Trade: Concrete
Putting In A Coberstone Patilo
I have a 25' X 25' patilo that I want to replace with a Coberstone brick and would like to know how mant brick it would take, useing the big or the small size? Which is better to use?
Also I would like to know how deep one should go with the graveal and sand? I would like to know what a project like this would cost if I would let someone do it or what it would cost if I'd do it? Frist off I would have to take out the concreate for it is cracked and stickes up. I am open for suggustionon how and what would be best to do this project.
Thom
Re: Putting In A Coberstone Patilo
What's a Coberstone Patilo
Trade: Masonry consultant
Go to a good landscape/hardscape supplier to pick out a pattern and color you want. They will figure our how man stones to order and how much edge restraint you will need for the edges.
Get a contractor to tear out the old concrete and get rid of it. You paver supplier can give you the names of good contractors. You will also probably need 4" - 6" of compacted base and a 1" sand setting bed. After you set the pavers, you should sprinkle masonry sand on the surface and vibrate the sand between the joints and level the pavers.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
Trade: Remodeling contractor
Call a professional contractor and get an estimate.
Complete Custom Remodeling "When Quality is Top Priority" www.completecustomremodeling.com |
#5 | |
Commercial construction
Trade: Commercial construction
Re: Putting In A Coberstone PatiloQuote:
leahcim- Last edited by mikesewell; 05-13-2007 at 10:27 PM. |
Trade: Outdoor contracting: fences and decks
Could that possibly be.....cobblestone?
Insert title
Trade: Doors-Windows-Decks
Steve, it has 2 b's....as found on google
Lindenhof as oldest park of the city isn't as spectacular as one might think but the view is fantastic. Being lucky, you can see the Alps in the distance behind Grossmuenster. The way up the place is quite nice to, again with some cobberstone streets and well-restored buildings. With crossing the Limmat and getting closer to Bahnhofsstrasse, you'll know more and more why Zuerich's way up the list of the most expensive places in the world.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Yet another carpenter
Trade: Carpenter Woodworker
Man, I ain't never mispeling anythig in this furom agaen. Yuo guies ar bruttel.
Carpentry and Woodworking - Chicago / North Shore - Ted's Carpentry "I don't know everything but at least I think I do, and that's what really matters."
#9 | |
Maybe I shood try hooked on fonnix... |
#10 | ||||||
#11 | |
You guys are a lot of help...but your posts are cracking me up. ConcreteMasonry gave the only real answer and he is dead on.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
Trade: Concrete
THE FUN IS OVER FOR NOW
i HAVE ASK IF ANYONE EVER PUT IN A COBBLESTONE (DUTCH) PATIO AND i WAS HOPEING THAT THERE WOULD BE SOME BRIGHT PERSON ON HERE THAT HAD PUT ONE IN, I AM SORRY THAT i EVEN ASK THIS QUESTION. HOPEFULY THERE IS A BRIGHT PERSON ON HERE THAT HAS PUT ONE IN? |
Re: Putting In A Coberstone Patilo |
#15 | |
Insert title
[QUOTE=SHORTGUN;240453]THE FUN IS OVER FOR NOW
i HAVE ASK IF ANYONE EVER PUT IN A COBBLESTONE (DUTCH) PATIO AND i WAS HOPEING THAT THERE WOULD BE SOME BRIGHT PERSON ON HERE THAT HAD PUT ONE IN, I AM SORRY THAT i EVEN ASK THIS QUESTION. HOPEFULY THERE IS A BRIGHT PERSON ON HERE THAT HAS PUT ONE IN?[/QUOTE] If they are anything like cobblestone streets they are not comfortable to walk on. If you end up doing your project post some pictures and get some feedback from your client. How would chairs and such sit properly on rounded stones?
The termnology for "cobblestone" is not uniform everywhere.
Cobblestone pavers have more to do with the pattern and the rounded edges on the pavers. They are not perfectly flay with absolutely square corners. Some are tumbled to get an antique appearance since they are manufactured with a relatively flat top and a vibrated with a flat plat vibrator. Due to the iregulatities, they are not normally used for heavy duty installations like streets and industrial areas because the strength developed by the interlock is not as great as the more regular units. They are completely adequate for patios, sidewalks and driveways.
#18 | |
| Is there a "REAL" problem with putting tile on a sub floor? | Project53 | Flooring | 20 | 06-16-2008 05:03 PM |
| Charge for putting up paneling... | craftyman | Remodeling | 10 | 02-09-2008 02:35 AM |
| putting latex on vinyl shutters | Traditions | Painting & Finish Work | 18 | 06-22-2007 01:16 PM |
| What is the lowest pitch roof everyone is comfortable with putting in a skylight? | mikeybobo | Roofing | 10 | 03-03-2007 11:34 AM |
| Putting in for the Moderator | A+Carpenter | Site Help and Suggestions | 11 | 03-01-2006 02:00 PM |
