Propane Tank
Old 11-14-2005, 10:08 AM   #1
kpikul's Avatar
Propane Tank
I have a 100 pound propane tank the was filled for the first time a couple days ago.
It is in my yard and has yet to be hooked up to the ventless gas fireplace.
I went over to the tank this morning and there was a propane smell in the air. I was told it was the relief value expelling some pressure. Does this sound right? If so, how often does it usuall happen?
kpikul is offline
Old 11-14-2005, 10:39 AM   #2
Teetorbilt's Avatar
Re: Propane Tank
There is a relief valve and it may release some gas due to temperature changes, that is why it's there. This usually occurs soon after filling and will subside in a day or two or after you use some of the gas.
Albert Einstein
Teetorbilt is offline
Old 11-14-2005, 11:12 AM   #3
kpikul's Avatar
Re: Propane Tank
Thanks, Tettorbilt,
So this is nothing to be concern about it and it may release some more over the next day or two?
kpikul is offline
Old 11-14-2005, 08:56 PM   #4
theman's Avatar
Re: Propane Tank
Kaikul how far is this tank from the house and property line
theman is offline
Old 11-15-2005, 11:06 AM   #5
kpikul's Avatar
Re: Propane Tank
I moved the tank to a shaded area on the other side of the garage. It is a few feet away from the side of the garage and around 15-20 feet from the property line.
I think moving the tank may have done the trick. I talked to the company who filled the tank and they told me it was either the sun raising the temp of the tank or it was a bit overfilled which causes the relief valve to expell some vapors.
kpikul is offline
Propane vs Oil Trueheat HVAC 10 09-27-2011 03:08 PM
Propane tank relocation... ruskent HVAC 4 03-19-2007 01:05 AM
Oil Tank KGB HVAC 1 03-18-2007 08:54 PM
Use of Propane naturenut HVAC 9 01-21-2006 09:33 PM
oil tank location question Vermonster HVAC 3 10-19-2005 09:14 AM
