Scored Concrete Floors With Metal Inserts
Old 06-28-2009, 11:49 PM   #1
go do it's Avatar
Trade: general contracting
i am going to try and talk a HO into stained concrete floors for a remodel
i want to cut some "grout lines" in the floor and have some aluminum (sp) inserts placed in them. i have seen scored floors before and the scored lines fill up with lint and dirt and cheetos and cheerios well you get the idea
anyone done this or know the process
thanks
go do it is offline
Old 06-29-2009, 05:30 PM   #2
General Contractor
greg24k's Avatar
Re: Scored Concrete Floors With Metal Inserts
thanks
I've seen it done it looks real good. They used grout, but you can use inserts also. If you use inserts, you have to make sure the floor is leveled or it will look like s^*t, the grout would be much better. My buddy used acid to give that etched look, it did turned out good.
greg24k is offline
Old 06-30-2009, 01:16 AM   #3
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
I seen one with aluminum inserts and I think they diamond grind the floor after they put in the inserts to make it flat. then they stain the floor or whatever else that want to do.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 06-30-2009, 07:53 AM   #4
joasis's Avatar
I believe the scoring lines for the inserts are a little deep, and then the adhesive in set and the inserts leveled to the floor. I have not done it, and never really paid attention to the technical side of it, since we grout them. A good grout, sealed, will prevent the problems as well as the inserts, unless you are stuck on that specific look.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Concrete Strength Gnanchandra Construction 3 12-24-2008 09:19 PM
Undercutting metal jambs downwithfloors Flooring 10 12-18-2008 09:21 AM
Metal framing for basement and drop cieling joliet_man Framing 8 10-31-2008 06:40 PM
Metal roofing Help The Boys Roofing 9 08-22-2008 09:28 PM
attaching metal lath to poured concrete walls with foam michiganmason Masonry 0 02-12-2008 04:26 AM
