Putting Vinyl Over Masonite
Old 09-29-2007, 11:28 PM   #1
Michaeljp86
Guest
Michaeljp86's Avatar
Posts: n/a
If you had to put vinyl siding over masonite how would you do it? Im not doing it but some guy is on a house Im working on and Im not sure he knows what hes doing.
Old 09-30-2007, 12:02 AM   #2
Patrick
Guest
Patrick's Avatar
Posts: n/a
Re: Putting Vinyl Over Masonite
3/8" or 3/4" foam and then the siding. the cheap guys wont bother using foam though and will put the siding right on top of the Masonite
Old 09-30-2007, 06:33 AM   #3
PA woodbutcher
Guest
PA woodbutcher's Avatar
Posts: n/a
That masonite is fun ***** to drive an aluminum nail through ain't it!!!. We have a plant 8 miles from my house that used to manufacture masonite. They used to offer factory second sales to their employees every 3 or 4 months and everyone knew someone who worked there....it's everywhere! Usually the masonite is covering clapboard siding underneath. I like to peel at least the masonite off, foam board or insulation and then do the siding. Makes it a whole lot easier to wrap the windows and make it look decent. In the grand scheme of things, how long does it really take to strip a layer of masonite?
Old 09-30-2007, 09:07 AM   #4
Patrick
Guest
Patrick's Avatar
Posts: n/a
Its not the stripping of the Masonite thats the issue, its the carrying of the Masonite a few pieces at a time to the trailer thats the problem. We stopped using aluminum nails in favor of electro galvs. Too many busted fingers. With the window and trim wrap system that we use it doesn't matter how many layers are on there as long as they are intact.
Old 09-30-2007, 03:07 PM   #5
Michaeljp86
Guest
Posts: n/a
This house has 3/8" plywood under the masonite on 1/2 the house and the other just has that old sheet insulation, that brown black junk lookes like its made out of cardboard.
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Siding over Masonite fxdfast Windows, Siding and Doors 4 08-24-2007 04:34 PM
putting latex on vinyl shutters Traditions Painting & Finish Work 18 06-22-2007 01:16 PM
Scalloped Vinyl Shamrock Windows, Siding and Doors 1 09-18-2006 04:20 PM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
