paper hanger,painter
Rough In Inspection
I am having some rmodeling done and the contract calls for the third payment due when "rough in inspection is done" this project is not even close to half done,so when is rough in completed and inspected by whom? Thanks.
Chris |
Sauna & Steam - Remodelin
Trade: Remodeling / Sauna & Steam
Re: Rough In Inspection
Did you pull a permit for the job?
If so, then it would be when the rough electrical, plumbing, interior framing, insulation, hvac, etc (or whatever applies), have passed inspection. It also depends on what inspections are required by your municipality. If you didn't pull a permit, or if certain inspections are not necessary, then get an inspection by a D3P (that is, if you feel uncertain about the quality). This is only a suggestion, but could save you money.
Raimo Kumpulainen Those who don't remember the past, are condemned to repeat it. |
Rough in that I use is when all the work in the walls is done and inspected before the drywall goes on, such as electrical wire, plumbing, A/C ducts, and insulation. The city/county building ispector should do the inspection assuming you pulled permits.
Trade: general contractor
Read and understand contracts before signing! This goes both ways- ho and contarctors. There are a lot of posts re payment schedules, conflicts with ho over inclusions, final payment, ect. ; all things that should be listed in a GOOD contract. For all who do not have a good contract template, look up AIA contracts and down load/copy them. A proper contract will save your @$$ in court! They have several, depending on the job size. Most of my jobs are above $100,000 and the contract I use is written in lawyer speak. Hard to digest after reading the first time, but it is written by a third party(AIA), covers much of the ho problems I read about here, and will hold up in court much better than a contract you copied from the back of some construction book. I know I got OT but many problems I read about can be avoided with a well written, detailed contract.-Chris
Remodeling GC
we list as follows:
After rough plumbing x amount due after rough electrical x amount due After rouch HVAC x amount due after rough framing x amount due after insualation and drywall inspections x amount due After floor tile installed x amount due etc etc ....
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
Luke Lukens
Trade: General Remodeling Contractor
we list as follows:
After rough plumbing x amount due after rough electrical x amount due After rouch HVAC x amount due after rough framing x amount due after insualation and drywall inspections x amount due After floor tile installed x amount due etc etc .... We lump all of the above together. Downpayment at contract signing and then the next payment is typically when all of the above is completed, inspected and drywall hung. We get a large enough down payment so we stay with positive cash flow through the process and I attempt to make things as easy as I can for the client by keeping the payments to a reasonable number - usually 4-5 per project unless we're over $300,00 then it can be 6-8 total payments. Change order payments are due when submitted, so they can fill in the gaps on a short term basis as well. |
General Contractor
We typically get a down payment of $1000, x% after demo is complete, x% after rough inspection is passed, and so on.... This insures me having more than half the money due me before I start finish (beginning with drywall). Most jobs now I just get weekly or bi-weekly payments regardless of what is complete. This prevents the customer from holding back money for ridiculous reasons
"History does not long entrust the care of freedom to the weak or the timid”. Dwight D. Eisenhower |
#8 | |
Fentoozler
Re: Rough In InspectionQuote:
![]() My contract states I receive a payment after passing my rough (that'd be just electrical ...in spite of what it says under the pumpkin over there <~~~ ). The rough inspection - depending on what/who we are talking about - could be anything ...and hopefully, the inspection is performed by a city/county/State AHJ or a "certified" (aka, legitimate) 3rd party inspection service.You haven't told us anything about what the project all is.....maybe a few more words from you would help us to help you?
Thanks all,I just was not sure of the wording. The city has made all 3 inspections and yes I did have a permit. It is a bathroom remodle and they want their 3rd payment after passing the inspections. This being said,is it common for the job to be not even half complete for the next to last payment? Does not seem right to me.The drywall is up,electric wires installed,plumbing ,sub floor down,but really no finish work has been done and they want 90% of the total cost ,just does not seem right.
#10 | |
#11 | |
Fentoozler
- bath fixtures ~ who purchases? - tile work ~ who purchases the tile? - etc... I can say that the electric end of the job would be a MINIMUM of 67% of the electric total...for a small job such as this (w/ 3 - 4 lights, 2 switches, 1 GFCI outlet, maybe a jacuzzi connection) the actual percentage might be closer to 90% of the electric price. Not much is left for the electrician here.
| Rough estimate 9,500sq.new home | birdog | Painting & Finish Work | 19 | 08-19-2007 07:31 PM |
| Residential Rough in Estimate Central Florida | Surface Tension | Plumbing | 7 | 06-17-2007 12:23 AM |
| Home inspection | brentsid | Inspections | 13 | 03-26-2007 11:27 AM |
| Ceramic Tile and Rough Cut Lumber | jodiemeglio | Contractor Swap | 0 | 01-01-2007 11:37 PM |
| Help me out with a rough paint quote | Grumpy | Painting & Finish Work | 22 | 02-19-2006 04:53 AM |
