#961 | |
Handle It!
Re: Post A Picture Of Your Current Job.Quote:
.Jeeeess! Have you not figured out out how to make this process turn out correctly and beautifully yet. Such a novice!.
#962 |
Re-use of the existing header.
My foreman re-framed it the way it was prior. - Can't tell you why they originally framed it that way (change in slider door width?), but we're not going to change around existing header-framing on a repair job, unless there is something wrong with the strength/design of it.
- Build Well - |
#963 | |
I think what the question is pertains to the 2 kings a 5 jacks, nothing to do with the header, instead of 5 jacks, 1 or 2 jacks could have been used, followed by 4 1/2'' bay, then another 6'11'' stud under the header. This would have been fine, would have saved 3 sticks, unless of coarse there was a point load as someone mentioned..No big deal, either way, G
#964 | |
Capra aegagrus
![]() BTW, how do you handle delivery & installation of an 800 lb top? Lotsa guys doing the Mrs. Whiggins shuffle, an engine hoist or what? |
#965 |
I like Green things
Gene- That swiss made mixer hanging in the back ground, is that thing worth a hoot? Only reason I ask is, I saw one the other day at a pawn shop for 125.00 bucks. I always wanted a mixer.
#966 | |
No problem. It's a $15K original water damage repair job, that turned (grew into) $50K+ in repairs (Structural rot). So, I could care less about the cost of an extra few 2x KD studs. As long as the work is getting done by the workers, it passes inspection, and we are making decent profits = it's all good.
- Build Well - Last edited by AtlanticWBConst; 04-06-2009 at 07:59 PM. |
#967 | |||
Trade: General Contracting
http://brianwilsonconstruction.net |
#968 |
Here's a couple of shots of one of our current projects.
We we're waiting for the weather to break before we finished cutting into the old house.
https://www.facebook.com/pages/John-...94183374011504 |
#969 |
YES, its a brute, good for small vanities, sample tiles etc...they do get tired, so be careful for $125, it may be at the end of its life. G
#970 |
Re: Post A Picture Of Your Current Job.Combination, hit the top with a quick 2000, then applied 7 coats of sealer, we also poured it on plexiglass. (the real secret to a shine)
#971 | |
We have a great cart, goes from flat to inverted, 4 nice air filled tires, handles 2000 lbs. i will show you a photo. its a pleasure to work with. G
#972 |
We're pretty much finished now,and will update with more shots once I get back out there.
It's not quite like the plans we received.The front was suppose to be a 12 pitch from the ridge to the first floor joists,but there was so much buried space that could be used we did a couple of alterations. We gained about 250sq/ft of living and storage space for the HO,including a two walk in closets ,and an extended hallway, which allowed the bedrooms to be larger and got some natural lighting into an otherwise dark area. The addition was for two bedrooms over a 1 1/2 car garage and extended kitchen. It seemed like a lot of work and expense (with all the jogs in the floor plan)so we chucked the plans when we got to the second floor and roof line.
#973 |
I did concrete for my kitchen here. I put a bunch of good (? expensive) grout sealer on it because I liked the more rustic look of a penetrative sealer, rather than a topical one. But I have a lot of staining from acidic liquids and am thinking about putting something else on them. What product do you use?
#974 |
Capra aegagrus
Re: Post A Picture Of Your Current Job. |
#975 | |
here is the cart http://concretecountertopplant.com/cart-1.html http://concretecountertopplant.com/cart-2.html second one is the big top.
#976 | |
USG #1, expensive but worth it, we put a penetrative on first, followed by topical. PM me if you want full finishing info.. you will need a good stripper for your situation as well.
#977 |
Capra aegagrus
#978 | |
Handle It!
WOW!!! I want MY web video to be just like that one!!!! Nice cart!!! But WHAT THE EFF were they thinking when they made that presentation?
#979 | |
egotistical prick
Trade: Wood Inlay
#980 |
LRG WoodCrafting
He's to busy making money!!!
| Picture post??? | Kim1181 | Flooring | 2 | 03-09-2004 04:10 PM |
