Trade: custom homes and renovations
Problem: Converting Deck To Floor - Insulating
Having an issue deciding how to best insulate a second storey 12 x 12 deck floor that will be converted to additional living space. We need to insulate the floor system in the best way possible as we live in a cold climate and the area under is unheated/outside.
The floor will not have heating ducts running through it as we can use alternate (electric bb ) for that area or a gas f/p . Best methods????? |
#2 | |
General Contractor
Re: Problem: Converting Deck To Floor - Insulating
You should visit DIY chat room, this site is for proffessional contractors only.
Good luck. Quote:
solar guy
Trade: solar contracting
how about installing insulation?
haha . Thanks , but that was a given. My issue is not wether to insulate - but proper ammount and method , placement of vapour barrier etc.
Since the deck joists are 2x10, my understanding is that if I use a spray foam and completely fill the joist cavity, it also acts as the vapour barrier - but how about cost?? It should be warm enough. Alternately, If i use batt insulation and fill the void completely, should I then install a rigid polystyrene to the underside ? This puts the Vapour barrier on the cold side which is not recommended???? |
solar guy
Check with the IRC and leeds. Then go back to the diy room The last post proves you are not a pro
#6 | |
General Contractor
I would use a GOOSE DOWN COMFORTER Blanket to get that warm and cozy feeling in the winter time, I wouldn't worry about anything else.
| new tigerwood deck -- boards with fuzz, green-yellow tint? | andywocky | Decks & Fencing | 32 | 08-20-2009 04:10 AM |
| How to put roof over existing deck | JohnHomeMatters | Decks & Fencing | 16 | 06-25-2009 04:23 AM |
| Red Oak on a deck??? | Nailerconstruct | Framing | 9 | 05-17-2009 08:14 PM |
| Deck rehab | Static Design | Painting & Finish Work | 7 | 05-01-2009 03:49 AM |
| wood deck question ???? | davinci | Decks & Fencing | 30 | 10-02-2008 07:07 PM |
