Perkins Diesel Motors?????
Old 09-02-2009, 10:25 PM   #1
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
I bought a case 1835c skid steer and someone put a 46hp perkins diesel motor in it. Originally case (from what I gather on the website) they came with a 3 cylinder diesel and this perkins is a 4 cylinder. I bought this skid steer off of an estate so it's not like I can ask the guy the history of the motor since he is dead. I am having problems and need to make sure things are hooked up correctly so I'd like to get an online manual or at least see what is suppose to go in the threaded hole on the injector pump.
The motor has this on the tags .
KF70261J and 752173B
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Old 09-02-2009, 10:49 PM   #2
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
Re: Perkins Diesel Motors?????
Perkins makes good engines but they will not start when its 40 degrees or colder. If you plan to use it in the cold get a block heater on it. Do some research on it and the other sizes. The same maching may be used for different models but they just had different size engines. This engine may be from a different machine. Also look for the tag on the machine. The body part with the decal may have been changed.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 09-02-2009, 11:00 PM   #3
#1 stunner
Trade: Design/Build
The tag on the machine says KF70261J and 752173B that's all I can gather from this. I tried researching but google is failing me with what limited information I have. I can't find any other tags on the motor and I really need to find out if this particular hole has a plug thats suppose to go in it or if another hose is suppose to connect it.
Old 09-03-2009, 10:48 AM   #4
rustyjames's Avatar
I'm pretty sure CAT bought out Perkins so you might want to call a dealer for info. That hole might be just a timing inspection hole for timing the pump to the engine.
rustyjames is offline
Old 09-03-2009, 12:48 PM   #5
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Perkins! flashback to when I was a diesel apprentice - they are from england. They have a very uniqe govenor setup - and they are VERY sensative to the valve clearance? lash? settings. When they work, they work good LOL I worked on marine perkins diesels wayyyyy back in '72. You might have to get set of metric wrenches/sockets to work on this.
good luck
Laurie
www.lauriescustomfinishing.ca
Mrmac204 is offline
Old 09-03-2009, 09:56 PM   #6
#1 stunner
Trade: Design/Build
I've been a honda man most of my life, I have plenty of metric stuff: actually 90% of it is! haha
Diesel 6500 CrpntrFrk Contractor Swap 1 01-20-2009 07:08 PM
2008 Duramax Diesel -30F XanadooLTD Vehicles 8 01-20-2009 09:32 AM
Economical Jobsite Heating... electric, kerosene , diesel, propane? plazaman General Discussion 8 01-19-2009 08:22 PM
94 753 diesel Bobcat RTK56 Contractor Swap 0 11-04-2008 07:40 AM
Consolidated Diesel Electric Genset thecrose12 Electrical 0 03-08-2004 04:34 PM
