/16" bit. Since I use a SDS, I always use the 3/16". I'm sure the pull out strength is altered, but not enough for the work I do.
builditguy is offline
Old 12-09-2016, 07:20 PM   #32
VinylHanger's Avatar
Rewards Points: 7,994
No spam would be a start.
VinylHanger is offline
Old 12-09-2016, 10:51 PM   #33
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
SDS for the pilot hole and standard M12 driver to install the screws.
MechanicalDVR is offline
Old 12-13-2016, 05:38 PM   #34
madmax718's Avatar
Trade: General
Rewards Points: 3,252
I do use a SDS for the holes if it will be more than 15 or 20, or if after the first hole the material is just way to stubborn. But I do like using a regular drill to drive em in, the clutch setting makes it more brainless.
madmax718 is offline
Old 02-04-2017, 06:02 AM   #35
Trade: Awnings
Rewards Points: 146
[QUOTE=Inner10;5312977]Because you can't drill through the item you are fastening, then drive the anchor directly into it. For instance fastening a sheet of plywood to the wall, you would have to take the sheet off, insert your rawlplugs then hang it back up. Plus they fatigue overtime. Once you try a one piece anchor you will never go back.
I normally hand tighten a few threads on the plastic expansion and send them right through the material and into the wall. It may chip or scrape a bit of plastic off but it works fine. I know tap cons were the discussion but I use the plugs a lot in lath, plaster, and stucco where stud connections are not possible. I would like to know what your preferrable anchor device in those situations are.
I do keep 3/16" snap/strap toggles on the truck for those times when plugs or expansions just can't get a good bite. The brackets I use have a 3/8" hole for the anchor so all the smaller type of fasteners just don't have a big enough head on them.
Old 02-04-2017, 08:15 AM   #36
Inner10's Avatar
[quote=PacificCanvas;5640418]
I don't find rawl plugs work well in plaster either, I'd rather run a #8 in to see if it bites on the lath, failing that it gets a snap toggle.
If my devices had 3/8 holes I'd be using 1/4" snap toggles all day:
Inner10 is offline
overanalyze (02-04-2017)
Old 02-04-2017, 10:51 AM   #37
Always Learning
The snap togglers are my favorite hollow wall anchor for heavier items.
Great deal on heavy duty impact wrench BCConstruction Tools & Equipment 1 09-17-2009 08:31 PM
Opinions on horizontal roller impact windows VS single hung impact windows security heydade Windows, Siding and Doors 2 09-10-2009 09:49 PM
Impact Glass nyc_sport Windows, Siding and Doors 8 09-07-2009 10:25 AM
Makita 18V Li-ion Impact drivers jhetland Tools & Equipment 15 04-18-2009 10:51 PM
Kitchen Install *( impact driver ) MikeNeufeld Tools & Equipment 32 02-13-2009 06:03 PM
