Trade: underground
Reference Material Anyone?
I'm looking for a comprehensive listing of the unit weights (pounds by area or volume) for various building materials for the purpose of estimating demolition disposal quantities. I've been surprised by how hard it is to find unit weights for items like plaster on lathe, sheathing, brick and block work, flooring materials, siding, etc. Anyone know of a good source for such information?
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
#2 | |
Re: Reference Material Anyone?Quote:
[PDF] Characterization of Building-Related Construction and Demolition ... File Format: PDF/Adobe Acrobat - View as HTML amount of building-related C&D debris generated, on a weight basis. Tables A-1 through A-6. in Appendix A are worksheets that provide details of the ... www.epa.gov/epaoswer/hazwaste/sqg/c&d-rpt.pdf - Similar pages
Commercial construction
Trade: Commercial construction
Pipe,
Scan the list. Email it to me. My email address is on the contact page of my web-site. Reference material I've got. Stone/concrete 150 LBS/FT^3 Wood 28 LBS/FT^3 Steel 490 LBS/FT^3 PVC 90 LBS/FT^3 Aluminum 170 LBS/FT^3 Dry soil 100 LBS/FT^3 Water 62.4 LBS/FT^3 If you use this list, you can ballpark almost anything by using the most similar material on the list. For instance, figure dry soil as concrete or stone with air in it, wet soil as about the same as concrete. Loose plaster would probably be about the same as dry soil, etc... Residential construction from the sill plate up is seldom over 20 LBS/FT^2 of floor area (lifted a few, LOL). Quick way-take a 12" or 16" or 24" slice of the structure, parallel to the joists, add up what's in it from the footings to the ridge, and go from there. Don't forget the end walls... That should get you started. -Michael Last edited by mikesewell; 03-15-2007 at 03:52 AM. Reason: Meant "loose plaster." |
AFTERTHOUGHT...
Pipe, I know that YOU know this, but for other readers, dry concrete (solid) weighs about the same as wet concrete (liquid). |
Trade: underground
Thanks all of you for your feedback. Just in case your interested, I built a spreadsheet to estimate the weight of the structure. I broke down materials by CIS 'division' and here's what I came up with for this 28 x 35, 2-story, 1/2 basement, 1/2 crawlspace , no attic house with a single bathroom and 12 x 12 enclosed back porch:
29 tons of concrete (footings, area way, porch slabs and steps) 53 tons of masonry (foundation walls, 1st-story brick veneer, fireplace and chimney) 15 tons of wood 4 tons of dampproofing, insulation, siding, roof shingles, gutters and downspouts) 27 tons of finishes (plaster walls @ 10#/SF, ceramic tile, interior paint, pad & carpet) I got lazy and ignored the M/E/P debris. The house has been stripped pretty good of any salvageable copper and the HVAC isn't much more than a couple ducts. All tolled, thats about 130# per SF of footprint per floor (130 x 28 x 35 x 2).
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn Last edited by PipeGuy; 03-14-2007 at 11:50 PM. |
I will find my book tomorrow and post the name of it. You can buy it at Home Depot, where I got it. Its about a half inch thick and has every thing you can imagine listed by weight and volume. I think it was $6.95. And it is what I use to estimate dumpster weights during my demolition. Hope it helps.
Trade: underground
Thanks a bunch S/T. I'll look for your post.
Pocket Ref by Thomas J. Glover is a good one, find it at the check-out in hardware stores. It's published by Sequoia Publishing in Littleton, Colorado.
I wasn't figuring the 2nd story, or any masonry. Most of the stuff that we've lifted was built pretty light, that's why they needed so much work in the first place. The most we've lifted was 35#/FT^2 per floor from the sill plate up. Yours sounds a little heavy. Maybe you're figuring a little high to cover yourself? The last demo job I did was a 2 story post and beam barn about the size of your house. It had a 4' dry stone foundation, and was FULL of miscellaneous household type junk. It cost me about 8 grand total. Do you have to have asbestos monitoring? Last edited by mikesewell; 03-15-2007 at 11:25 AM. |
yep...thats the book. Good call.
Trade: underground
It's a small world. I have that one on my desktop all the time.
| deck material | smarks | General Discussion | 12 | 12-12-2007 03:59 PM |
| Material choice for fascia. | kclapper | Windows, Siding and Doors | 5 | 07-31-2007 11:14 PM |
| Opinion about material pricing | eXpatRioteX | Construction | 9 | 03-12-2007 02:53 PM |
| Question regarding surplus electrical material | solcam | Electrical | 2 | 07-25-2006 06:31 PM |
| Paying for material | 6stringmason | Masonry | 24 | 03-30-2006 09:10 AM |
