Pole Barn Per Sq Footage
Old 08-11-2009, 12:00 PM   #1
lucero's Avatar
Trade: Lucero Construction, Inc.
I
lucero is offline
Old 08-11-2009, 12:06 PM   #2
Bob Kovacs's Avatar
Trade: Consultant
Re: Pole Barn Per Sq Footage
Well, let's see....
- Is it 1,000sf, or 100,000sf?
- 10' tall or 40' tall?
- What's the exterior wall finish?
- Is it heated/cooled?
- Electrified?
- Is there a slab on grade?
- What's the scope of sitework around the building?
Answer those questions and around 100 others, and we can narrow the range down from $15-$150/sf.
Bob Kovacs is offline
Old 08-11-2009, 12:12 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 962
The answer to your question is a definite YES!!
Someone CAN tell you.
I hope that I have been of some help here.
My work is done.
Andy.
ScipioAfricanus is offline
Old 08-11-2009, 12:42 PM   #4
lucero's Avatar
aaa
lucero is offline
Old 08-11-2009, 12:50 PM   #5
Bob Kovacs's Avatar
Trade: Consultant
OK, that's a small one- should be somewhere between $15/sf and $90/sf. Hope that helps!
The Following User Says Thank You to Bob Kovacs For This Useful Post:
lucero (08-11-2009)
Old 08-11-2009, 01:11 PM   #6
lucero's Avatar
thanks
lucero is offline
Old 08-11-2009, 01:44 PM   #7
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Rewards Points: 1,000
Better use the "search" function to develop a better understanding about this question on this site...
~Matt
BreyerConstruct is offline
Old 08-11-2009, 02:08 PM   #8
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Rewards Points: 2,000
I'm 1st! I get to say it 1st! Tree Fiddy! Ha,, ha!!!
Cdat is offline
Old 08-11-2009, 02:12 PM   #9
Treeandland's Avatar
Trade: Landscaping
Rewards Points: 75
I thought maybe just maybe this would be a different kind of sq. ft. question like how many cows or chickens can you fit per sq. ft. or something.
Treeandland is offline
Old 08-11-2009, 02:14 PM   #10
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Do you have a license or is your team a bunch of illegals? Makes a big difference you know?
Cdat is offline
Old 08-11-2009, 02:17 PM   #11
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
Congratulations. You are now a member of the Tree Fiddy First Club (T.F.F.C.).
strathd is offline
Old 08-11-2009, 02:32 PM   #12
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
Originally Posted by lucero View Post
Thanks for the help. We do not have to supply materials or anything else. We are submitting a subcontracting bid on this one and there is no concrete. Just the erection part of the pole barn. So what would the average rate be per sq. footage?
Well if you take $15 and $90 that gives and average of $52.50.
ChainsawCharlie is offline
Old 08-11-2009, 02:34 PM   #13
Crash Test Dummy
Trade: Landscaping
This pole barn is 16'x120' x 16' high. I generally only bid on ag confinements and this one has come along.
You have three dimensions there...maybe you should bid it in cubic feet.
The Following User Says Thank You to ChainsawCharlie For This Useful Post:
ampman (08-11-2009)
Old 08-11-2009, 02:58 PM   #14
mics_54's Avatar
Trade: contractor
Hmm well if you don't have to supply materials or anything else...
I would say $0.00 plus tax. with a bonus for early completion. Do you have any openings? I can do nothing from here on a retainer. I haven't done nothing in quite some time but I'm a fast learner. If you need nothing done immediately I can drop what I'm doing if the remuneration is good.
BTW I am currently licensed and insured but I can drop my policy and license if that's a problem.
mics_54 is offline
The Following User Says Thank You to mics_54 For This Useful Post:
Chris G (08-11-2009)
Old 08-11-2009, 03:38 PM   #15
lucero's Avatar
for
lucero is offline
Old 08-11-2009, 03:48 PM   #16
Bob Kovacs's Avatar
Trade: Consultant
There is no "average going rate for certain areas"- only you can determine what the right number is for you. You say you've done work like this before, so figure out how long it'll take your crew to do the job, multiply by the cost for your crew, add for equipment you may have to rent, and then add for overhead and profit- that's what you need to charge to do the job? If you followed that process and came up with $15/sf, and someone told you the "going rate" was $10/sf, would you lower your price to $10? I'd certainly hope not.
Old 08-11-2009, 03:49 PM   #17
Crash Test Dummy
Trade: Landscaping
I thought this was a help someone out kind of chat. Not someones stupidity remarks. For those of you who can reply with a decent answer, thank you. I was just needing asistance from someone with knowledge on this type of barn. I am not needing the bid from ground up, just for the erection of the pole barn. Is there somewhere I can go to get the average going rate for certain areas.
I think this site assumes that the people posting here have at least a basic understanding of running a contracting business. Knowing how to bid bieng first and foremost part of that business.
No one can help you with a going rate, as you and only you (or maybe your accountant) can know your overhead.
And labor only still has it's overhead. Comp, liability, payroll taxes...and you still have to cover overall expenses of the business with that "labor only" bid-shop rent/mortgage, utilities, vehicle expenses...
You need to make money to keep your business going. Even if you are doing labor only contracts.
Old 08-11-2009, 04:08 PM   #18
mics_54's Avatar
Trade: contractor
Dude...how many times to you need to be told you didn't give enough information in your question to answer it. Be reasonable. Giving us the dimensions of the building is not enough information.
What equipment will be available?
Whats the pitch of the roof?
How is the roof structure designed?
Are there eaves?
What type of poles?
What if any are the time constraints?
I can design a building of those dimensions and tell you what *I* would charge but it would have NOTHING to do with your building.
Now you can cop a tude or you can give us more information. What you gain from the time you spend asking people for HELP depends on how willing you are to to learn.
mics_54 is offline
lucero (08-11-2009)
Old 08-11-2009, 04:13 PM   #19
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
If you reflect on your original Post and follow up you might understand the heat.
To begin with the "How much" question get's you heat period!
Followed by a non-descript "poll barn". MANY on here have no F'n clue what a poll barn is past a Google search.
I grew up in the Mid-west and even have relatives in Kansas. I have seen ALL kinds of poll barns some elaborate same plane jane. Some made of telephone poll sized "polls" some steel polls. Some dirt floors some concrete. Some partially enclosed some just a roof. SEE?
The answer remains the same (as pointed out) do a material TO add your % of mark up use an average of what it takes you to do other ag buildings and tack a % on.
We don't know your overhead or the speed/size of your crew. Do you have a skid loader with an auger attachement or a tractor? Do you have/need a boom lift? etc.
If it's your first you'll know the learning curve for the next!
jtpro is offline
The Following User Says Thank You to jtpro For This Useful Post:
lucero (08-11-2009)
Old 08-11-2009, 05:18 PM   #20
W-Tinc's Avatar
Trade: Student
Rewards Points: 250
Crap!! I read this well before Cdat posted and considered giving the correct answer. But being somewhat of a lurker I decided to pass.
It could have been me joining the club today!!@#$%^.
I am going to redouble my efforts and not miss another opportunity like this
W-Tinc is offline
Pole Barn Garage mrmike Carpentry 26 10-28-2009 08:29 PM
convert pole barn into house kalefarmer Construction 5 07-06-2009 09:07 PM
Pole Barn Framed Garage? J-Peffer Construction 12 05-25-2009 08:49 AM
large slab in pole barn tomscarpt Masonry 17 04-04-2009 04:41 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
