#61 | |
Trade: Construction
Re: Rotary Laser LevelQuote:
found the grade rod cumbersome and the audible receiver not precise enough. When I shoot a laser out, I can measure down from ledger to dot and have a number that works all the way around the house. Align the laser over my footings and I've got a measurement from footing to laser. Add those two and I've got total rise from footing to top of ledger. Then, it's just simple math figuring post heights. When I'm pullin' tape off the dot, I've got 1/8" margin of error, depending on size of dot. I usually measure from center of dot. When using the audible receiver, I've not been able to get a continuous tone for that tight of a tolerance. I'm perfectly willing to accept that my methods are stone-age (funny term seeing how we're talkin' about lasers!!) - do you have pointers for updating my process? Mac |
#62 |
solar guy
Trade: solar contracting
Re: Rotary Laser Level |
| The Following User Says Thank You to naptown CR For This Useful Post: | lou5577 (05-31-2009) |
#63 |
Trailer park boy
I only use the receiver if I'm grading a sloped driveway or something. If I'm laying out posts or anything like that it's the rotary laser line and a tape for me.
"Industry without art is brutality"
#64 | |
Builder/Remodeler
But for footers, excavation, grading, etc... audible is the only way to go.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
#65 |
Trade: Remodeling/building
Seeing the picture reminded me how much I hated working with Advance Forms.
#66 | |
The most accurate way to measure with a receiver is to move the receiver into the beam from above or below consistently from the same direction, when you get tone use that point. As you have found, the width of the beam and the "window" of on grade can make for a pretty wide margin of error, by essentially using the edge of the beam and the edge of the "window" you can increase the accuracy of the layout. |
#67 |
Most laser detectors have 3 settings for beam sensitivity.
Mine are fine .75mm or less than 1/32" medium 1.5mm or less than 1/16" Coarse 3mm or less than 1/8" |
| Best rotary laser | HemiMan2500HD | Tools & Equipment | 6 | 11-29-2007 03:12 PM |
| Rotary Laser | Tonkadad | Tools & Equipment | 5 | 02-12-2007 12:55 PM |
| Laser level for top plates on partition walls? | personalt | Framing | 3 | 11-12-2006 09:58 AM |
| I Need Some Laser Level Advice | needthingsdone? | Tools & Equipment | 13 | 11-11-2006 11:10 PM |
| Laser Level | reveivl | Tools & Equipment | 2 | 03-02-2006 01:18 PM |
