Trade: Finish carpentry and Painting
Peeling Paint From Pipe
I have a customer that has a steam heating system with radiators in their home. The pipe running from the first floor to the second is about an inch from the wall and obliviously goes thru the ceiling. The paint around the pipe in the cieling and on the wall which, like I said is about an inch away is peeling like crazy. Now I know the prob is the pipe is sweating and condesation I just don't know how to stop the pipe from doing so. I don't want to just fix the paint and get a call back in a few months or so. Will pipe insulation be a fix or is there anything else you guys have come across that could solve it? Thanks in advance!
Trade: Painting Contractor
Re: Peeling Paint From Pipe
Is the condensation coming from the space where the floor joists are? I'm guessing the pipe is next to an exterior wall? Is it colder in there, i.e. drafts? That would be hard to stop.
| The Following User Says Thank You to Bender For This Useful Post: | Platinum8 (01-13-2009) |
Trade: Carpenter/GC
It is unlikely the pipe "sweating" unless you are pumping cold steam through it.
![]() If there is a radiator on the floor above the valve may be leaking. Check the flooring for signs of water. Since it will happen when the pressure has built up a little,run the heat for a bit, or put some paper towels under the valve to see if it is the problem. If there is no water around it may just be the heat reacting with the plaster/board. You could clear away some of the plaster from the pipe to allow you to slide some pipe wrap up into the ceiling/floor. Most exposed pipe installations will have an escutcheon to cover the gap around the pipe. |
| The Following User Says Thank You to Aframe For This Useful Post: | Platinum8 (01-13-2009) |
yah it is on an exterior wall. I'm not sure if there is a radiator directly above. I will have to check when I go back there. It gets pretty cold in there when the guy leaves for work thats when i saw the pipe condensating. Thanks guys
| pipe fence | danalm | Welding & Steel Trades | 8 | 10-06-2011 05:28 PM |
| Pipe sizing | eager2start | Plumbing | 23 | 11-21-2008 08:37 PM |
| lead paint issue | outsidethelines | Painting & Finish Work | 9 | 04-01-2008 09:13 PM |
| Peeling Ceiling Paint | jerome8283 | Painting & Finish Work | 23 | 03-15-2008 07:41 AM |
| Roof paint | Teetorbilt | Roofing | 3 | 05-07-2004 05:47 PM |
