Sealcoating
Old 11-01-2009, 04:31 PM   #1
Any Season's Avatar
Sealcoating
I want to add sealcoating to my painting business as a way to package services and book more work. I plan to buy the right equipment to spray and fill cracks, not just a squegee and bucket. My question is, is there advice I could get on pricing? I know I'm probably going to get killed for asking that but, no offense to sealcoaters out there, this seems like a field that requires limited skill and pricing appears to be pretty general. Also, I am researching the best places to get equipment and would like to know if there is one particular brnad of sealcoat that is better or easier to work with. Thanks in advance...
Any Season is offline
Old 11-01-2009, 07:13 PM   #2
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Re: Sealcoating
I know there are several forums that discuss sealcoating specifically.
Just do a google search,..Here is an example.
http://www.pavementpro.com/forum/fusionbb.php
CCCo. is offline
Old 11-01-2009, 07:21 PM   #3
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Re: Sealcoating
my asphalt driveway is 700 feet long and needs some help what is the difference between spraying and mopping
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 11-01-2009, 07:32 PM   #4
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
Re: Sealcoating
Spraying is much faster then mopping but Mopping holds up better . spraying it doesn't fill in the cracks as well .
I recapped driveways, sealed and striped pavement in a past life.
The best place to buy a tank and sprayer is in the want adds used .
alot of guys sell out this time of year.
The funny thing about the sealer is in the late 70 s early 80s all the sealer was the same stuff from the same vat . We would buy from a supplier 1/2 an hour away . We could pull 300gallons of material in a 500 gallon tank on our spray trailer . When we are at the plant they have 5 gallon buckets every where and they just change labels and color of buckets but channel lumber , rickles, sears all had the same stuff . John
wellbuilthome is offline
Old 09-30-2010, 10:38 AM   #5
travelcoater's Avatar
Trade: Sealcoating and Line Striping
Re: Sealcoating
Sealcoating with the right equipment is a full-time job. This isn't something you can just dabble in. The equipment needs to be constantly maintained, and YOU need to know your equipment from front to back. This requires mechanical knowledge, and some rudimentary plumbing skills.
Furthermore, TONS of skill is required to set yourself apart from the unskilled sealcoaters out there. Good technique takes YEARS to acquire, and must be practiced continually to keep from getting rusty. Here's some things to consider before getting into this "unskilled trade":
-Mix design.
-Weather variables, pavement temperatures, water fogging in hot weather, knowing what additives to use at what times.
-Equipment maintenance and repair.
-Possible DOT restrictions on equipment.
-Licensing.
-Knowledge of the product you are putting down.
-Understanding different brush types and techniques.
-Understanding different spray methods / equipment
-Proper prepping skills (A LOT more than just running a leaf blower).
I haven't even covered crack sealing and line striping yet. Pavement maintenance is a very complex, multifaceted business. You can get into trouble VERY quickly if you don't know what you're doing. I see SO many guys assuming that it's "so easy" just because they saw someone spray a driveway once. Trust me, it isn't easy. This is an art and a legitimate skilled trade that real contractors are in for LIFE. You've gotta be prepared to either totally jump in, or don't bother. NOBODY is ever successful in this business just doing it on the "side". But hey, don't take my word for it.
travelcoater is offline
The Following User Says Thank You to travelcoater For This Useful Post:
Sportioli (07-15-2011)
Old 09-30-2010, 10:02 PM   #6
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Re: Sealcoating
Good post travelcoater
It just goes to show that we shouldn't make assumptions about another mans trade.
I honestly never knew all that info.
I'm feeling smarter already though
I think I'll open a recoat business, any more tips?
JK
Yeah, I pay 50 cents a gallon for fuel
www.wasteveggieoilexplorations.shutterfly.com
Aaron Berk is offline
Old 07-15-2011, 01:17 PM   #7
richardndeal's Avatar
Trade: Asphalt Business
Re: Sealcoating
I agree with "Travelcoater", there is alot to learn with this type of work. But the best way to learn is trial and error. Start out sealcoating small jobs, maybe like your driveway. And make sure you do your research. Alot of the big asphalt sealer manufacturers have training material for the contractors.
And if you are looking for some used sealcoating equipment try out www.asphalttrader.com
richardndeal is offline
Old 07-16-2011, 01:05 PM   #8
nailit69's Avatar
Trade: Contractor/PM/Designer
Re: Sealcoating
Yea... not something you just dabble in, it's a full time gig. I helped my buddy start up his sealcoating/striping biz a few years back and there were many many mistakes made along the way with improper equipment, improper plumbing, improper product, improper application, etc. It took a few freebies before we had all the kinks worked out and could actually go out and blow out a big job and make any money doing it.
If you can buy a small rig that's already set up, get a few lessons from the owner, and find a supplier for the coating you'll have a better start than we did. Good Luck.
nailit69 is offline
Old 07-18-2011, 12:33 AM   #9
Re: Sealcoating
Being a successful sealcoater takes way more than just being able to do a good job, or having the equipment to do it. It takes a lot of finesse with the customers, and you've gotta use the right English to get those jobs. You've gotta be a hustler, and know what to say. There's a lot of psychology that's involved both in selling the jobs, and on your end as a contractor.
I've been doing this for 13 years, and I can honestly say that it's incredibly rare for me to actually see my own dried, cured work after the caution tape and stakes have been taken down from the entrance of a driveway. From April through October, it's one right after the other....as fast as I can get the product on the ground. I've always attributed the sealcoating business (at least here in the Northern states) in the same light as baseball. The seasons coincide, and it's all about putting up good numbers. He11, I even take a little week-long vacation every year at the all star break, as it's the mid-point in my work season.
Old 07-18-2011, 09:59 AM   #10
nailit69's Avatar
Re: Sealcoating
He uses the Queens english to sell em' . He's a silver tongued devil from England, he could talk the panties off of a nun, i've seen him do it .
Not a job for me though, it was fun, it was cool to try something new, just not for me.
nailit69 is offline
