Trade: Builder, Residential Construction
Old Mold In Attic,need Advice
Just joined, great site.
A friend called me last winter, said his attic was drenched. I checked it out, told him to stop running the humidifier on high 24/7. Attic did dry out. Last week we replaced the entire roof. Previous contractor used 2x6 to span 15' with a 5/12 pitch, roof had a 8" belly on both sides, no collar ties either. The bottom of the plywood was black with mold, but it was dried up and flaked off. One of my guys noticed some dried up mold in a few spots on top of the sheetrock. The question is. Is this mold a potential problem? Should I remove all the insulation, clean the mold up with some bleach, and install new insulation? The roof does have soffit vents and two gable end vents which I think work better in a snowy climate (Rochester,NH). I have gotten conflicting opinions on this so any input would be appreciated. |
Re: Old Mold In Attic,need Advice
On a very related note, if anyone can post a link to the so-called "New York Standard on Mold remediation", that would be a good thing. I had it on my hard drive, and maybe I still do, but I can't find it.
First of all, welcome to the site.
Here's my opinion only, - - until some 'more-experienced-in-the-mold-department' answers come along. Don't touch it, - - way too much liability with mold these days, - - once you touch it, you're 'married' to it, - - inform the homeowner and suggest (they call) a 'mold-remediation' crew. If they don't want one, - - have them sign to that effect. My two cents only.
http://www.tr-built.com |
Ah-ha! I found it. This is perhaps the best document ever writtin on mold in the home. It gives a technical introduction and health effects in section 1.0 and 2.0. Section 3.0 is a step-by-step how to for prefessional mold remediators.
http://www.nyc.gov/html/doh/html/epi/moldrpt1.shtml |
I'm here in the humidity/ mold capital and Tom is correct, in for a penny, in for a pound.
Get someone whos ins. is geared to it. Here it is a specific clause. I don't have it and am not getting it.
#6 | |
Back from the dead...
Trade: Paperhanger/Painter
Re: Old Mold In Attic,need AdviceQuote:
If I come across more than 10 sq ft of mold, I am to advise the homeowner to contact a mold remediation specialist, or at very least, their local health dept. will have an 'industrial hygienest' available. This is supposed to keep me out of the 'lawsuit loop'. |
#7 | |
Trade: architect
Re: Old Mold In Attic,need AdviceLast edited by mighty anvil; 10-24-2005 at 02:03 PM. |
Bah Humbug!
Ventilate and insulate. That is the answer to all attic problems including mold.
As a roofer who does a bit of mold remediation work in attics, I can tell you the #1 reason for attics to mold up is improper ventilation. What you described is condensation build up, as you said because the humidifier was too high. In addition improer ventilation will also cause this. If there is a kitchen or bathroom vent it should not be vented into the attic. It should be vented through the attic and out the roof or soffit. IMO the only real way to remediate mold is to remove it. This is how I handle the problem: Tear off the roof and all decking. Apply biocide bleach-water mixture to all framing with spray gun. Encourage customer to have insulation replaced by others (I'm considering adding this into the mix only for mold remediation). Replace decking and roofing. Properly Ventilate. Absolutely no warranty against mold returning. I am not a mold specialist but I am willing to properly install your new roof system after the mold has destroyed the existing attic space. |
...jammin
Trade: Rock Disciple
Welcome NHCharger
Greetings from the corner of river and ocean, the land of rust and mildew This mold is a potential problem It must be killed dead dead dead or it will come back Just because it's dormant does not mean it's dead Bleach or a pro UV mold killer machine is the only way Your situation sounds bad, the flakyness does not mean it's dead If you can hit every bit of it with bleach and replace any insulation that might have spores in it, you may be OK You may want to hand it off to a specialist |
#11 | ||
| Possible Black Mold between 1st and 2nd floor | TurnkeyConst | Remodeling | 10 | 04-25-2007 11:37 PM |
| New Construction Showing Mold... | thepawnshop | Construction | 13 | 10-20-2006 07:43 PM |
| white mold | banctecbobn | Construction | 6 | 08-16-2006 06:54 PM |
| When you find mold?? | theworx | General Discussion | 2 | 03-05-2006 03:15 PM |
