Old Patio Door Wheel Adjustment Screw
Old 02-27-2018, 11:38 PM   #1
Slimeshady's Avatar
Trade: painting
Rewards Points: 4
hav e you ever seen an old adjustment wheel like this?
I removed the screw and you turn the wheel but which way?
I want to raise the door.
Cheers
Slimeshady is offline
Old 02-28-2018, 01:58 AM   #2
VinylHanger's Avatar
Rewards Points: 7,604
Re: Old Patio Door Wheel Adjustment Screw
Just try it both ways. Only one will be the right way.
Just make sure you lift up the door first to take pressure off the wheel.
VinylHanger is online now
Old 02-28-2018, 09:06 AM   #3
AustinDB's Avatar
Rewards Points: 656
Looks like the screw is removed then replace it after adjusting the ten sided button.
As vinyl said, lift the door first-so you donít strip the adjusting screw.
AustinDB is online now
Old 02-28-2018, 03:14 PM   #4
Pangdev's Avatar
Trade: general contractor
Rewards Points: 188
you need to loosen the philips screw. This will enable you to use a flat screwdriver on the adjustment screw.
TIP:Lift on the door to make it easier to turn adjustment screw.
Good Luck
Pangdev is offline
Old 02-28-2018, 05:32 PM   #5
Slimeshady's Avatar
Trade: painting
Rewards Points: 4
thanks
autofeed screw guns for decks and/or drywall dale rex Tools & Equipment 11 02-24-2016 09:16 AM
Dry Pack for laying porcelain tile on exterior patio Kyong Tiling 8 09-06-2015 10:11 PM
Screw holes showing hoferbuilder Drywall 76 05-08-2011 10:21 AM
Concrete Sealer on Stamped Patio is flaking off? BobNoxious Concrete & Paving 3 07-25-2010 03:12 PM
