Trade: Masonry restoration
Removing Old Caulk
I recently removed a mudroom entrance in the front of my house. There was a lot of caulk on the surround attached the the front which is red brick. I removed all the bulk material, but the outline is still
there, and ugly. Anyone have any suggestions or products that will remove the last fine remaining caulk without damaging the brick?
Trade: home builder carpenter Central Alabama
Re: Removing Old Caulk
soda blasting. You may end up doing the whole house though
You could try a stiff wire wheel on an angle grinder. I have done it a couple times with good results. Just try it in a small area first to make sure it dosen't scratch the brick.
Dave |
regular wire brush, scuffed brick.
Re: Removing Old Caulk |
Sweeper of fine saw dust
Trade: Project Manager by day, Cabinet maker for fun
goof off and a 5 n 1 it gets it pretty damn close
Yeh i was going to say goof off too. If you have some try it but if not or if it works and you run out go buy some lacqer thinner , same thing and cheaper.
Little late seeing this, but how about a heat gun and a wire brush?
will burn the new joints i repointed.
I see your point. It seems I have seen a product on the shelves that is supposed to help remove old caulk. I have never used it, so I cannot say one way or the other whether it actually works.
I used something off the shelves at home depot specifically for the removal of latex caulk. did nothing
Bigmo
Trade: Masonry Restoration and Repair
You may try to do a masonry stain over the bricks... especially if it is an old acrylic caulk. Usually a wire brush will scuff the surface and cause the white pigments to push deeper into the surrounding brick pores.
Stain and be done with it. |
| Removing old caulk | Teetorbilt | Painting & Finish Work | 22 | 03-14-2007 06:45 PM |
| Caulk flat panel doors in cabinets? | cstrombe | Painting & Finish Work | 8 | 02-25-2007 06:04 PM |
| Removing silicone caulk | ron schenker | Painting & Finish Work | 8 | 02-07-2007 08:33 PM |
| Ceder siding to caulk or not to caulk??? | Dave Mac | Painting & Finish Work | 10 | 05-26-2006 09:33 PM |
| Removing stain from a french door or replace? | Mike F | Painting & Finish Work | 6 | 03-22-2004 10:46 PM |
