Residential Wood Dock Piling Code
Old 05-08-2016, 07:42 PM   #1
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Building Contractor
Rewards Points: 1,380
I'm building a wooden 10' x 78' dock on fresh water with a neighbor, we are going to share it. I looked up the Florida building code, and dock piling codes aren't there. I then checked the ICC and found chapter 36 : Piers, Bulkheads and water ways.
This is the only thing I can find that states anything close to what depth of piling I need to have. I was assuming it was depth needed for dead and live loads of whats on top of the dock. In reading it, most of it is for uplift and depth to prevent it from floating away. Says 8' depth into soil minimum.
I am using the charts from the AWC prescriptive deck design for span charts on headers and joists but I was struggling to find something to back my choice and size of pilings for my drawing to present to the AHJ.
Anyone know of a chart that states depth and butt size of the wood pilings? DEP states we don't need a permit because it is residential and under 1000sq ft. Only permit we will need is from the building dept.
Builders Inc. is offline
Old 05-08-2016, 08:33 PM   #2
Dan_Watson's Avatar
Rewards Points: 2,470
Re: Residential Wood Dock Piling Code
Not an expert on driven pile but up here they sized based on a geotech report and installed to a certain bpf (blows per foot). I have never seen a chart that could be blindly spec'd from.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Oklahomatyler (05-30-2016)
Old 05-08-2016, 08:46 PM   #3
Yeah its clear as mud around here. There's the old rule of thumb for 1/2 in and 1/2 out length. If the water is 5' deep and the dock will be 5' out of the water then it needs to be 10' deep into the mud. But where did that come from. There's got to be some technical data supporting that old saying somewhere. Looks like i'll make some calls tomorrow. I have never seen a geotech determine soil capacities for a dock around here. Not for residential that is. Only time I would see that would be if there was a home sitting on pilings, not just a simple dock.
Old 05-08-2016, 08:50 PM   #4
hdavis's Avatar
Rewards Points: 9,099
Up lift and lateral loads. I don't know that there is anything prescriptive, but you should be able to look at sizing for other docks n the area, plus ask the BI what he's looking for.
hdavis is offline
Old 05-08-2016, 08:58 PM   #5
Dan_Watson's Avatar
Deep foundations are chapter 18 of the ibc.
Old 05-08-2016, 09:02 PM   #6
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 7,938
I'd talk to the inspector and see what he prefers.
Kowboy is offline
The Following User Says Thank You to Kowboy For This Useful Post:
sunkist (05-09-2016)
Old 05-09-2016, 11:52 AM   #7
Talked to the inspector and he said when it's not clearly stated in the code book I'll have to consult and engineer and have it stated what size and depth and how the graders will be bolted to the framing. They said usually an 8" top and half in and half out. But still need an engineer. Well there goes $350. Haha
The Following User Says Thank You to Builders Inc. For This Useful Post:
hdavis (05-09-2016)
Old 05-09-2016, 06:23 PM   #8
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,660
Talk to a dock builder see what he has to say
sunkist is offline
Old 05-09-2016, 09:05 PM   #9
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,120
Holy crap!! $350.00 bucks for engineering on a dock?
We would be lucky to get engineering on just about anything for less than $3500.00 around here.
Anyway, if Florida is like Calif. then docks are not covered under CBC. I am pretty sure they would be built by an A contractor/engineering company and not a B license GC.
This doesn't help but hell, my post count goes up for whatever that is worth.
Andy.
ScipioAfricanus is offline
Old 05-09-2016, 10:04 PM   #10
hdavis's Avatar
3 story deck and stairs plus a few internal structural changes to the building - $500.
hdavis is offline
Old 05-11-2016, 06:31 AM   #11
When you spend upwards of 10k a year with your engineer he cuts you a break for small stuff. Besides I can't pull permits for docks without a marine specialty license in Florida. But when it's a personal dock for my neighbor he'll just pull it. We're going to bind both parcels of land to ownership of the dock so we will have a larger dock that we can share. I've seen it before. It's formal name is a multi family dock. But if you saw how the land is shaped it makes sense to run it off a point of land that comes off his property.
hdavis (05-11-2016)
Old 05-11-2016, 11:05 AM   #12
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 1,440
May want to send Jaws a pm. He has built a few
TxElectrician is online now
Old 05-22-2016, 06:56 AM   #13
So we started jetting them down last weekend and it went good. Had a hand full that we couldn't break through the clay hard pan. It shows up in spots between 5 to 8' below surface in about 4' deep water. I was talking to a college who said to just break through a pin hole size of the hard pan and attach a fitting In direct line to your emt 9' lance with an air fitting. Then while your jetting you hook an air hose to the fitting and squeeze a lever to pulsate short burst of air into the water in the lance. He said it will add 120psi to your water pressure and blow up chunks of the hard pan. Kind of a super lance. We're gonna try it today.
hdavis (05-22-2016)
Old 11-09-2017, 10:59 PM   #14
Kumpel's Avatar
Rewards Points: 28
[QUOTE=Builders Inc.;4724761] I can't pull permits for docks without a marine specialty license in Florida. /QUOTE]
Hello
It is my understanding that any crc,cbc,cgc etc could perform as a marine contractor(in fl).
How did that dock turn out? Any pics?
Kumpel is offline
Old 11-11-2017, 08:39 AM   #15
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 304
Would love to see a picture of your super lance you came up with.
platinumLLC is offline
Residential Flat roof Nac Roofing 15 04-28-2018 08:46 AM
What Species Wood Should I Use? NC2X4 Carpentry Picture Post 23 04-19-2016 08:39 AM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 09:18 AM
International Residential Code test Broncoman72 Business 2 05-20-2009 09:22 AM
Residential code book Michaeljp86 General Discussion 11 12-03-2007 11:14 PM
