No Permit Required!
Old 03-13-2011, 07:52 AM   #1
Smatt's Avatar
Trade: Plumber
Rewards Points: 152
No Permit Required!
In my area the maximum size shed is 12x12 or 144 sq. feet whichever comes first. In addition to this if shed is 144 sq. feet or bigger it must be built on a slab. You also must get a permit.
Does anybody else have requirements like this?
In certain cities in my area you need to obtain a permit to rent a POD. This one I have a hard time with. If you have e renovation and need to store stuff. In to keep out of the way. Like you need the added inconvenience to pay for a permit to get a temporary storage unit.
Smatt is offline
Old 03-13-2011, 08:11 AM   #2
Hmrepairs's Avatar
Trade: Remodeling contractor
Rewards Points: 250
Re: No Permit Required!
Where I live you can build a shed, any size, without a permit. It can even sit next to a property line. But as soon as you pour a slab, it is considered permanent, and you need a permit, and whatever easements for any possible encroachment.
Here is a really strange one. As a homeowner where I live, I am responsible for my water main all the way back to the cities main. In my case, that means out of my house, through the curbstop, under the street, to the other boulevard. When I replaced my main a few years ago, I had to pay to fix the street. Only place I've ever lived like that.
Hmrepairs is offline
Old 03-13-2011, 08:31 AM   #3
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Here you need a permit for anything bigger than 10'X10' that will be permanent. If it is on skids and is move able then no permit is required and is not taxable. Many people choose this option for garages if you do not mind a wood floor. I have seen up to 3 single bay garages lined up next to each other to keep from paying taxes.
woodchuck2 is offline
Old 03-13-2011, 08:35 AM   #4
TimNJ's Avatar
Rewards Points: 2,680
We also have the size restriction and have zoning restrictions as in has to be set to certain lot setbacks.
I have a rental property with city water and same thing , I am responsible out to the main in the street.
TimNJ is offline
Old 03-13-2011, 09:13 AM   #5
Smatt's Avatar
Trade: Plumber
Rewards Points: 152
We are responsible for our water supply only to city water meter, responsible for our city sewer to the Norfolk clean out box, both of which are always in our yard.
Smatt is offline
Old 03-13-2011, 11:24 AM   #6
Kent Whitten's Avatar
Rewards Points: 2,040
So one can build a 2000 sf shed?
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 03-13-2011, 12:05 PM   #7
txgencon's Avatar
Rewards Points: 430
In Dallas, you can build up to a 200 sq ft "accessory" building without a permit but it must meet all setback requirements. Unfortunately, I live in a "conservation district" and technically can hardly build a doghouse without approval.
txgencon is offline
Old 03-13-2011, 12:13 PM   #8
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,704
Where I used to live , you could build up to 120 square feet as long as it didn't have electricity going to it. I built a shed last summer for the mayor of our little town with no permit because we kept it under 100 square feet, but it had power going to it.
knucklehead is offline
Old 03-13-2011, 12:15 PM   #9
Anti-wingnut's Avatar
Rewards Points: 3,308
I don't think so
Exactly, define a shed
Anti-wingnut is offline
Old 03-13-2011, 12:47 PM   #10
Kgmz's Avatar
Our rule in the county.
One-story detached accessory structure used as unheated tool and storage sheds,
playhouses and similar uses, provided the floor area does not exceed 200 square
feet (18.58 m2) and it is at least three feet from a property line.
As you can see there is no mention if it is on a slab or skid, or anything about power as long as it is unheated. You can also see it is exempted from our normal setback laws, which are anywhere from 5 to 30 feet depending on the zoning.
Electrical is covered by a different jurisdiction, Washington State L & I.
Also for commercial this rule is changed to a max of 120 sq. ft.
Complete list of all county exemptions, mechanical, plumbing, IBC, IRC, etc.
http://www.co.pierce.wa.us/xml/servi...gbulletin8.pdf
Kgmz is offline
Old 03-13-2011, 01:59 PM   #11
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
200 sq ft here for any non-living area structure. I just did a 12'x16' on a slab with a regular garage door, It's pretty nice. 12'x18' and they would have had 2 months and $1,500 for a permit.
jhark123 is offline
Old 03-13-2011, 02:27 PM   #12
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
I live in FLORIDA.and if ya dont have a green card you do what ever ya want when ya want......so I am building a 4200 sq ft shed while listening to the sounds of mexcio
opiethetileman is offline
Old 03-13-2011, 02:33 PM   #13
General Contractor
greg24k's Avatar
Rewards Points: 7,330
Here you need a permit for any shed, but anything under 200SF you don't need footings, but is must be tied down and located 6' from the property line, unless local zoning says otherwise.
greg24k is offline
Old 03-13-2011, 04:31 PM   #14
Hmrepairs's Avatar
Rewards Points: 250
Yep, depending on size of the lot. Zoned residential, footprint of all structures can only occupy 65% of the lot size without a variance. So yes, as another poster asked, you could build a 2000sft. shed.
Old 03-13-2011, 05:52 PM   #15
Rob PA's Avatar
In our city, basicly whatever you are doing you need a permit. If its inside or outside. Regular property maintenance requires a repair permit. You want to change a recp? Permit.
Outside sheds require a permit. But under 100sq and no elect doesnt require or fall under inspections.
Facebook
Rob PA is offline
Old 03-13-2011, 06:33 PM   #16
sancho's Avatar
Trade: Master Hack
Rewards Points: 252
where I live I can build a shed up tp 8'X12' w/o a permit as long as it isnt consider a perminent structure. So I built mine on skids
"It's all good"
sancho is offline
Old 03-13-2011, 08:15 PM   #17
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
need permits up in these parts? surprised
blackbear is offline
Old 03-13-2011, 08:36 PM   #18
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
10x12 here, but I don't build too many sheds these days. I would like to but a pre fab shed is so much cheaper & since its considered portable you can go even larger without a permit. To bad too cause sheds are easy money.
SAW.co is offline
Old 03-13-2011, 11:03 PM   #19
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 28
My county in WA, one may build a 400 sf. ft. shed for storage, playhouse, etc. No office or residence allowed, although people push the limits on this sometimes.
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 03-14-2011, 08:37 AM   #20
catfish's Avatar
Trade: carpentry
Rewards Points: 348
No permit for anything except in Stillwater city limits, as far as I know. I'm in Payne County, OK.
catfish is offline
What to charge Heating Contr. for elect permit? airgrabber Electrical 4 02-23-2011 01:10 AM
Contract with Permit Application? Jaf Business 9 07-22-2010 06:33 PM
permit required? Pat Cullinan General Discussion 5 01-13-2010 06:00 AM
Soliciting work from issued permit lists Constructive1 Marketing & Sales 8 03-31-2009 07:53 AM
Is a permit required for fixing wind damaged soffit on apartment AustinDB Windows, Siding and Doors 4 07-31-2008 10:32 PM
