Remodel Vapor/Air/Insulation Advice Needed.
I am trying to finish a garage attic on a very limited budget. and i am trying to use materials that i already have which is. 5/8 osb, tyvek house wrap, faced r 13 batt insulation.
here is what i was thinking tell me if you see any potential moisture problems or if it will be sufficient. remember this isnt going to be a space where anyone is going to live just a kids play room so i am just trying to keep some of the summer heat out and i will be buying a portable a/c. Batt the roof baffles, then put the tyvek on as an extra layer of insulation. (the batt is faced with vapor retarder) i could use poly plastic that way i wouldnt have to buy faced batt for the entire area. on the gable end walls there is currently vinyl siding and foam board... nothing else. i was going to put tyvek from the inside (so i wouldnt have to take down siding) then i was planning on putting the osb up and sealing all of the joints. then drywalling the whole thing. i am going to bring some air in from the garage below and have a small fan blowing some air out to keep from having too much stale air. kids wont actually be playing in this room. i just want it to up the resell value and i was thinking of growing some vegetables up there. any input would be great. |
Re: Remodel Vapor/Air/Insulation Advice Needed.
bumpp
Trade: Exteriors
growing some vegetables up there. Not a good idea. Up the resell value.
Absolutely maybe you should look into installing HRVs to condition the space better.
“Exteriors Done II Perfection” |
| Advice needed! | JLD | General Discussion | 32 | 11-05-2009 09:59 AM |
| GC Student, Advice Needed. | Underwood84 | General Discussion | 3 | 11-11-2008 10:35 PM |
| Advice Needed | realpurty2 | Technology | 5 | 04-03-2006 03:51 PM |
| Advice and wisdom needed | Mike Finley | Business | 10 | 05-13-2005 11:40 AM |
