View Poll Results: How much do you usually load on your Roof Rack?
2-3 Ladders (~150 lbs.) 6 30.00%
150 - 300 lbs. 4 20.00%
300 - 450 lbs. 2 10.00%
450 - 600 lbs. 2 10.00%
600 - 750 lbs. 0 0%
> 750 lbs. 6 30.00%
Voters: 20. You may not vote on this poll
Roof Rack: Overloading?
Old 05-22-2007, 02:03 PM   #1
Jay Harding's Avatar
Trade: Electrician
I just recently purchased a Ford E-250 Cargo Van with a Utility Roof Rack rated to 800 lbs. How much can I load on the Roof Rack before it is dangerous? Ford and Chevy don't publish a maximum weight rating.
How much do you guys load on your rack typically? What's the most you ever loaded?
Jay Harding is offline
Old 05-22-2007, 02:27 PM   #2
widco's Avatar
Trade: --------
Re: Roof Rack: Overloading?
widco is offline
Old 05-22-2007, 03:58 PM   #3
Custom Builder
Glasshousebltr's Avatar
Ya gota draw the line right about here.
Bob
Glasshousebltr is offline
Old 05-22-2007, 04:16 PM   #4
The Deck Guy
Greg Di's Avatar
It really doesn't matter what the rated capacity of your rack is because I guarantee you have exactly no idea how much what you are putting on it weighs other than "a little" or "a lot".
I have bomber custom aluminum rack on my 3500 van and I've put 12 2x12x20 ACQ on it without a problem.
Greg Di is offline
Old 05-22-2007, 05:33 PM   #5
RobertCDF's Avatar
Trade: Custom deck builder
I put 36 very wet 2x6x16' PT boards on a rack rated for 500 lbs... The rack was fine. It dented the crap out of the side rails of my truck. The truck was sagging about the same as when I had 17 80# bags of concrete on it.
RobertCDF is online now
Old 05-22-2007, 05:50 PM   #6
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Four ladders at all times. Sometimes conduit along with them. Can't be more than 500-600# tops with some conduit.
I have a System One system on a van.
Speedy Petey is offline
Old 05-23-2007, 01:29 AM   #7
Palisade Point Const.
TempestV's Avatar
I don't have a roof rack, but my dad has a rack on his E350, and has had full bunks of lumber on it loaded with a forklift, with no problem. on another occasion, 24' curved gluelamb beams for a bridge. they stuck off each end and we had to flag them, but it wasn't a problem.
the only problem we ever had was cutting the banding to unload the bunk- if some of the boards fall back at you, stepping backwards is a 8 foot drop first step.
TempestV is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
