Orange Flames On Propane Stove
Need some advice. We've had this range and from the beginning it really didn't seem to work 100%. Lately, it's been leaving soot on everything. It's obvious it's not burning the way it's supposed to. Orange flames, making a popping sound on ignition, etc. It's not that old of a stove, maybe 2 years? Is this something I can adjust or should I just call the propane guy out?
I'm assuming a bad regulator.
Certified Remodeler
Trade: Kitchen bath remodeler
Re: Orange Flames On Propane Stove
Call a stove guy.
Vote for Pedro Kitchen, bath, St Paul remodeling Minneapolis Remodel Blog 203K Loan Consultant Minnesota |
Trade: Plumbing & Gas Contractor
Maybe regulator,maybe wrong orifice[s],maybe an air problem or a combination of the three.If the line to the range was added on at some point,it could be a pressure or volume problem.You would need the proper gauges and the range manual with the specs. and someone trained or licensed should give it a thorough inspection/tune-up.Good luck.
Handle It!
Definitely the wrong "Air Mix"! Or, believe it or not, bad Gas.
There should be an adjustment collar on the feed stem. (oraface tube)
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 12-07-2008 at 08:19 AM. |
Trade: Electrical
Re: Orange Flames On Propane Stove |
Trade: remodeliong, repair, woodworking
wrong air/fuel mix. too much fuel/not enough air. could be orifices or adjustment, maybe regulator.
Told wifey to call the pro. I don't need to blow myself up.....well, that may not be such a bad idea either!
Plumbing is a Profession
Trade: Plumbing & HVAC
Framerman gets the "Smart Decision" award of the week
Trade: Site Development, Trucking, Demolition,Environmental maint.& restoration
Look at the oraface tube ck for obstructions , the orange flame is too much gas not enough oxygen mix , if it has been sitting the tube can get clogged , Ive seen many times there is a tiny spider that seems to love propane gas and will build his home there. But dont use a pipe cleaner or other ramming tool to clean it, the hole is not actually round its square, Yes this matters or you'll never get your flame adjusted properly. If you have one in your area call a tech. It would probly save you money in the long run.
Trade: custom home building
I remember some "dial" type adjustments on the lines leading to the burners, and yes, spiders can be a problem.
If you can't figure it out, have your wife play dumb and call the propane company. They will figure it out for free. |
Well, the answer came the day before Thanksgiving when the propane tech came out. Apparently, the appliance place who installed it for us and hooked it all up changed out the orifices on the burners, but failed to properly adjust the oven. It worked, just not very good.
| venting a wood stove with other things | walshwoodworkin | Construction | 7 | 11-05-2008 09:17 AM |
| Alcove for Wood Stove | Agolk2 | Construction | 0 | 09-02-2008 01:23 PM |
| Oil vs Propane | LNG24 | HVAC | 8 | 10-23-2007 11:00 PM |
| Coal Stove Hood | Devil505 | HVAC | 1 | 12-06-2006 11:47 AM |
| Replacing a Propane Stove | robertc65 | Plumbing | 2 | 04-17-2005 07:00 PM |
