Post A Picture Of Your Current Job -- Part II
Old 07-06-2018, 09:16 PM   #10041
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,382
Re: Post A Picture Of Your Current Job -- Part II
Working with META for the next couple weeks
A&E Exteriors is offline
The Following User Says Thank You to A&E Exteriors For This Useful Post:
asevereid (07-07-2018)
Old 07-07-2018, 12:03 AM   #10042
GC/carpenter
Californiadecks's Avatar
Rewards Points: 9,274
Originally Posted by Leo G View Post
Got them installed today. We got to the house just in time for the skies to let go. Good thing I finish most sides. What did get wet was dried off in 15 minutes with a fan blowing on it.
Really good that they were in small pcs. Never would have gotten them up the stairs and around all the corners. Got a little worried with the 36"x 92 1/2" face frame, but didn't have any issues.
Brought 3 of my Husky folding benches and some moving blankets. Put the face frame on top of that and then each cabinet one at a time. Brought some 24" squeeze clamps to keep things put while driving the pocket screws. Pocket screwed the left and right cabinets all the way around, top, middle and bottom. The center cabinet I put glue on the left and right side biscuits and pocket screwed the top, middle and bottom. Kept the clamps on the sides for 25 minutes while we took a break.
After that I made sure the face frame would be straight. Had to add a layer of blanket on the middle Husky bench to get everything perfectly straight. Then we put the back on and screwed it together. Took the cabinet off the benches and then flipped it on its back and put the full length toe kick on.
Then all that was left was to slide them it place. Fit like a glove. Two 4" screws through the floor at either end of the drawer cabinet and 2 screws into the right stud. I took the hinge plates off, drilled a countersink hole and put 2" screws in. Put the hinge plates back on and hung the doors. Then put the drawers in and adjusted them a little to make them perfect. Total length of the cabinets is about 134".
Went smoother than I figured. Unusual.
Oh, and the little Milwaukee fan worked great.
You learned all that from my office thread dint ya?
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
Xtrememtnbiker (07-07-2018)
Old 07-07-2018, 07:20 AM   #10043
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 901
What'd I learn?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 07-07-2018, 11:04 AM   #10044
GC/carpenter
What'd I learn?
All that. Everything.
Mike.
_______________
Old 07-07-2018, 11:38 AM   #10045
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 901
I don't remember learning anything
Carpenter by day.
http://lrgwood.com
Leo G is online now
Californiadecks (07-07-2018)
Old 07-07-2018, 09:14 PM   #10046
Hack
asevereid's Avatar
Rewards Points: 644
Same ****, different day... Going to move down to the first floor in this project by the second or third day of next week.
Contact wording issues are now muddying the scope of work to be completed. If I continue to work based on the original agreement, I can be off of this project by the end of next week... If it goes in to the expectations of the GC (upon approval of payment), then I may be able to get out of here within two weeks.
More arborite, more plain Jane trim, more door hardware...
And... Does dummy hardware really need to be that complicated? I swear... This door and hardware supplier has no foresight in to how their products get installed with the slabs and jambs that they provided.
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
The Following 2 Users Say Thank You to asevereid For This Useful Post:
Californiadecks (07-07-2018), SmallTownGuy (07-08-2018)
Old 07-10-2018, 09:41 PM   #10047
Really enjoying this little change of pace.
asevereid (07-10-2018)
Old 07-10-2018, 11:00 PM   #10048
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,044
Looks good, any reason the old roof and new one aren't tied in so there is not going to be that crazy side wall to roof valley?
Randy Bush is offline
Old 07-10-2018, 11:05 PM   #10049
Because that's what is shown on the plans is the only good answer I have
Randy Bush (07-11-2018)
Old 07-10-2018, 11:12 PM   #10050
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 344
How do you even do that properly?
I have an Edifice Complex.
Old 07-10-2018, 11:37 PM   #10051
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 206
Flat roofing membrane of some kind. TPO, Carlile, Duro-Last ext. Run the membrane up both sides about 2ft and then shingle and side over it.
Designed2Fail is offline
Old 07-11-2018, 12:59 AM   #10052
6/12 full width cricket/ saddle
Seven-Delta-FortyOne (07-11-2018)
Old 07-11-2018, 06:43 AM   #10053
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,776
Incompetent “architect”.
The new roof is higher than the old and he probably didn’t know how to deal with that so he left it up to the framer to figure it out n
Big Johnson is offline
Old 07-11-2018, 06:47 AM   #10054
This idea is just like your name.
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
A&E Exteriors (07-11-2018), Designed2Fail (07-11-2018), mrcat (07-11-2018)
Old 07-11-2018, 07:15 AM   #10055
Randy Bush's Avatar
Originally Posted by Big Johnson View Post
Incompetent ďarchitectĒ.
The new roof is higher than the old and he probably didnít know how to deal with that so he left it up to the framer to figure it out n
I have had to deal with that before, not real hard to do .
Old 07-11-2018, 07:23 AM   #10056
The Sheriff
Jaws's Avatar
Rewards Points: 6,744
I've actually run into Andy situation a couple times here when when building off of other people's plans, did you consider sending the designer an email asking if you could just tie the roof into the other roof? Does not look like it would be an issue to do so and would be a lot better for you
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 07-11-2018, 07:28 AM   #10057
Itís pretty common but itís nice if the plans show the transition, that way when you order trusses youíll get all of them and there will be less stick framing.
Old 07-11-2018, 10:09 AM   #10058
Trade: Builder/GC
Rewards Points: 344
That's what I always figured.
Imagine it looks a little funny. But no one is ever gonna see it.
Old 07-11-2018, 10:15 AM   #10059
I did not. This isnt my circus. Just here to lend a hand.
I dont mind raftering at all.
Definitely looks funky.....looks good from my house though.....lol
The Following 4 Users Say Thank You to A&E Exteriors For This Useful Post:
Jaws (07-11-2018), Randy Bush (07-12-2018), Seven-Delta-FortyOne (07-11-2018), SouthonBeach (07-11-2018)
Old 07-11-2018, 10:17 AM   #10060
KAP (07-11-2018)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 11:24 AM
Picture post??? Kim1181 Flooring 2 03-09-2004 03:10 PM
