Outdoor Crown Transition
Old 08-23-2007, 05:34 PM   #1
Wood Butcher's Avatar
Trade: Contractor / Remodeler
Looking to see if anyone has a slam dunk way to transtion crown from horizontal to gable (10 pitch). I've seen it done using two different sives of crown but I can't remember the details...Anyone?
Wood Butcher is offline
Old 08-23-2007, 05:39 PM   #2
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Re: Outdoor Crown Transition
Can you break the lines with sometype of plinth block?
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 08-23-2007, 05:43 PM   #3
I don't think so...
Old 08-23-2007, 05:44 PM   #4
slowsol's Avatar
Trade: General Contracting
http://www.contractortalk.com/f13/crown-vaulted-ceiling-25779/
Search function is your friend.
-John
We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today.
slowsol is offline
Old 08-23-2007, 10:57 PM   #5
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
Im trying to picture what you have here. Could you use a 2x4 and mount it up there or have someone hold it while you mark it to get the correct angle. Then cut the 2x4 and make sure your right before you use molding.
Michaeljp86 is offline
HELP - Transition at angle between floor and carpet rajrajput Flooring 1 07-19-2007 08:40 PM
Transition from the 3/4 PVC to NM remster Electrical 10 06-19-2007 04:17 PM
Pitched to flat transition reveivl Roofing 17 05-31-2006 04:02 PM
hardwood to berber transition? badassdak20 Flooring 5 01-30-2006 02:09 AM
best transition? mike959 Flooring 11 01-04-2006 10:41 PM
