Peeves Part 3
Old 11-15-2009, 05:05 PM   #1
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Peeves Part 3
Product labels on finished surfaces...
I just finished a window project for a friend...I didn't want to be there, PITA etc... so in my finishing details I had to remove the stickers...Low E, packing slips...you know....
Here I am for an hour with a razor blade for an hour scraping 5 windows and cleaning....
The worst is medicine cabinet shelves that are clear plastic...and finished plumbing fixtures...aaaarrrrggggg!
What does festool offer?
WNYcarpenter is offline
Old 11-15-2009, 05:52 PM   #2
Inner10's Avatar
Trade: Control Systems
Re: Peeves Part 3
There is a special place in hell for thoes that put stickers on finished surfaces.
A local raceway supplier puts bar-code stickers on the visible part of the product and its the worlds stickyest crap. I'm affraid to use goo-gone for fear that the paint will not adhere to the surface, so then I have to use breakkleen to get the goo-remover off argh!
I feel your pain.
Inner10 is online now
Old 11-15-2009, 05:56 PM   #3
Tom Struble's Avatar
Trade: siding
Re: Peeves Part 3
cardboard,packaging materials,pallets...i didn't order no pallets
Tom Struble is offline
dkillianjr (11-15-2009)
Old 11-15-2009, 07:40 PM   #4
Jeff
jkfox624's Avatar
Trade: master turd burglar
Re: Peeves Part 3
Yeah ive noticed the product name on the window is like a static cling but the low e sticker is like super glued. Stickers on toilet bowls are impossible to alot of times. Sometimes you clean the freaking stickers off and you can still see the outline from it.
jkfox624 is offline
Old 11-15-2009, 07:56 PM   #5
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Re: Peeves Part 3
3 M has a glue remover that works great. Nasty stuff though, gives me a headache when I use it.
fireguy is offline
Old 11-15-2009, 08:05 PM   #6
kubie's Avatar
Trade: general contractor
Re: Peeves Part 3
i hear ya about them darn stickers......pain in the arse!!!!
kubie is offline
Old 11-15-2009, 08:25 PM   #7
KentWhitten's Avatar
Re: Peeves Part 3
You're not supposed to use razors on Low-E glass
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-15-2009, 09:00 PM   #8
Trade: siding
Re: Peeves Part 3
yea no scrapers,one of those labels would have probably
said that
Tinstaafl (11-15-2009)
Old 11-15-2009, 11:02 PM   #9
paul100's Avatar
Re: Peeves Part 3
Razors are fine on Low-e glass as long as the low-e is part of an inulated glass unit. The low-e should of been installed toward the middle of the insulated unit. The outside of the glass is not coated unless it has a self clean feature on it.
paul100 is offline
Old 11-15-2009, 11:07 PM   #10
Trade: siding
Re: Peeves Part 3
the ones i see say no scraping
maybe it has nothing to do with lowe
but thats all i install
just keep them wet with glass cleaner they eventually come off
Old 11-16-2009, 01:11 AM   #11
freemason21's Avatar
Trade: carpentry and painting
Re: Peeves Part 3
i worked for a glass guy for about 2 years. so i've seen all kinds of stickers and i always had to take them off. i never once scratched the glass or whatever it was i was taking a sticker off.
the way i was taught to remove stickers is spray commercial glass cleaner on the sticker, let it soak in for about a minute, then take your single edge razor and work it from one corner, once a you have a little bit of the sticker up, spray more glass cleaner on, always going in one direction.
maybe some of you have tried this, maybe some of you havent. if you havent it, give it a try, it never failed me once.
freemason21 is offline
Old 11-16-2009, 11:25 AM   #12
Wolfgang's Avatar
Trade: Painting & Remodeling
Re: Peeves Part 3
Every once in a while I'll get an acrylic tub surround or shower stall where the label is a real bear to remove, even with alcohol and lacquer thinners. I dont know what they use for adhesive, but I can think of better uses for it.
Wolfgang is offline
Old 11-16-2009, 04:53 PM   #13
wannabe
Trade: carpentry
Re: Peeves Part 3
Why on Gods green earth would you label something you can't remove....Honestly...the sticker removal 85% of the time is more difficult than the actual installation...
What's the thought on just leaving the stickers?....after all they are there for the consumer's education..???
The Following User Says Thank You to WNYcarpenter For This Useful Post:
OGStilts (11-17-2009)
Old 11-16-2009, 05:01 PM   #14
bathroom guru
jarvis design's Avatar
Re: Peeves Part 3
How about a sticker that you are NOT supposed to remove??
I have installed some shower doors from MAAX and they have a nice white sticker they put right on one of the glass panels that says:
Removal voids warranty
I of course always do, cause who wants a white (paper) sticker on the front side of your shower door??
I guess it cuts down on their warranty claims...
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 11-16-2009, 05:12 PM   #15
wannabe
Trade: carpentry
Re: Peeves Part 3
Thanks for the tip!! It's still BS to need removal instructions for manufacturer stickers!
Old 11-16-2009, 05:23 PM   #16
Trade: siding
Re: Peeves Part 3
as i go around checking each new window for proper operation
i peel each label and stick each one to its own piece of printer paper
so the homeowner can save them for future reference or tax purposes
Old 11-16-2009, 06:23 PM   #17
wannabe
Trade: carpentry
Re: Peeves Part 3
Your're absolutely right!! I was whining...
In this instance the reciept and window specs were given hard copy to the property owner and advised to take up tax rebates with his accountant.....
documenting the stickers from one window is good practice, but the other 4 or 34 in some cases is tedious! Let alone all the other product labels we deal with throughout the larger projects....
I was just complaining to complain
Old 11-16-2009, 08:32 PM   #18
Re: Peeves Part 3
hope it works out for you
Old 11-17-2009, 12:22 PM   #19
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Re: Peeves Part 3
Go to a car dealership and go to the paint shop. Ask the tech's inside what they use to remove bumper stickers. Spray on, wipe off. 5 minutes wait time. 22 bucks a can but worth it in time saved.
Cdat is offline
Old 11-17-2009, 10:04 PM   #20
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Send a message via AIM to WilsonRMDL
Re: Peeves Part 3
I sometimes run into lowes to grab a few copper fittings if I'm working on a sunday or late and the plumbing supply is closed. It seems like just about every elbow or other fitting always has a nice sticker glued on right where it's to be heated up. Unless you buy the contractor packs i guess, but when you only need 1 or 2 fittings, it's not worth it usually.
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Okay, Here's My Take on the Economy, Part One dirt diggler Business 12 03-20-2009 10:52 PM
HELP! need hard-to-find part HVAC gopher HVAC 11 01-13-2009 05:45 PM
Part Time Moulder Service Mike65 Finish Carpentry 24 11-29-2008 10:24 AM
2 part thread: hydro vs. BB/ Biasi vs. Buderus loogout1 HVAC 0 07-06-2008 04:13 PM
Part time Painter glock40 Help Wanted or Looking For Work 0 10-15-2005 12:06 AM
