Random Lally Column
Old 11-23-2008, 08:35 AM   #1
wjsibley's Avatar
Trade: construction/finish carpenter
Question
Random Lally Column
Have a non-anchored lally in middle of 11' run under a 3 1/2" by 9" engineered wood laminated beam. One end of the run is supported by a lally that is properly installed w/ footing below poured 4" floor & the other end supported with vertical wood structure of exterior wall of house. The middle lally is out of plum and simply rests upon bottom steel plate. Haven't found MASS bldg code reference to determine if middle lally is necessary. Any thoughts? Also, any recommendation on how to trim-cut steel lally plates?
Thanks,
WJS
wjsibley is offline
Old 11-23-2008, 08:51 AM   #2
genecarp's Avatar
Re: Random Lally Column
genecarp is offline
Old 11-23-2008, 09:56 AM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
Torch rig maybe a little water afterward
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 11-23-2008, 09:59 AM   #4
One would have to guess that
it wasn't simply being stored there.
Someone at least thought it
was necessary.
I would get someone knowledgeable
to take a very close look at it, and
what is above it.
neolitic is offline
Old 11-23-2008, 06:34 PM   #5
Aframe's Avatar
Trade: Carpenter/GC
The building code won't tell whether or not it is needed. Bring an engineer in to calculate load and he can tell you.
Is there a post that comes down on top of the beam in that location?
Aframe is offline
Installing a Lally Column BCFBeacon Construction 22 03-13-2009 08:54 PM
Replacing lally column tomk15 Framing 14 03-06-2008 07:30 PM
Remove Lally Column? zslavin Construction Picture Post 7 12-05-2007 10:50 PM
Lally column footer depth Second Look Construction 12 04-01-2007 12:29 AM
Installing lally columns osborneconst Construction 10 12-13-2006 08:57 PM
