Ridge Board Support
Old 08-20-2009, 10:25 AM   #1
cpb123's Avatar
Trade: home improvement
Ridge Board Support
Hi, I am a HI contractor in MD. The bulk of my jobs are interior, finished basements, theater rooms, and I am adding a screened porch to my house 8'x13'. The house is early 1800, log walls and chinking covered in vinyl. I'm looking for a way to support the ridge board on the house side, it runs smack in the middle of the chimney, also early 1800, soft brick. I'd rather not run a single post from slab to bottom of the ridge. Any ideas?
Thanks,
Chas Burke
cpb123 is offline
Old 08-20-2009, 10:35 AM   #2
HSConstruction's Avatar
Re: Ridge Board Support
order a handful of trusses and be done with it. If you do interiors you will waste tons of time figurin' the rafter cuts.
What did the drawing spec that you gave to the Twp for the permit?
HSConstruction is offline
Old 08-20-2009, 06:00 PM   #3
mikec's Avatar
Trade: remodeling contractor
The rafters themselves will hold up the ridge. Are you using collar ties? Ceiling joists, or is it cathedrial? Hence the need to support the ridge.
mikec is online now
Old 08-20-2009, 06:19 PM   #4
cpb123's Avatar
Thanks Mike C, I thought they might, I'll use collar ties, as well
Chas Burke
cpb123 is offline
IS the ridge out of level? forsmant Framing 16 06-13-2009 11:12 AM
ridge vent boman47k Roofing 15 05-12-2009 09:06 AM
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 07:09 AM
Ridge cracked/splitting kydd3 Framing 42 11-21-2007 01:46 AM
1X Ridge Board, Cape Cod, 1934 Build sparkie5 Roofing 3 04-11-2007 09:32 AM
