Removing Fiberboard From Concrete
Old 05-19-2007, 01:16 PM   #1
metomeya's Avatar
I might be using the wrong term, but the fiberboard stuff that they put in concrete cracks.
I'm trying to get it out between the concrete patio and the house.
But I'm having a really hard time. Any tips?
metomeya is offline
Old 05-19-2007, 02:23 PM   #2
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Removing Fiberboard From Concrete
Just leave it there
Seriously though, why do you want to remove it?
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 05-19-2007, 03:34 PM   #3
Zero Punch's Avatar
Trade: Floors and more
Bust out the patio. I often have to remove some of this expansion material when preparing floors for VCT we either cut it on a vee from both sides at column pads. Not practical with a wall on one side then I use an old wood chisel but I don't try to remove all of it just 1/2 below the surface enough to level the floor with floor patch.
Zero Punch is offline
Old 07-25-2007, 08:40 PM   #4
metomeya's Avatar
Well the fiberboard is the badstuff, it bowed from the water and some of it is popping out.
Anyways we solved the problem by taking out what we could by hand, and removing enough so we could put in the self-leveling cement filler (polyurethane based i think) great stuff, we added sand to it while it was still wet, should last for a very long time.
metomeya is offline
Old 07-25-2007, 09:24 PM   #5
bryan305's Avatar
probably shoulda just put in some backer-rod and caulked the joint instead...The expansion joint is in there for a reason.
bryan305 is offline
Old 07-25-2007, 09:29 PM   #6
Rich Turley's Avatar
Trade: Residential Remodel
Sounds like that is what he did. Polyurethane is flexible.
Rich
Rich Turley is offline
Old 08-01-2007, 02:22 PM   #7
metomeya's Avatar
Ya, i did, took the stuff that warped too much out, and put backer rod, and left the stuff behind where i could as backer rod
really looks nice now, glad i did it
metomeya is offline
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
