Play In Tandem Axle Trailer Spring Shackles?
Old 11-14-2009, 10:15 PM   #1
bob_cntrctr's Avatar
Trade: renovator
Gentlemen,
I have a tandem-axle utility trailer for hauling material. Yesterday I had ~60 sheets of drywall on it and I was turning tight in the parking lot, when I noticed that the wheels appeared all out of alignment. Toe, camber - a mess. I thought one was about to fall off, or that the bearings were gone. But when I straightened out, wheels went back in line.
So today I lift it up on stands, all wheels off the ground, and check it out. And I discover that there's a whack of play where the leaf springs are bolted to the frame. That is, at the end of the leaf springs the spring is rolled into a cylinder, it slips into a yolk, and a bolt passes through to hold it there. On a truck, there's a bushing in there to eliminate play and insulate vibration. But on my trailer, no bushing, and the bolt is a good 1/4" smaller diameter than the passage in the leaf spring.
So it's easy to imagine that under the strain of ~4,000 lbs of drywall and a tight turn, the plays in these linkages added up to some out of alignment of an axle during the turn.
OK, mystery solved - my question is this:
Is this common to tandem-axle trailers? Maybe intentional so the wheels go along with tight turns? Or are there supposed to be bushings in there and they've disintegrated?
It runs straight as an arrow on a straight-away; zero drift on the highway. Which is why I never noticed this before.
Any part-time wrench turners out there who've disassmbled their tandem-axle trailer's suspension?
Thanks.
bob_cntrctr is offline
Old 11-14-2009, 10:38 PM   #2
hughjazz's Avatar
Trade: carpenter
Re: Play In Tandem Axle Trailer Spring Shackles?
yes there is definitly supposed to be some nylon bushings. similar to the ones in the pic http://www.princessauto.com/truck-tr...-equalizer-bar
Brass bushings may be available
There are usually kits available that will supply new
spring bolts
equalizer arm/bar
bushings
and shackles.
The kit will supply basically everything except new springs and mounting brackets.
I highly recommend looking into this.
There is a good chance that if the bushings are gone, the shackles are warbled out, And the spring bolts are flattened out.
Also, is a good idea to avoid real sharp turn in a tandem axle, even in a new trailer the tires will try to turn opposite directions.
It makes sense when you think about it. The fulcrum is between the 2 axles. pushing out on 1 tire and pulling in on another..
Even dump trucks experience this effect.
It should take no longer than 3-4 hours to replace all the parts, a grinding wheel or a recip saw with a metal blade will help immensely.
hughjazz is offline
Old 11-15-2009, 11:04 AM   #3
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
None of my trailers have bushing on the rear of the springs.
I don't remember any bushing on the front either , but cant see them now.
My equipment trailer doesn't even have a bolt ! The spring just rubs on the bracket and there in a plate that stops it from sliding out .
"The front is bolted . If my trails are loaded the tires get out of whack on a turn . Sharp turns wear the tire fast try not to turn so fast.
wellbuilthome is offline
Old 11-15-2009, 06:04 PM   #4
dkillianjr's Avatar
I posted about this same thing happening to my trailer a little while back. wheels do the same thing and I believe thats normal. I'll have to check, but I think mine dosen't have any bushings either, I'm not positive though. Heres the thread. What kind of trailer is it?
http://www.contractortalk.com/f41/ta...estions-64212/
dkillianjr is offline
Old 11-15-2009, 07:34 PM   #5
mikeswoods's Avatar
Trade: interior remodeling
Most spring shops are very helpful (at least mine is). I think it might by well worth the trip.
Broken down with a 4000 pound load-sounds like a bad day!
mikeswoods is offline
Old 11-15-2009, 08:29 PM   #6
I like Green things
WarnerConstInc.'s Avatar
I have torsion axle's but, most sprung trailers had slop in the shakles just for that reason.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 11-15-2009, 09:35 PM   #7
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
The trailers Ive dealt with seem to have this on the lighter duty trailers. When you get into the more heavy duty stuff like 10,000lb they are usualy tight and the havy duty like 20,000lb have grease fittings. Im guessing yours is about 7000lb?
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 11-15-2009, 09:52 PM   #8
dlcj's Avatar
Trade: home builder carpenter Central Alabama
I have 12 year old 7000# cap tandem that does the same thing. I too once had about 4000# of drywall on it and when I made a tight turn the wheels looked like they where gona come off. And that was before the thing was worn out. I recently rebuilt mine with a kit from northern tool, $45. It came with all the bolts,new shackles, new idler beams, and all six frame brackets. It did not come the bushings. Mine were worn out too and the shackle holes where about twice the size they should be. I happend to have some moble home spings and idler beams laying around that I robed the bushings from (exact same size spings). The shackles in the kit are shorter than the originals (on my trailer) witch gives room for bigger tires.
dlcj is offline
"Wireless" LED Trailer Lights DirtMoverUSMC67 Landscaping 5 10-12-2009 10:19 AM
Changing Trailer Leaf Spring plazaman Off Topic (Non Trade) 1 10-01-2009 02:22 PM
Tandem axle trailer questions dkillianjr Vehicles 8 09-02-2009 11:47 PM
2003 Asv rc-30 skid steer with 20' trailer, auger, snow plow, 2 buckets kklick Contractor Swap 0 09-27-2008 07:33 PM
Trailer Weight Axle Question plazaman Vehicles 20 05-13-2008 12:39 AM
