Replacing Stone Sill Under Existing Door
Old 01-11-2013, 05:32 PM   #1
pjh's Avatar
Trade: builder
How do I replace a stone sill under an existing door. The door threshold sits on the subfloor but overhangs the bond by about 1 1/2 inches so the stone should be snug to the metal threshold. I don't see how I can set the stone in mortar and still support the door. It seems like the sill will settle into the mortar and leave a gap. Any ideas? Should I fill with something? I really don't want to put in a wood filler.
pjh is offline
Old 01-11-2013, 06:08 PM   #2
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 7,866
Re: Replacing Stone Sill Under Existing Door
I'm not getting exactly what the problem is.
Joe
Kowboy is offline
Old 01-11-2013, 06:17 PM   #3
pjh's Avatar
Trade: builder
The door is already installed and there is 4 1/4 inches between the brick and the bottom of the door threshold. The sill is 4 inches thick so my mortar joint could be 1/4 inch. The sill weighs about 90 pounds and is 6 feet long. So I'm trying to stuff the sill in and still support the door. I'll probably end up pushing the wet mortar off when I set it and I don't see how I can get any support under the overhanging threshold. Hope that clarifies.
pjh is offline
Old 01-11-2013, 07:26 PM   #4
SSC's Avatar
Trade: Interior Remodeling Specialists
Hire a contractor to fix it
The Finest in Interior Renovations
SSC is offline
Old 01-11-2013, 07:30 PM   #5
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 772
You smell like a diyer/homeowner...but I will give a hint as to how you can do it. The hint is "tuck point tool".
overanalyze is offline
Old 01-11-2013, 09:07 PM   #6
pjh's Avatar
Trade: builder
I've been a contractor for twenty years but masonry isn't something I do that often. The trick is how can I get a tight fit between the stone sill and the threshold since the door is already in. Are you suggesting I pack the joint with mortar? It will also be a challenge to set the sill in place without wiping away the mortar - its long and heavy and I'll be working alone. But thanks for the hint.
pjh is offline
Old 01-11-2013, 09:10 PM   #7
SSC's Avatar
Picture would help
SSC is offline
Old 01-11-2013, 09:15 PM   #8
Always Learning
Rewards Points: 772
Put the stone in place dry. Use your flat bar to pry it up tight to the sill. Wedge some shims underneath to keep it up. Tap the shims back from the face 1/2 to 3/4". Use your trowel and tuck point tool to install the mortar bed.
thezoo (01-15-2013)
Old 01-11-2013, 09:15 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,252
How bout shim it in place w/ adhesive on top and semi dry pack underneath the stone. Pvc works well here.
supersealconstruction.com
superseal is offline
Old 01-11-2013, 09:19 PM   #10
pjh's Avatar
Trade: builder
Thanks. The light bulb just turned on.
pjh is offline
Old 01-11-2013, 09:20 PM   #11
pjh's Avatar
Trade: builder
Oh, what do you mean by Pvc?
pjh is offline
Old 01-11-2013, 09:28 PM   #12
SSC's Avatar
Tree fiddy
SSC is offline
The Following User Says Thank You to SSC For This Useful Post:
Jdub2083 (01-15-2013)
Old 01-15-2013, 11:59 AM   #13
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
I'd set it on shims and use a grout bag to mortar it in. Finish it off with a margin trowel and call it a day. Sometimes unless you're experienced, which is to be determined, it's harder to get a sufficient amount of mortar in the gaps with a tuck point tool.
Jdub2083 is offline
Old 01-15-2013, 12:42 PM   #14
thezoo's Avatar
Rewards Points: 238
I'd also use pvc shims made out of azek.
thezoo is offline
Framing addition - Matching existing roof plane ncornilsen Framing 18 01-11-2013 11:47 AM
Existing exterior door installation toolmantim General Discussion 2 09-29-2012 09:27 AM
warping barn door fix artinall Windows, Siding and Doors 6 06-09-2012 08:19 AM
Replacing a door sill DaHammer Carpentry 11 10-05-2008 11:17 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 09:28 PM
