Rules For Wooden Planks?
Old 02-08-2007, 02:53 PM   #1
metomeya's Avatar
Hey. I'm replacing some heavy planks with wooden ones, cause I need something more light weight (Has anyone seen magnesium planks?)
Safety is of course an issues. I'm about 210.
They are going to spand, a little over 4 feet. And be about 10" in width.
How thick do you think the wood should be?
Type of wood? (oak i'm guessing)
What do you think of adding a sheet metal backing on the bottom to add support?
Any opinions or alternatives would be appreciated.
metomeya is offline
Old 02-08-2007, 04:34 PM   #2
Toothpick's Avatar
Trade: Home building
Re: Rules For Wooden Planks?
Have you looked at the standard osha planks? Most lumberyards carry them, they are made from clear yellow pine with steel rods in the ends to help prevent splitting and cupping. Usually 2x10 and 8'-16' in length.
Toothpick is offline
Old 02-08-2007, 04:36 PM   #3
TimNJ's Avatar
How about regular "scaffolding" planks. Should be available at any commercial lumber yard.
TimNJ is offline
Old 02-08-2007, 06:54 PM   #4
metomeya's Avatar
Any picture of these?
you think i'll find it in 4 feet?
metomeya is offline
Old 02-08-2007, 07:33 PM   #5
boman47k's Avatar
Made some temps out of 3/4 ply with 2x's on the under side. They are a little heavy though. Better than some I have been on though! Whew!
boman47k is online now
Old 02-08-2007, 08:12 PM   #6
Frankawitz's Avatar
Home Depot has adjustable aluminum plank for around 100 bucks. It's 6' to 12'
Frankawitz is offline
Old 02-08-2007, 09:13 PM   #7
metomeya's Avatar
Weight and size is a concern,
thats why i wanted to make my own.
Is yellow pine light weight? How exactly does the steel rods fit in?
Can I buy yellow pine locally?
metomeya is offline
Old 02-09-2007, 09:16 PM   #8
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Just buy some OSHA rated scaff planks. They are just rated micro lams basicly.
JustaFramer is offline
Old 02-09-2007, 09:50 PM   #9
framer
steves's Avatar
Trade: framing
What are these OSHA planks?????
OSHA aproves NOTHING they just set standards.
If any sales people try to sell you anything that is OSHA aproved ask them for the aproval paper work. There is none.
steves is offline
Old 02-10-2007, 12:23 AM   #10
metomeya's Avatar
??? I don't think anyone said they are approved, just rated to their guides like other things are like masks and such.
What do you mean micro lams, JustaFramer?
metomeya is offline
Old 02-10-2007, 12:46 AM   #11
Teetorbilt's Avatar
If you have the ambition, you can fabricate your own from 1 X 2's or greater. Foam and fiberglass can be really light AND strong.
Albert Einstein
Teetorbilt is offline
Old 02-10-2007, 12:53 AM   #12
Blackbird's Avatar
Trade: Remodeling and Custom Decks
extendo-plank
Blackbird is offline
Old 02-10-2007, 12:54 AM   #13
metomeya's Avatar
i think i'm interested.
What exactly do you mean by foam and fiberglass? Like bondo? What kind of foam exactly?
metomeya is offline
Old 02-10-2007, 01:46 AM   #14
Teetorbilt's Avatar
Here, most commercial HVAC co's sell 2" polyurethane foam. This can be ripped through a tablesaw. The 'stringers' (wood) can be as light as you want to make them. I usually go 1/4" Fir. For a 16" platform I'd use 4, two on the outside and two equally spaced in the center. Laminate the sandwich first, level the decks and then glass. A few layers of 6 oz. works fine for me but I'm good at it. You may want to try mat for starters. Wrap it well over the edges.
These are just something that I whipped up in my spare time and I had the materials on hand (I have always built surfboards). The ones that I have built have working loads of about 550#s over an 8' span.
I never did any engineering as I knew that they would work for MY purposes but I lately asked a friend to drive over an old one in his F-350 diesel with one end on a concrete block and it didn't break. The worst fractures were at the block interface.
Albert Einstein
Old 02-10-2007, 02:44 AM   #15
metomeya's Avatar
Kinda lost here.
I've seen from some guides on the internet, how they do the foam/fiberglass thing.
-foam
-resin over it
-fiberglass cloth over that, and get all the air out.
-then resin over that
I'm kinda lost in how the wood fits in order of options. Is it being bonded by the resin?
Also what is the best way to color the fiberglass, do they sell dyes for it? Are there different grades of fiberglass or does the bondo work fine?
metomeya is offline
Old 02-10-2007, 10:22 PM   #16
Priced In
Laminated engineered lumber. Some OSHA rated planks are laminated just like microlams.
Old 02-10-2007, 11:02 PM   #17
plazaman's Avatar
OSHA planks must have osha Stamp on them with a date. After so many years, they have to be dumped. Im not sure on the type of wood, but OSHA planks have ties on the ends to prevent splits.
plazaman is online now
Old 02-11-2007, 11:07 AM   #18
metomeya's Avatar
Like metal ties?
metomeya is offline
The rules our sales guys live by Grumpy Marketing & Sales 31 10-24-2011 02:12 AM
osha approved planks - BS oldrivers Health & Safety 12 06-03-2007 10:10 PM
General rules..... KellyPainting Painting & Finish Work 5 11-30-2006 06:40 AM
Please follow the rules!!! theworx Carpentry 16 08-31-2006 08:14 PM
