Trade: Plumbing & Electrical
Parking Pole Removal
I dunno where the hell to put this thread. See pic below. My client wants to have that pole removed now that I have removed her tanked heater. I believe it's just a steel pole with concrete. What is it going to take to make it flush with the floor, with your average plumbers tools?
Thx
"....And then we all switch places when I ring the bell" -Adrock
The Grand Wazoo
Re: Parking Pole Removal
A 4-1/2" grinder with a cutting wheel oughtta do the trick.
Pro Plumber
Trade: Plumber
Not knocking your work but, whats up with the gas line, why did you not square it up. A longer piece of channel would have done the trick.
I fudged it up....After it was together I stood back and gave a rather audiable What the Fu*k. I was time crunched and I am by no means done on this house. Hard water is killing the fixtures.
So just a metal cut off wheel, all the way around, then break it over?
Pro Plumber
Trade: Plumber
I thought so, now you have to give us an updated picture when fixed, so we know you fixed it. Don't leave us looking at that screw up.
#7 | |
Re: Parking Pole RemovalQuote:
#8 | |
The Grand Wazoo
Use a masonry wheel on the concrete if it doesn't break flush with the floor.
Pro Plumber
Trade: Plumber
Maybe a longer nipple between the shutoff and the 90 will square it up.
Restoration Crazy
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
EVIL GENIUS
I would do like others said and use a angle grinder and just grind the pipe it off flush with the floor.
Ive never seen a pole like that in a garage, looks stupid.
I am just a vessel from which genius flows -Homer Simpson Global warming is a myth, like evolution and the metric system. U.S. Coast Guard
#12 | |
Trade: Plumbing & Gas Contractor
#13 | |
EVIL GENIUS
They should pain the pole black so you can see it instead of painting it white like the wall.
Trade: master plumber
why no small elec. heater, to serve the circ. loop?
Trade: hjrafiuoashfed
Re: Parking Pole Removal |
Trade: Construction
Bummer that it's part of the floor - I've seen many that have a bolt-down flange top-mounted on the finished concrete instead. You just unscrew the concrete screws (or bust 'em off) and the metal pipe and flange are free. Is it possible that the white piece is a cover of some sort over that kind of arrangement?
Seems like it would have been a PITA to pour the concrete and get it smooth with a big pipe in the middle of the floor... Mac |
Parking Pole Removal:
Standard Procedure - Get a nice solid chain. Attach it around the base of the parking pole, and the other end to the bumper of your work vehicle (nice new truck recommended). Allow engine to warm up, place truck in parking gear. Rev engine to 4K RPM, drop gear into drive. Please post pictures....
- Build Well - |
#18 |
Lol, yeah thats sounds good.
![]() If you take this alternative, post pics for sure. Of both truck AND floor!
Renovations, Restorations, Additions |
#19 |
Trade: Outdoor contracting: fences and decks
It's called a bollard and is commonly used to provide protection for structures that are suceptable to being banged into by vehicles. I would guess that someone hit the platform or the heater at some time in the past.
Easy removal: go to a rental store and rent a concrete curb cutter, or if they don't have that a quick-cut with a steel cutting blade. We've done them many times. |
#20 |
Pro Plumber
Trade: Plumber
Code requires it, if the heater is in a direct line of a vehicle that a post is required.
| Wallpaper Removal | Red Canary | Painting & Finish Work | 33 | 03-21-2007 03:24 PM |
| Plaster Removal | Mulecreek | Drywall | 8 | 01-16-2007 10:13 AM |
| Parking lot- sand or no sand? | gdavis | Excavation & Site Work | 6 | 01-08-2007 09:08 PM |
| Pole Barn Feeder | sparkysteve | Electrical | 4 | 10-21-2006 08:57 PM |
| pricing wallpaper removal | lornmastro | Painting & Finish Work | 23 | 09-21-2006 09:40 PM |
